Page 8 of 9 FirstFirst ... 456789 LastLast
Results 176 to 200 of 211
  1. #176
    Mar 2012
    NJ
    Quote Originally Posted by hchays View Post
    I'm kind of new to the "Nanny thing", but I removed my steering sensor (the one on the bottom of the steering shaft). It looked like it had a magnet in the bottom of the shaft that controls how the sensor reads. If this is true could the sensor be removed and a magnet placed on the sensor to fool the sensor into thinking it is on the shaft and not moving?
    Potentially. I don't know why it wouldn't work. Unless there is some relationship between sensed steering output and different outputs from the front wheel sensors that it would expect to see only in a turn.
    I'm wondering also if one couldn't just remove the sensor but leave it plugged in??
    What did the opening look like when you removed the sensor? Would the area need to be blocked off if we were to try to do some runs with an unmounted sensor?
  2. #177
    Mar 2008
    Allegan, MI
    If you guys fool with the SAS, don't forget that it is constantly compared to the steering torque sensor. I'm not sure if the front ABS sensors factor into it, but they might, or they might be integrated with the yaw sensor to detect wheel lifting. It may not be as simple as it seems.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
  3. #178
    SoFlo
    If the sensor is removed from the steering shaft, it may not be wise to just let it be settled in the straight position. Maybe, to keep some input, the sensor could be relocated, and the mechanical rate changed from 1:1, to something less and have mechanical stops to limit what the computer sees as full steering lock angle. A flexible interconnect similar to a firm pair of rubber bands would allow the full lock travel of the steering with the sensor stopping well short of full lock.
    PK
  4. #179
    Mar 2012
    NJ
    I agree guys. I don't think totally eliminating any sensor input entirely is a good solution for long term.
    Just need to give nanny a Valium so she will relax a bit.....
  5. #180
    If steering and yaw sensors don't appear to be on the same page; she squawks...
    If she got no signal from either; she'd get nervous...
    But; if you could just get a constant input, for the signal that she expects when the bike is in gear, and just sitting still (as in traffic)??
  6. #181
    Very Active Member billrob71's Avatar
    Jun 2013
    Delaware
    Looking here at work at a angle sensor off a Chevy truck , the steering shaft of the column is flat on both sides and rounded on top and bottom. Half to look and see if maybe giving the hole where the shaft goes through maybe little clearance on the contact points , giving little movement in the shaft to sensor contact and several degrees before it actually engages the sensor . The trick is gonna half to be keeping the sensor centered and having a light spring tension to keep the sensor center until the shaft engages it
  7. #182
    Very Active Member SNOOPY's Avatar
    Aug 2013
    Can I put input here?
    Oops, wait a minute...you guys sound like you know 10 times what I do on this subject!
    Carry on.
    Just keep me in the loop. Lol
  8. #183
    Registered Users hchays's Avatar
    Jun 2013
    Milford, Ohio
    DrewNJ, I can't remember exactly what it looked like. If I remember the end of the shaft had a little square magnet in it and it sat against the sensor. I tried to remove it but leave it plugged in and I got a code. I bolted it back on and have not messed with it.
    It amazes me that BRP gave Nanny an adjustment on the 14's yet they won't make a software change to adjust the previous units. I would be willing to sign a release if they would create one.
  9. #184
    Mar 2012
    NJ
    You got a code with it removed but still plugged in? That sucks...wonder where it picked up that signal.
    I have been back and forth with splitsec and they even verified with me looking at the wiring diagram, that both the SAS and YRS are indeed a CAN signal.
    They even recommended rotating the YRS 90 degrees and either spacing the SAS off the shaft to give it a false input as an attempt.
  10. #185
    Charlotte, NC
    ARGH. Pulled out in traffic today and needed to speed up fast...and VSS kicked me down so hard I thought the Spyder had actually cut off on me.
  11. #186
    Aug 2013
    Quote Originally Posted by NetJunkie View Post
    Guess you need to go slower like Bob. Lol
    ....hiding.
  12. #187
    Jun 2013
    Delaware
    Quote Originally Posted by SNOOPY View Post
    ....hiding.
    RLOL
    You better go hide with that comment
  13. #188
    Charlotte, NC
    ....hiding.
    I knew it was either going to be you with a smartass comment toward Bob or Bob making a smartass comment telling me to slowdown as the first reply...
  14. #189
    Aug 2013
    SoFlo
    Can someone take their best photo skills and get a shot of the installed steering sensor?
    Maybe it is viable to remote mount the sensor, and drive the left, right input at a reduced rate or gain. Say use a small cog pulley set. As an example a 20 tooth from the steering shaft to a 40 tooth sensor input.
    Or maybe run it at the same ratio 40:40, but have one pulley on a slip nub with a centering spring. Build mechanical stops to let the pulley turn to lock, but stop the inner hub a set distance or degrees prior to full lock.
    PK
  16. #191
    Aug 2013
    Are you talking about the sensor mounted at the very bottom of the steering column?
    I can see some of it on my STS through the hole next to the right side suspension, not sure how clear I can get it....
  17. #192
    What'd I do now?
    Seriously; if you're gonna grab a handful from a dead stop with a turn on your mind; get your weight inboard!!
  18. #193
    Charlotte, NC
    What'd I do now?
    Doesn't help.
  19. #194
    Aug 2013
    What'd I do now?
    Stick to touring.
  20. #195
    I do; it allows me to ride more miles than you!
  21. #196
    SoFlo
    Focus People. This is serious stuff.
    PK
  22. #197
    Aug 2013
    Very Active Member coz's Avatar
    May 2011
    cincinnati, ohio
    Default good luck with that
    PK
    it was fun while it lasted.
  24. #199
    PK
    Yes; it is... But it also isn't necessary to wear a frown all of the time...
    Sorry...
    And I have tried to offer some useful direction and input in this conversation...
  25. #200
    Aug 2013
    Sorry...
    I for one love your useful directions.
