Results 1 to 7 of 7
    Jan 2013
    Las vegas
    Default Squared Away Alignment
    Today both my wife and myself had both our 2014 RT Limited aligned by Squared Away a Las Vegas vendor. Prior to the alignment her RT was drifting to the left and mine was going to the right. After the alignment it went straight which is what it was supposed to do. Having the alignment makes a world of difference. I highly recommend this to anyone in the surrounding states.
    South Carolina
    Default Alignment
    I have an alignment scheduled in 2 weeks on my 2013 RTS SM 5 I bought in January. I sure hope it helps or I will be trading it on another HD.
    Jul 2010
    Las Vegas, NV
    Thank you for the kind words. Glad to help, and happy it made a difference in your bikes!
    Joe Meyer
    Dec 2013
    Las Vegas
    Default How Much?
    Mine is only at a 1000 miles but drifting pretty bad to the right now. Is there any advantage to waiting for more miles before the alignment? Also, how much for the service?
    Thanks!
    Jul 2010
    Las Vegas, NV
    Quote Originally Posted by LVSpyder View Post
    Thanks!
    No, it won't get better. In fact, the sooner you bring it over, the longer your tires will last! We do them here for $120, and if you are active or retired military, we have a discount. Call Ann for an appointment. Takes about an hour. If it does not need it, it is free!
    Joe Meyer
    Aug 2013
    Northern California
    Default Silly Question
    If you have the Spyder Laser Aligned and you later put on new tires, do you have to get it aligned again? Also curious if you have set a date to come to Northern California in March?
    Jul 2010
    Las Vegas, NV
    Quote Originally Posted by Pirate looks at -- View Post
    Same size replacement tires, should not need another alignment. I will check it for you, free. If it was not damaged or adjusted , should be ok.
    Yes, we are in San Fransisco this weekend! Call Ann for an appointment! Saturday has openings!
    Joe Meyer
