Results 1 to 10 of 10
    Mar 2013
    Maumelle, AR
    Default What carries over from the 2013 RTL to the 2014 RTL?
    Does anyone know if an aftermarket seat (Ultimate) for a 2013 RT fits on the new 2014 RT? How about Bajaron's sway bar?
    I'm just kicking things around.
    2020 RT Limited , Chalk
    Default Don't know..!!
    you could check with the folks on the home page that deal with them. Don't know if anyone has reached the point of changing things out already seeing as many have them but can't ryde them...egine, suspension, and electrical seem to be the big changes on the RT. Rest assured they will have those items soon if not already...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Jun 2010
    Las Vegas
    The sway bar is a definite yes and it is my understanding that the seats also fit
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Very good question.
    Yes, and ditto!
    Bryant, Arkansas
    If you are going from the same model to the same model.
    Sway bar = Check With Baja Ron, you may need to add the collars.
    Seat = Yes
    BRP adjustable Air Vents = Yes
    NBV Highway Pegs = Yes
    Bump Skid = No (new Design)
    Cup Holders = Yes
    Floorboards = Yes
    WindShields = Yes
    IPS Key Holder= Yes
    Trailer Hitch = Yes
    Wiring Module = ???
    Drivers Back Rest = Probably Not
    Rear Rack = Yes
    did i miss anything??
    Girlfriend = Who Knows
    Cruzr Joe
    Nov 2012
    North Las Vegas, NV
    Joe, I think you said the adjustable wind deflectors fit with different screws too.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    May 2013
    Edmonton Alberta, Canada
    I know Ron made some adjustments to the sway bar for the added weight of the new engine.
    2014 RT-Ltd , Cognac
    Bryant, Arkansas
    You are correct, but i think i used the wrong screws the first time, the screws that come with them are the correct ones.
    Cruzr Joe
    The air deflectors transplant just fine... if you use the proper screws!
