how many
of us have forgotten to put the kickstand down when getting gas or getting off the bike, 2 wheels
MOgang Member
Joy
Very Happy Ryder... '09 Phantom and a '15 F3-S
If you don't slow down, they can't catch you..
If you don't give up, they can't win.
What a long strange journey its been.
If you use Fuely to track you fuel consumption it will provide an over all average. I love to ride my bike.. I mean ride fast and hard so I have dropped my 2011 near 20, my best was 32 if I recall. My over average is 27 which is a mix of every thing, trailer, 2 up, fast twisties and scenic drives. I am looking forward to see what my 2014 will do over time but I know it will be better, not that I was unhappy with 27 mpg either.
Originally Posted by caw001
I love all the speculation due to lack of detail! Sorry about that....
I have to say I did not start paying attention to the statistics until my 3rd fill (one at the dealer, and two myself).
Both times I filled up It took "about" 4.5 gallons (didn't pay attention). The first time was at 98 mi. (this one got my attention). The second was somewhere around 200. This was all in town stop and go driving, and being the owner of a brand new Spyder I have to admit I may have been a little heavy throttled at times as I have been ryding atop a magnificent beast.
The third time I filled it I decided I needed to figure out how to reset the trip meters so I could get the real facts and I did just that. I did some freeway driving to and from work and I am currently at 335 total miles and a 1/4 of a tank as it sits level in my garage. That's about 130 miles on 3/4 of a tank. So if you do the math on that, things are not looking so bad. I will take her for a spin tomorrow and refill again to get an accurate mileage burn.
I also have never waited to see the fuel light come on (quite frankly, didn't know there was one). Once I cross the black 1/4 tank marker I have been refilling because I just felt like It was going to burn that last bit of gas faster than I expected.
Yep its new, there is learning to be had. I've been trying the eco mode, but it seems that it always wants me in 6th gear. In stop and go driving that's not always possible to make that stretch and feel like you are doing the motor any justice.
We'll see how things go over the next couple tanks as the newness wears off. Does the "I just want to grab the throttle and GO!!!" feeling ever go away? I sure hope not...
This was posted in #18 and may have got lost in the shuffle.
"The recommendation to fill the same way each time is right on. The most I have ever put in a tank was 5.8 gallons and that was at 185 miles on the tank. (31.8 mpg). When filling I always run the gas almost up to the O ring but do not fill beyond that point. I zero the trip meter and am then ready for the next go around. I calculate mpg by taking miles driven on the trip meter divided by number of gallons put in. I go to the nearest 10th on mileage and gallons. I use the digital gas gauge and the fill up lights usually come on between 140 and 150 miles on the trip meter.
If you are already following this procedure, then there may be something wrong with the . Based on what you have said, I recommend the above procedure for the next couple tanks or so."
The use of the fuel gauge 1/4 left indicator is probably not the most accurate way to determine remaining fuel in the tank.
just looked up
what i had posted b4 about my gas mileage and i am averaging 27 MPG
I've heard and read many times that the fuel mileage will go up after breakin... So when exactly does the fuel mileage begin to get a little better?
Mine is not fully broken in, but I've got 300mi on my 2014 RTS and am averaging just a hair over 100mi per tank... PER TANK! Not good, not even bad, but freaking horrible...
Something is seriously wrong with your individual bike if that is the case.. I have ridden close to 5000 miles with the 2014 RT LTD and i get 200 miles a tank routinely
Originally Posted by BRPcare
Hello caw001,
You should definitely be getting better mileage than that. Please contact me via PM here or email at brp.care@brp.com ; I'd like to get more details (ie how much gas you are putting in the vehicle, driving style, etc) in order to solve this for you.
I don't mean to hijack this thread OR divert it from it's original topic of average MPG on 2014's, but I have to say that I am impressed with the speed at which a BRP representative stepped in.
Not that it's any of my business, but i'd love to know what the conversation between the OP and BRP consisted of...not verbatim, just the gist of the conversation. Might entail some useful nuggets of info for other 2014 owners.
Originally Posted by Yazz
Did that a couple times when wasps flew down the back of my jacket.
Another is leaving your bike parked in 1st gear, then starting it up without holding in the clutch.
When I had to switch back to the 2011 SM last week I couldn't figure out how to start it. Forgot to pull in the clutch.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Gee...
That almost sounds like a good reason, to pop for the, "ESSIE"!
No, it just means I'm getting old and forgetful.
2010 RT- 622
Originally Posted by Hawk
Also keep in mind as someone stated. If you put the nozzle all the way in and stop when it clicks the first time, your not totally filling the tank. My method is to put it all the way in, let it go until it stops, then pull the handle out until there is about 2 inches of nozzle in the neck of the tank. Slowly fill it until I see the fuel just barely starts to splash out of the vent holes.
I did lift the nozzle out to make sure it was full...
2012 Spyder RT milage
Originally Posted by SMOKEYG
I HAVE AN 2012 SPYDER RT & I GET ABOUT A 100 MILES PER TANK AS WELL??? AND ITS WORST AT HIGHER SPEEDS ON THE HIGHWAY
I have a little over 9.5K mi. and get 0nly 28+ MPG
We have around 800 miles on our 2014 RT and so far have been averaging a little over 34 mpg riding two up.
Update: So I'm averaging about 28mpg on my Spyder now. 2014... Still not great. Hoping it gets better. Most of my driving is freeway driving, so I would think it would be better....
- Chris
- Chris
Well at least that is more inline of what you should get. I am getting a little more, some even more. Freeway driving is not the best for fuel economy (you would think it would be, like a car). Unless your driving 55 on the freeway, that is. If your like me and ride 80 + or - a few MPH, you will probably only get around 28-32. Also depends on windshield a bit. If you keep it all the way up, less MPG. I try to lower mine to the point the wind is just going over my head. Its only about an inch or two, but it changes the angle slightly of the windshield from all the way up.
Look at my Fuelly below. The last 5 fuel ups were mostly interstate going to Daytona and back. I got 26 one tank.
Originally Posted by SpyderAnn01
I had asked about the foot on the brake and that wasn't it but I just checked back and it looks like it was the kill switch
Been there, done that!
Update on milage of my 2012 RT now with 15350 mi
Thanks for all the input, I did good milage calculations from tank to tank and then it wasn't good. However now I'm 30 to 34, except at the 75 to 80 open road down to 22 to 24!
started to add the enzyme for the alcohol contant, and of course hi test. I do trips and around town. thanks for your help, Mike
Definitely something wrong here! On our ride yesterday, we got - get ready - 48 MPG!!
Now here's what I've noticed:
For Spyderquest earlier this month it was rainy and very windy on our way to the host hotel. We were on the highway moving at about 70-75 MPH. We were also pulling the trailer. You could actually feel the wind slowing down the Spyder (we have a 2014 RT-L). We got 31 MPG. Same thing on the way back home. Heavy winds, highway speeds over 65 MPH, and the trailer.
The weekend after Spyderquest we went camping in Maine. Same thing: Rain, heavy winds, highway over 65....again....31MPG.
This past weekend's trip was all back roads. Long easy cruising at speeds varying between 40 and only rarely up to 60. Not too many lights...just long country roads. We did the entire 217.4 mile trip on 4.5 gallons. No lie.
As you can see there are a lot of variables that can affect mileage. If your travel profile looks more like our "lousy" mileage, that could be the problem. If not, then I'd suspect something mechanical maybe.
We have a little over 3,000 miles on our RT-L so just out of break in period. Before this our high mileage mark (same exact route as the 48 MPG trip this weekend) was 41MPG.
Hope this helps a little
crappy mileage
My spyder just went thru 10,000kms. I actually think the mileage got worse after the whole filter and oil service. I used to be able to ride for about 220 kms on a tank when I went to my ranch on highway at speeds of 150 to 180 km/h . The ranch is 102 kms from the city. Now I get to the ranch with 1/4 left in the tank. I was lookin forward to the mileage getting better but got the contrary..
rain helps
By the way, I noticed when I ride it in rain the mileage gets better. I think the water cools down the bike and that helps. Because when the bike gets hot on high speeds , the bike starts smelling like gas.
My last tank was 36.47 (36 mpg). Normal, 40-41. I am attributing the lower mileage to the colder temperatures outside. My car always gets less mpg in the winter. Another possibility, winter grade gas?
My driving techniques and my fill-up procedure has not changed.
milage 2013 st limited
fill to same level all the time, then devide miles traveled by the gallons.
I drive it fast and dont care about milage. i average 30mpg in first 2k miles.
carl
SpyderLovers Sponsor
What weight oil did they use? Regular, blended or synthetic? It can make a difference.
