If you still want to chase it, looking on BUDS may reveal the code history. The bad gas theory sounds plausible, although it could have also been another type of glitch.
Stil want to - and will
It's in my DNA.
Originally Posted by Jerbear
Having coffee and one of my buds came by. We were discussing the incident and he said bad fuel. I said, but it happned the moment it was cranked. Meaning, a fresh load of fuel should not have caused a problem on start up. As compared to a few minutes later. It would have needed time to suck some of the new suff in. Right? Then, it made sense. Maybe? Perhaps the previous tank full was contaminated, and, since it was being consumed -by the spyder being in perpetual motion since the previous fill up - all was OK. But, once I had stopped, and the fuel level from the previous fill up was low enough -if contaminated- it allowed the pump to get a big gulp of bad stuff as soon as it was cranked. Thus, causing the check engine warning.
Anyway.....sounds very logical...actually quite possible. Considering no codes and the problem going away.
This is me. Thinking out loud and sharing without fear of intimidation.
If, the above is true. It truly was worth sharing.
Never, but never.....say die.
When checking plane fuel for contamination, we use a drip-cup to extract fuel from the bottom of the tank. If there is water in the fuel, it will show-up at the bottom of the tank -- therefore it will be in our drip-cup.
So, it makes sense the fuel could have been contaminated given your progression of events.
Will be interesting to see if you have any other problems... Hopefully never again.
Glad to hear you made it home fine!
I saw the rain over the mountains and thought about you guys riding back today. I hear some got quite a bit of rain coming over the tejon pass. I take it you went through Joshua tree?
Bob
Bob
East of J tree - 95,62,177, to I10 and home. It got a we bit wet out but like you said, based on weather reports. The folks that went Victorville way most likely got it bad. Bummer!
Exchanging ideas....it's all good
Originally Posted by Illinois Boy
My WAG is "Operator Error"!
There is not a code for Jerbear-operation; Good One
so my guess cannot be discounted yet, since there is not proof I am wrong!
I certainly do hope it isn't something as simple as the brake sensor needing attention. Not sure how many miles on your machine, but if it is dirty, worn-out, or has developed some sort of slack causing it to send a signal of the brake being applied... it could cause this.
Good point.
I watch for such things when night riding on rough roads. A bouncing brake pedal that results in illumination of the brake light is easily seen in the mirrors when night riding.
Remember... we are in WAG-mode here... since you said it was okay to do. I just thought I would lob-out a couple WAGs while the time passes.
You are welcome to WAG away here.
All in all, I seriously hope you get this figured-out so you can get on your way and enjoy the ride... Good luck to you!
Thanks
Jerry,
Glad to hear you made it back. I received your order this morning when I woke up and your Air Filter Kit will ship out today!
JT
Can' wait
Originally Posted by jthornton
Jerry,
JT
Thanks for the made it back. I'm looking forward to removing all the plastic under the hood. Tho a battle it may be I'm conviced it'll be worth every swear word
Finishing a thought
Having coffee and one of my buds cameitby. We were discussing the incident and he said bad fuel. I said, but it happned the moment it was cranked. Meaning, a fresh load of fuel should not have caused a problem on start up. As compared to a few minutes later. It would have needed time to suck some of the new suff in. Right? Then, it made sense. Maybe? Perhaps the previous tank full was contaminated, and, since it was being consumed -by the spyder being in perpetual motion since the previous fill up - all was OK. But, once I had stopped, and the fuel level from the previous fill up was low enough -if contaminated- it allowed the pump to get a big gulp of bad stuff as soon as it was cranked. Thus, causing the check engine warning.
Something I left out.
The spyder recognized a fault on start up. In this instance I chose to ride 21 miles with a known fault condition( no codes - but check engine warning). If, it was a bad fuel condition and it cleared while riding that distance. The spyders software would not know it had cleared....until the spyder did a new systems check on restart. Which is exactally what happened.
Thanks for the offer
So when is the wrenching party?
I will come help/participate if you like!
Bob
PM sent
I don't think so. No bowls on injectors... the only fuel remaining in the system is what is in the lines.
RT-S PE#0412
Bob
PM sent
Did I hear the word party?, so after reading this whole thread it appears it's not the TB, (thought you were referring to me), but maybe bad gas. I had that happen to me when I was up in Hollister at Corbin. So embarrassing not knowing what was happening, and that I might get stuck, but after I got through that tank, there were no more issues. My symptoms were erratic idle behavior, that I posted in this thread http://www.spyderlovers.com/forums/s...-idle-behavior
Hope everything rides well for you here on out
TB aka TicketBait
All is well....for now
Originally Posted by TicketBait
Did I hear the word party? , so after reading this whole thread it appears it's not the TB, (t hought you were referring to me), but maybe bad gas. I had that happen to me when I was up in Hollister at Corbin. So embarrassing not knowing what was happening, and that I might get stuck, but after I got through that tank, there were no more issues. My symptoms were erratic idle behavior, that I posted in this thread http://www.spyderlovers.com/forums/s...-idle-behavior
TB aka TicketBait
Other TB...
Sounds similar that's for sure. Just stocked up on ◇Gas-X◇ 'formulated especially for spyders'
