04-07-2014, 11:46 AM
#151
04-07-2014, 12:01 PM
#152
Originally Posted by NetJunkie
I could see them doing this with sensors that had higher sample rates... I also think the "relaxed" VSS is something they built for the next generation RS-S and it either got moved up or the RS-S updates got moved back. Guess we'll see later this year.
I don't know but I have a 13 and there was only 3 or 4 changes made between the two years .
I still don't think my decision of getting my 13 just do too the colors they have for 14 maybe the next update if they do a engine swap and bring back the green maybe time for a change .
Bill
2013 RSS Neutron Green
BRP HID's and Fogs
Custom Belt Tension
2014 side panels
HMF Exhaust
K&N air filter
Bajaron sway bar and links
04-07-2014, 12:02 PM
#153
Bill
BRP HID's and Fogs
Custom Belt Tension
2014 side panels
HMF Exhaust
K&N air filter
04-07-2014, 12:50 PM
#154
Originally Posted by billrob71
We will see Bob
It would be nice maybe that V4 motor upgrade and little different gearing in the sprockets and a 6 speed transmission, supercharger, traction control off button, etc etc...
LOL
04-07-2014, 12:52 PM
#155
04-07-2014, 12:54 PM
#156
Originally Posted by SNOOPY
LOL
hell might as well ask for a rock pack and wings while were at it
04-07-2014, 01:34 PM
#157
Hope you're right..and if anyone from BRP is reading I'd love to try a test mule for you. I bet I'm close to your target audience for it. Contact me.
04-07-2014, 01:41 PM
#158
Right there with ya
04-07-2014, 01:46 PM
#159
:drool:
lol
04-07-2014, 05:04 PM
#160
Watch it..!!
2012 RS sm5
04-07-2014, 05:46 PM
#161
Originally Posted by Chupaca
To many serious changes and it won't be an RS any more...when I spoke to them I said I go for a 1200 cc v-twin... ..??
I think what ever they do it needs to stay the same size it's borderline too big in currant size
any bigger and it can be called a RSST
04-07-2014, 09:20 PM
#162
Any info from split second?
PK
04-07-2014, 10:01 PM
#163
Yes. Don't bolt anything else on it. Take some stuff off... Give me more power.
04-07-2014, 10:16 PM
#164
Amen brother
Little less bottom end torque not much . Dam tire can't leave a light with out spinning , oops well maybe that's just me
Bill
BRP HID's and Fogs
Custom Belt Tension
2014 side panels
HMF Exhaust
K&N air filter
04-08-2014, 07:46 AM
#165
I apologize fo the language...
hell might as well ask for a rocket pack and wings while were at it
I hope that you don't mind the language...
04-08-2014, 01:27 PM
#166
04-08-2014, 01:36 PM
#167
04-08-2014, 01:51 PM
#168
04-08-2014, 02:20 PM
#169
04-08-2014, 05:08 PM
#170
Splitsec is a no go. Their signal modifier doesn't play nice and modify the CAN signal.
Nice people and very helpful though.
Back to square one!
Sent from my SCH-I545 using Tapatalk
04-08-2014, 07:48 PM
#171
Back to square one!
Sorry that was not a viable means.
Did Split Second offer any leads on companies that can handle the CAN signal.
PK
04-08-2014, 08:51 PM
#172
PK
No....sigh...
04-09-2014, 03:53 AM
#173
No....sigh...
Do you have a wiring diagram of your vehicle?
It almost sounds as if the +-5v signal needs to be trimmed somehow prior to the output from the sensor.
I do have an option to see what these things look like inside, maybe I can acquire a steering sensor from a car at the junkyard and see what is inside.
PK
04-09-2014, 07:12 AM
#174
PK
PM me your email address and I will send it over.
Basically, all we have to work with is: 5v, grnd, canhi, canlo. 4 wires for each. Since its CAN limiting the signal won't have any benefit. Kinda like lowering the voltage in a computer hard drive.
Its actually a pretty cool system with the specs on the size of the data bits and the redundancy on each of the hi-lo and the bandwidth of each.
I think to do anything effective its going to have to be more low tech with moving the sensor or removing it.
The more i read into it, I agree that its probably the steering angle sensor that's giving us the most grief at low speeds.
04-09-2014, 08:07 PM
#175
I'm kind of new to the "Nanny thing", but I removed my steering sensor (the one on the bottom of the steering shaft). It looked like it had a magnet in the bottom of the shaft that controls how the sensor reads. If this is true could the sensor be removed and a magnet placed on the sensor to fool the sensor into thinking it is on the shaft and not moving?
