Results 1 to 19 of 19
    Stevensville, MT
    Default tric LED full size brake pedal
    Stephen Allan's full Size Brake pedal was ordered on 01/18, and was delivered on 01/24. Great service! It included the necessary instructions and it installed in minutes, and answers the serious issue of having to "hunt" for the little , OEM brake pedal on a quick stop. Kudos to Steve.
    I have the full size pedal on both 's and would not be without them. A great accessory.
    That's an addition that goes on the bike; authorized, or not!
    Feb 2012
    Lake Havasu City,Arizona
    Default Stephen Allan'd TRIC Full Size Break Pedal
    Quote Originally Posted by CapNCrunch View Post
    This really caught my attention,who?what? where? can I find out some more info about this brake pedal? Sounds just like what I'm looking for.......
    http://tricplate.com/
    It's in here...
    Here's a comparison of the OEM, and their brake pedalsBrake Pedal Comparison.jpg...
    Default Same day delivery..!!
    but only cause made a couple and put one on the brake and one on the park brake (RS model)
    20140126_153111.jpg brake 20140126_153126.jpg park brake..
    ​2012 RS sm5
    Very Active Member Purple Guy's Avatar
    May 2013
    Edmonton Alberta, Canada
    It's in here...
    Thanks for the pics & link Bob!
    2014 RT-Ltd , Cognac
    Bryant, Arkansas
    I have one on my 2014 and it makes a world of difference.
    Safety item, not a farkle. (this is for Bob Denman so he can tell his wife it must be true because he seen it on the internet.
    Cruzr Joe
    Default Thanks, Joe!!
    GOS member (Girls On Spyders) BigLegMac's Avatar
    May 2012
    Chicago Heights,Il
    Default brake pedal for 2014 RTS
    Cruzr Joe can you pm me and tell me which brake pedal you purchased from tricled because it says its not compatible to 2013s with the floor boards.
    Bryant, Arkansas
    Quote Originally Posted by BigLegMac View Post
    i am putting this up here for everyone to see, i bought the brake pedal when i had a 2012, so that warning was not up there, on my 12 and 13 RT's i used the seal pup floorboards and the brake pedal had an aluminum spacer to raise it up. on my 14 i put it on with the spacer but it raised the pedal way too high, so i removed the spacer and it works fine, and so far i have had no trouble with it. BUT, now that i know that there is a warning on it I will take a closer look at it to see if I can find any potential problems.
    Anyone else out there care to chime in??? Always looking for good information.
    Cruzr Joe
    Very Active Member Hawk's Avatar
    May 2011
    Dacula, GA
    I am guessing when an emergency stop, it could hinder the petal from going all the way down, due to it sticking out further and hitting the floorboard??
    Bryant, Arkansas
    Quote Originally Posted by Hawk View Post
    I will take a better look today when I get home from work.
    Cruzr Joe
    That would be my guess...
    May 2013
    On the stock floorboards, don't they snap down in a emergency stop situation?
    Bryant, Arkansas
    Quote Originally Posted by Purple Guy View Post
    Good Question, anybody know??
    Cruzr Joe
    May 2011
    Dacula, GA
    Cruzr Joe
    They do, but if the brake pedal is still on top of those (with the larger pedal), it will still not travel as far down as the stock (I assume).
    happy old fart stillriding's Avatar
    Apr 2010
    Elyria, OH
    The owner's manual says it does.
    My mention of the extended brake pedal is on a 2010 and 2011 RT. I have seal floorboards on mine. To avoid bottoming out on the boards with the use of the extender, I added a "riser" under the extended pedal. Seal has supplied these with his floorboard kits.
    I know that the set up is different on the new 2014's with their factory floorboards. Anyone using an extender for the brake pedal will have to give us some beta tester knowledge. At least, its not a really expensive issue. I read that it is more of a reach with the 2014's to get to the brake pedal than we are accustomed to, so once again, a riser might not be a good idea in this case.
