Gage wires
I searhed and couldn't find anthing, which may mean this is stupid question, but that;s how you learn.
Can the analog gage leads be used to power anthing besides other gages? Such as a GPS or satelite radio, or LEDs.
Ed
They told me not to give up on my dreams, so I went back to sleep.
Champagne 2017 RTS SE6
Quantum Blue 2012 RTS-SE5 "Bluebell, Bell for short" - Traded 09/2017
I have powered my Zumo GPS on 2010 RT with the fuel gauge power/ground leads for over 30,000 miles now with no ill effects.
2015 Intense Red Pearl RTS SE6 - Laser Alignment by Precisyon Trac, Tri-Axis handle bars, ? to be determined.
2014 XLR Viper 305V14 Toyhauler (Home)
2015 Ram 3500HD Crew Cab
Former Spyders
2010 Blue RT A&C SE5 53K plus miles - never left us stranded!
2013 Pure Magnesium Metallic ST SE5 11K plus miles - never left us stranded!
Should work..!!
just make sure to find what you need...constant power or keyed power and keep the power to power ground to ground connections. If it is too much you will blow a fuse and may need a more direct source...
2012 RS sm5
Motorbike Professor
I don't recommend it, because the waires are so small and the amp capacity is very limited, but they would power an electronic device like a GPS. Be sure to separately fuse the new circuit after the point of connection.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
While it can be done I also don't think its a good idea. Ever since the obd2 CAN protocol in 08' I've always wired aftermarket items totally isolated from the OEM electronics.
Modern day vehicle electronics have changed so much from the simple positive/negative connections that most of us are used to.
