modifications
If I install aftermarket exaust would that void warranty?
also where can I buy license plate relocate kit
I would like to remove the rear fender and looked on internet but not sure if anyone sells for spyders
thanks
You will not void the warranty by replacing the exhaust. The only way to void the warranty is to not have the Spyder serviced. If you replace a part with an aftermarket part the warranty will not cover that part (obviously). If you replace a part and it damages another part it will not be covered. However your entire warranty will not be void.
'' RIDE -WINE - DINE LIKE ITS YOUR LAST DAY- SO MAKE IT COUNT DAILY''
2013 ram 1500 RT HEMI 405 Hp
2012 spyder RT + cat-bypass, mod muffler, PCV + auto tune, HID headlight n foggers, seal floorboards, LED's every where, supercharged ..not!
2012 Fiat c500 conv.
thanks
any idea where I can find license plate relocating bracket?
