Spyder rt hitch
Doing my homework thought I could do it myself. Picked it up today and the "instructions" are poor quality black and white photo's no step by step written instructions. Can anyone help?
Where'd you get the hitch?
BRP's instructions are normally very detailed, and pretty easy to follow...
It is a BRP hitch got it from my dealer, guess I should say that it is the wireing that has me worried
try here http://www.spyderlovers.com/forums/s...elt-adjustment
Here is an excellent set of instructions on Spydertalk for installing the Hitch and wiring harness, only difference is the connector to the trailer. I used this to install mine, had the same problem with the instructions. Although the wiring harness is a little different, the disassembly of all the covering is the same and of course the battery has been moved to the Frunk.
http://www.spydertalk.com/forums/top...iler+%2Bwiring
These are very good instructions, I used them to install my hitch because I thought BRP's instructions was not that great.
Bob
