These are not the fault codes, they are warnings. The actual active fault codes would have to be called up using a special manual procedure for your particular model, or the fault code history can be read by the dealer via BUDS. That would be necessary to try to determine the actual cause. What you saw were cascading warnings, where one critical system triggered the shutdown of another, related system.
Most likely causes for your problem would be:
1. Riding the brake pedal (or brake switch/pedal bumper failure). Merely touching the pedal without actually applying brake pressure will trigger this sequence
2. Low voltage. The DPS takes the most amperage of anything but the starter. A turn can pull a depleted battery too low, triggering warnings and limp mode. A weak/bad battery can do the same.
3. Bad DPS. This is something for the dealer to diagnose and repair.
4. Bad/loose/obstructed ABS sensor or clogged sensor wheel. If a VSS shutdown is triggered because of a perceived brake problem, it will shut down related systems.
I would guess that yours is most likely one of the first two possibilities. There are additional possible causes.
Are you by any chance running tire sizes different than OEM? Or did you have a tire that was low?
Sent from my SCH-I545 using Tapatalk
Yes my front tires are 185 60s. jtpollock
I didn't pay close attention this morning, but I just noticed the mileage on your Spyder. Add one more strong possibility...worn brake pads. If they are thinner than a worn dime, it's time to replace them. Also check your brake fluid level. Usually that causes a different sequence, but it can shut down the VSS and trigger cascading warnings.
