Best Floorboards?
Which is the best floorboards for 2013 Spyder RT SM5?
Silver Shadow
2013 RT-S Lamonster Edition (vented windshield,
NBV highway pegs, Two Brothers exhaust)
Additional Mods: SpyderPops BumpSkid, Elka 1+ shocks, BajaRon Anti-Sway Bar
A Veteran is someone who, at one point in his or her life, wrote a blank check made payable to “The United States of America,” for an amount of “up to and including my life.”
Your choices may be limited since you have the SM.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
The BEST ones; will be the ones that you buy, after careful consideration of the pros and cons of what's available out there...
Sorry... it's always got to be your money; your choiice!
MOgang Member
with the suggestions that you should make plans to come to Spyderfest and check out all the bikes with floorboards and the vendors that will be their. Nothing like an informed decision and you can probably ryde home after the event with a new farkle!
Spyder: 2011 RT Limited w/ RT-622 trailer
Mods: ESI Brightsides, RT Rear Brightsides, HMT Brake Light, Scuff Guards, Utopia Backrest, Chrome, and more Chrome, Pearl White Rear View Mirrors, Rear Fender, and Dashboard, Black Rear Wheel and Belt Assy, SpyderPops Heat Shields & Bump Skid, Elka Stage 1+ Shocks, 2012 SF Graphics, Silver Carbonfiber Dash, Corbin Arm Rests, Baker A.W., BRP Vented WindShield. BR's Sway Bar, Tricled White Halo Lights, BadBoy Air Horn, Spyder Legs Floor Boards
I will give you my opinion only as I believe that the ISCI floorboards are superior with HGH quality billit aluminum and mounting hardware, check out the website sight sponcer.
Mike
Thanks for the advice.
Sent from my GT-N7100 using Tapatalk
How tall are you? That could make a difference.
You always have the BRP floorboards since you have a 2013. They have a "Breakaway" feature where the board will actually tilt forward if you have to use too much brake.
Seals are big. they give plenty of room to move around, and one model will actually replace the need for highway pegs.
Isci are basic.
Both seals and Isci will bolt on to your existing foot pegs (I believe), so if you have long legs, it may still be an issue. My legs were long enough so that seals really couldn't get my knees in a position to ride comfortably for long periods.
Rivcos replace the pegs, and drop the floorboards down about 1-2 inches. They do allow me to get my knees into a comfortable position (for me). I used to use my highway pegs quite a bit, now I find I don't need to use them as much.
It is best to find an event, or gathering, and try some different options out though...
Love my Seal DLX and they make them for a SM5
2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
Thanks. I'm 5' 11" and I do have a problem with them being low enough. Will check out Seal @ Rivcos.
Love my Web Boards. He's a site sponsor too.
Are the Web boards low enough to let you stretch your legs?
Well they are the same height as the original foot pegs, but they are strong enough to put your feet up on top where they bend up in the front, much like a highway peg if you want to stretch out.
I am going to spyder fest next month. Will check them all out. Tks .
RT-S PE#0412
here is a link I put together where you can contact the Vendors from spyderlovers for info if there boards will work for your SM5
http://www.spyderlovers.com/forums/showthread.php?55172-SMORGASBOARD-OF-FLOORBOARDS-PEGS-AND-FOOTRESTS
good luck, and let us know in this same thread what you ended up with.
The best floorboards belong to me and I made them from 1/4 inch thick aluminum diamond plate. They are exclusive and nothing like them. I put the most love in making them.
2012 Spyder RT SE5 Brake pedal mod
Web Boards will have both the original long floorboards as well as a new mini board that fit the SM 5 model 2013... see you at spyderfest
Web Boards Mini and Full size pics
Top row shows Mini Boards (one with linex coating) the other with Stainless steel. Notice that highway pegs can be used with this model boards.
Bottom row shows full size RT web Boards.
Visit our web site for more details!
