That is the one that I use. J. D.
2016 F3T Magnesium Metalic : Smooth Spyder Dual Backrest, Lamonster LED Head lights and Fog lights
I have too and it works great.
jack points
I have a two-wheeler friend that has one of these and I need to replace the plugs, wires, and exhaust o-rings on my bike. Where, underneath the Spyder RS, is the best place to lift the front end?
2010 Full Moon Silver RS SE5
SpyderLovers Sponsor
jack
I have had one for about 10 years got it at Sears... works great
On the frame or A arms
Motorbike Professor
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Yup! Grab the beast by the belly!
I use it!
I use this jack...works great. Good value for the $'s. Inpsect the contents. I was lucky, had all the parts to assemble it. However, they were loose in the box and could have easily got lost....check your box to make sure it doesn't have holes or other ways for the parts to fall out....
Happy and safe rydin'
2014 Spyder RT Limited - January 2014, Cognac/Black Seat, #958, born on 1-8-14
Web Runner;
i go straight in at the front or side-ways at mid-ship... depending on what your needs are... at mid-ship, i can get all 3 wheels off the floor, but understand that when lifting like this, it is best not to get too comfortable under your SPYD3R, because it isn't the most stable and could fall over... when lifting the front, i ALWAYS put the emergency brake on, and a piece of 2 X 4 to lock the read wheel... whatever you do, do it safely....
Just bought one at Sears its a Craftsman looks like the one Harbor Freight for the same price on line other than mines Red. Great jack for the money
I just picked up this exact jack at Harbor Frieght for $79.
Oil change this weekend and I will report how well it worked.
Bob
2011 RT-S SM5 - Black
The HF jacks work good. With the yellow ones just don't be shy about stomping on the pedal fully to lower it slow and smooth.
Sent from my Venue 8 3830 using Tapatalk
Originally Posted by SPYD3R
Web Runner;
Thanks SPYD3R!
Is there any benefit to the aluminum jacks that run $175 at HF and Sears? Other than lighter weight and the opportunity to spend more money?
Ordered aluminum one ( min hight 4.5 in to 19 in) steel was min hight 5.5 in . Used coupon code 28177679 , got it for $134.00
Do you have a link to where we can find it.
Searched harbor freight coupon on google and picked the best free one. I think you can use this one , try it ):
Cool... Thanks!
Web Runner;
Jack stands are your friend.
Current Bikes:
2018 BMW K1600 B
2012 Spyder RT LTD - Sold
2003 HD VRSCA (VROD)
I had my old lift set up with a set of nylon tie-down straps, that I'd use to lash the bike to it solidly...
Picked one up at Harbor Freight tonight with that coupon code. Thanks!!
Me too
Excellent jack for the money - But add a pair ramps
Hey SPYD3RLOVERS..... HARBOR FREIGHT has the 1500 lb. Capacity ATV/Motorcycle Lift
http://www.harborfreight.com/a-b-hp100912.html?utm_expid=14208462-11&utm_referrer=http%3A%2F%2Fwww.google.com%2Furl% 3Fsa%3Dt%26rct%3Dj%26q%3Dharbor%2520freight%26sour ce%3Dweb%26cd%3D1%26sqi%3D2%26ved%3D0CDAQFjAA%26ur l%3Dhttp%253A%252F%252Fwww.harborfreight.com%252F% 26ei%3DFGYMUc6pKISW8gS7i4CoBg%26usg%3DAFQjCNGrimdt BnI6M-4JMZ1T3CN8GfHTFw%26bvm%3Dbv.41867550%2Cd.eWU
make sure you OPEN the link, and PRINT the COUPON... it'll be $79.99, without the coupon, it's $99.99, or even $149.99..... if there is not a HF in your area, you can call and order it, by using the coupon code number.....
GOOD LUCK guys n gals....
The HB ATV lift is a great jack for the money.
However, I HIGHLY recommend you add some HB plastic car ramps to you tool inventory. Then you pick up your with the jack and then sit it down on your ramps. What I do pick up my , place the ramps under the front wheels and inverted cinder block under the rear wheel then set the bike down on them. I pull my jack out and I can get to any place underneath my bike. I just reverse the process when I am finished.
- Mike
