break in
as a rule you should never ride at the same speed and rpm for long periods of time, other than that go for it. i have done this for years with out a problem
NO BIKE AT THIS TIME
Have to agree..!!
keep from crusing at a constant speed and rpm. Move through the gears ryde the different highways and byways so pretty much ryde it like your going to after you break her in with that one exception. Fastest way to get mileage is to get on the freeway and cruise but the least fun...enjoy your new ryde..!!
2012 RS sm5
Go on the ride with us on Sat the 15th and we will have it broken in by the time we return..
220,000 Mile Spyder Ryder, IBA Premier member #59352, Saddlesore 1000 (11), Bun Burner 1500 (3), Saddlesore 2000 (2), Bun Burner Gold, MILEEATER SILVER
'14 Engine Break In Question
Can't make the 15th, Doc, but if everything goes like written in the brochures we should see you @ CFPS Sat. Mar. 1
Ron
Avoid prolonged riding? Oh no, I don't think I can do that.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
If you don't have diff type roads conducive to varying the rpm, use the gears to do it.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
2014 Spyder RT-S breaking in awesome 1330 motor
http://www.mototuneusa.com/break_in_secrets.htm
I have used this method on all my many motorcycles over the years. Oil rings seal well, good compression, strong motors.
Rolling off throttle letting de-compression slow you down is what seats the oil rings.
Enjoy your new 1330 motor/smooth shifting trans RT!!!
My 2014 RT-S SE6 is broke in, strong torque pulling throught the smooth shifting gears! Jim
SpyderLovers Sponsor
The way they build engines these days, the materials and machining plus run in at the factory, there isn't nearly as much break-in care needed as in the old days. Especially with water cooled engines.
Main thing is to not let it sit idling to warm up. Very bad for any engine but worse on a new engine with more blow-by. Start it, let it idle about 1 minute at most, and then ride it easy until it gets to operating temperature. That will probably make more difference in longevity and proper seating than most anything else.
When is it Enough?
With 400 miles on mine now and having varied the RPM's using the gears, I'm assuming the rings are sufficiently "seated" and I can ease off the varying speeds. I know there are other elements of the motor that need mating also, but believe the rings to be the most critical part of a break in.
Is this basically true or should I keep working the RPM's?
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Banged Up Member
Was that your "purdy" 2014 Cognac spyder I saw at Seminole Power Sports yesterday (Thursday)??? Lookin good Ron.
Chris
I'd say you're right on this. Start riding it harder. Cylinder pressure is what pushes the wrings against the cylinder walls and will help finish the break-in process. I'd say you can pretty much ride it whatever way you like.
I also think lugging a new engine (even if they are OK with it) is not a good idea. You get back into the excessive blow-by possibility when you lug a new motor. This contaminates your oil and can decrease lubrication and increase wear.
Thanks. Quite an interesting article that makes sense.
