Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 56
  1. #26
    Invalid Emails
    Mar 2014
    Northen Maine
    Quote Originally Posted by bobnaquin View Post
    Brake fluid low will give an error when it needs about a teaspoon of fluid. Brake pads can wear down to a mm before needing changing. That is really thin but there you have it.
    Change the oil every 5000 miles, ride it regularly and don't modify the electrics in any way. At least until you learn the proper way to do it-on here.
    I am on my second RS and they are rock solid, strong and problem free since the power steering has been fixed. You should have a lot of fun.
    Thanks Bob Naquin! The pads look OK, but a more thorough inspection is necessary. I'll be sure and ask here about any electrical mods. The Can-Am oil change kit will be in next week. I did suction out the oil tank and put in semi 20w-50 I had for my Suzuki (wet clutch rated). It was NOT SM.... It has to be better than the stuff the previous owner left in there (phew!). I noticed it now goes in neutral much easier......Art
  2. #27
    Invalid Emails
    Mar 2014
    Northen Maine
    Quote Originally Posted by Queasyrider View Post
    Thanks, Spydaman60! People on this forum are having an incredible time with their "Spyda's". I haven't had so much anticipation since I bought my V-Max 10 years ago! Big day tomorrow!..............Art
    I've been riding two days now, I LOVE this thing!!..........Art
  3. #28
    Here's to lots more miles and smiles!
  4. #29
    Mar 2008
    Allegan, MI
    I'd recommend you get that 20W-50 out of there ASAP. The water-cooled Spyder engine is not designed to operate with the heavier oil meant for air-cooled engines. Until you get it out of there, take it very easy...especially when cold, and warm it up thoroughly before you rev the engine or hit the road.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
  5. #30
    Invalid Emails
    Mar 2014
    Northen Maine
    Quote Originally Posted by NancysToy View Post
    Thank you for the advice! I have been taking it easy, getting used to it. It's been warm here in Tampa, 65-75f. New oil here Monday.....
  6. #31
    Mar 2008
    Allegan, MI
    -Scotty
  7. #32
    Jan 2013
    lancater ohio
    congratulations On your new spyder. I have a 2012 rs and will have 25,000 miles on it this week. I've put on new rear pads and a rear tire...you can not beat the rs. Enjoy the Ryde and put some miles on it!
  8. #33
    Invalid Emails
    Mar 2014
    Northen Maine
    Quote Originally Posted by greatrides View Post
    Thanks Greatrides! Quick question: I noticed at highway speeds 50-70 mph, the wind over the windshield hits me right at my face. Do you have a similar problem? I wear an open face helmet, full face is too hot in the warmer weather especially in the heavy traffic here.............Art
  9. #34
    GOS Founding Member (Girls On Spyders)
    Apr 2011
    Arkansas
    BRP makes a 25" windscreen that might help. I keep it on until we get to the really hot days here in Arkansas. I thought I would like the taller model to help with buffeting, but it cut the airflow down too much on 90degree days. Once it's that hot I switch back to the short sports screen and just wear a 3/4 helmet. But below about 80, I do like the taller one even though it takes away from some of the coolness factor of the RSS.
  10. #35
    Invalid Emails
    Grant, Florida
    Default Awesome purchase!!
    If you'd like pm me your vin or call me at the dealership ( 321-725-7225 ) and i'll run that vin
    You got a friend in Grant,Fl
    -chuck
    Route1Motorsports
    chuck@route1motorsports.com
    321-725-7225
  11. #36
    Registered Users CanAmKidd's Avatar
    Dec 2013
    Goose Creek S.C.
    Let me throw this to the wind. Could it be due to the size difference on the handle bar switch housing? Being the LH is larger and directing upwards?
    Now I have one for you guys. When I ride holding only with my left hand it pulls to the left, right or both dead straight down the road.
  12. #37
    Invalid Emails
    Sep 2012
    Clermont Florida
    Cool
    Can am kid the switch houseings should have no difference in handling, maybe your left arm is causing a slight pull,The right or left hand on the bars with slight pressure on them should have you tracking straight.
    Mike
  13. #38
    Invalid Emails
    Sep 2012
    Clermont Florida
    Smile
    Congrats on the new spyder from one rss rider to another youll love it.
    My thoughts on the 20 /50 cycle oil is that my Harley V Rod V twin is watter cooled also and i use synthetic HD oil for it as well as my 2012 Can Am Spyder although the spyder calls for 5w40 i prefer here in Florida to use the same oil in both machines due to the heat here and the synthetic hd premium oil with the same jasco ratings works verry well with no manual clutch problems.
    Im not recomending this to anyone else these are just my personal choises having used this oil in both new and used Harleys with air and watter cooled V twin motors with no failures.
    Mike
  14. #39
    Mar 2012
    NJ
    Don't sweat running that 20/50. Aprilia has been running the same v twin in most of their bikes for years and a lot of those guys run 20/50. No oil issues.
    BRP specs the 5/40 oil because it's the same oil they use in a lot of their other machines.
    Sent from my SCH-I545 using Tapatalk
  15. #40
    Invalid Emails
    Mar 2014
    Northen Maine
    Quote Originally Posted by mcaccamise View Post
    Mike
    Thanks Mike! The correct BRP oil and filter kit will be here Monday. The oil that was in it smelled like gasoline and was pitch back......I wanted it out ASAP! The clutch does release better, but still gets grabby occasionally. The plates may be burnt......Art
  16. #41
    Invalid Emails
    Mar 2014
    Northen Maine
    Quote Originally Posted by DrewNJ View Post
    Thanks Drew! It's been a while since I read up on it, but I remember that the low number (20)indicates the equivelent viscosity of 20w at 0 dg. F, the high number (50) is the same as 50w at 212 deg F (Or something like that!). Anyway, I feel the same that clean oil was a better choice, even if a little thicker.............Art
  17. #42
    Jan 2013
    lancater ohio
    Default I do
    I do get a lot of wind....you do on a rs. They make bigger windscreens Witch will help.
  18. #43
    Invalid Emails
    Mar 2014
    Northen Maine
    Quote Originally Posted by FaranH View Post
    Thanks FaranH! Yeah, the the last two bikes I had, Intruder 1400, V-Star 650, both came with windshields. I took them off right away as I like the "coolness" without them. I ordered a used RSS windshield from eBay to try cutting it down an inch at a time to see what works best. I'll post how it works out. Did the new sway bar help with the floating feeling at high speeds? Also, getting a lot of lean on sharp turns at lower speeds..........Art
  19. #44
    Mar 2008
    Allegan, MI
    The lean is something you have to get used to, to some extent. Be sure your front tires have sufficient air...around 20 seems to work well on the GS/RS. That may also help the floating feeling, although overcontrol is a common cause, and the toe-in may need adjustment. Be sure the front tires are the same pressure as each other. To help with the lean, set your front shock preload higher or replace the front shocks with 2010 or the 2011/2012 RT units. Take-offs are available at reasonable prices. Elkas would be better, but more expensive. Lean your upper body into the curve or shift your weight. It's like trying to kiss the knuckles of your inside hand. A BajaRon swaybar is the best help, and a real bang for the buck. Do some parking lot figure eights until you are more comfortable with the lean.
    -Scotty
  20. #45
    Invalid Emails
    Mar 2014
    Northen Maine
    Thanks Scotty! I used the e-air gauge supplied with the tool kit and set the front tires to 15.0 psi. My old mech gauge showed 17psi. Riding two up and taking a left at a light, I noticed the right tire flattening out. Will the 20psi throw off the VSS? I guess it monitors yaw (lean) and modulates the eng timing/brakes to avert lifting a wheel. I'll try a higher preload a little at a time.
    The sidecar hack required body english, careful throttle, etc. and would still lift the wheel......Art
  21. #46
    May 2009
    Connecticut
    http://www.calsci.com/motorcycleinfo/Spyderprod.html
    I have the CalSci X-Large on my RS and its protective while letting cooler air over the top and air through the middle hole which relieves turbulence and they are Cost Effective and Good Looking!!!
    Sea Doo GTI-SE 90 Jet Ski!!
  22. #47
    Mar 2012
    NJ
    I have one of those 25" touring windshields I just picked up to try and have used for a few rides. I absolutely HATE it. It works as it should keeping most of the wind off of me, but looks ridiculous, to quiet sitting behind it. Makes me feel 20+ years older than I am.... I really am just not a big windshield kinda guy...
  23. #48
    Invalid Emails
    Mar 2014
    Northen Maine
    Quote Originally Posted by Sarge707 View Post
    Hey Sarge, great website! You ordered the large, did you use their yardstick method?.............Art
  24. #49
    Invalid Emails
    Mar 2014
    Northen Maine
    Me too! See my post above to FaranH.......Art
  25. #50
    Invalid Emails
    Mar 2014
    Northen Maine
    Quote Originally Posted by Route1motorsports View Post
    -chuck
    Route1Motorsports
    321-725-7225
    Thanks Chuck! E-mail on the way...........Art
