Micro-Start PPS (Emergency Battery) Test Results
OK so i got one of those Micro-start PPS emergency batteries the anti gravity ones, actually the XP-3 model, i got it about a week ago, charged it completely up and put it in the back of my Spyder in its bag (This thing is smaller and lighter than my Ipad).
Today i disconnected the battery to my 2010 Chevrolet Suburban, and then connected this XP-3 to the cables to see if it would start. It started my Suburban 4 times in a row with no problem, I did not want to try anymore because I did not want to damage my Suburban, the XP-3 lights showed that it was still fully charged.
I wanted this to be able to have a battery to jump start my Spyder in case of emergency ................. Well this little sucker works like a charm. I bet i could start 20 Spyders before it runs out of power.
Go to Amazon.com and google Anti Gravity Battery and they have two styles like this the XP-1 and XP-3, i think the XP-1 just has more attachments, the XP-3 has the Jumper Cables, a USB cable with 3 different outputs and a nice soft carrying case.
It is a lithium battery so you can charge it and it will hold that charge for a year or better and it appears to be the safest way to carry an extra power supply.
It comes with a car charger and a wall Charger ($110.00 AND UP CHECK EBAY OR AMAZON FOR FREE SHIPPING)
Update: fully recharged in 40 minutes with wall plug and now it heads back into its stoage place in the Spyder.
Cruzr Joe
jumper
i have a different type and i have to keep it hooked up to the battery for a few minuets to charge the battery but thanks i am going to look up the one you have
The same night I bought the xp-1 my spyder battery died. Hmmm? Anyway, I'm with you...nice thing to have.
Joe,
Do you have a link to a website for them?
Joe,
WWW.ANTIGRAVITYBATTERIES.COM
Spyder tech review - Previously posted
http://spydertechnician.blogspot.com...new-micro.html
Have used it to recharge my phone, tablet, and start the spyder. Also, if you use BRP's custom bags. It fits nicely when placed in the left compartment before putting the bag in. fwiw
i just ordered one, it's better than the one i have
Good Move
Cruzr Joe
Joe,
I only took a quick peek at their site so far...
Does that little powerhouse come with connectors, or do you order them separately?
It comes with battery connectors to start a vehicle and a 3 way power cord from usb to power a cell phone, Ipad and other stuff. all in one small soft case.
Cruzr Joe
THIS DEVICE
ON E-BAY # 261418474596 ....$ 110.30......or bestoffer,with free shipping ................I'd try best offer first you have nothing to lose......Mike
Thank You Joe...
I just ordered one...
Just ordered mine
Better then carrying jumper cables , plus able to charge phone when camping !
Thanks Joe for the heads up !
I am glad that i seen someone else's post on these, they are the best battery supplies that i have seen for motorcycles and cars.
Cruzr Joe
can you jump start the spyder with this through your 12-volt port on the bike?
Hi Joe:
This is awesome and didn't know it was even available but now I do thanks to you.
Hey- can you hook this up some how to jump start the Spyder via the 12-volt port in the trunk or does it have to be connected to the Spyder's battery posts?
Thanks!
Originally Posted by Cruzr Joe
2015 RT-Limited SE6-TricLED Fender LED's (Red and Amber), 3rd LED Brake Light/Tail Light, ISCI Handbrake with black small hands handle,Spyderpops Rock Guard. ,Can-Am Adjustable Wing Vents, Bumpskid, Bajaron's Sway-Bar with metal Heim Joints. Elkas Stage 2 Plus., TricLED Wide-VU Mirrors, TricLED Jumper Port, Laser Aligned!
Originally Posted by Elembytes
Hi Joe:
Thanks!
Cannot boost through the 12V accessories port. I am guessing you have 2012 or older Spyder. In that case you can't push 150 to 200 amp through a 3 amp fuse and a 22 gauge wire.
Hi Joe:
Thanks!
No this needs to be at the battery for best results you may be able to use the battery terminal posts under the seat on an older RT, don't know where they are on a ST or a RS, someone correct me if i am wrong.
Cruzr Joe
Thanks I just saw this at one of my local motorcycle shops and was wondering how well they work. On my add-on list now.
** Loving my 5th Can-Am Spyder since 2007! **
Okay---how about this---
I suppose hooking it through a tender pigtailed directly to the battery terminals wouldn't work either then, am I right?
Just trying to think in an emergency an easy way to use something like this without the hassles of trying to get to the battery easily. It is a 2012 RTS-SE5 that I have.
Thanks for this tidbit though--sounds awesome---just was thinking of an easier way to hook up is all.
Cruzr Joe
Thanks for the info. Just added the xp-3 to my wish list
Sent from my GT-P7510 using Tapatalk
