Page 1 of 2 12 LastLast
Results 1 to 25 of 35
    Active Member Nils888's Avatar
    Santa Paula, Ca
    Default New owner Questions on 2014 RTS
    OK. I have 300 miles on the New RTS. I feel a shake in the handle bars above 60 MPH. Are the Spyders sensitive to tire balance??
    I jacked the front end up and spun each front wheel. The right side looked pretty good. Left side did not look so round. Kinda looked like it had
    a flat spot. I decided to go out and get the tires warmed up and recheck the tires. They both looked much better after warming up. I guess the flat spot when they sit over night. I check the tire pressure in the fronts it was 20psi.
    Are the factory tires a good tire???? Or should I be looking for a better quality tire???
    Mar 2012
    NJ
    No more sensitive than anything else. Sounds like you got one where they either didn't balance them or have a bad tire\wheel.
    I had this issue when i got screwed changing wheels. The tire shop just didnt balance them when switching things over to my new wheels. I only noticed the vibe at 60+ so it took a few days to realize. When it starts to vibrate look at your fenders. Which one looks like its going to fall off?
    Santa Paula, Ca
    The left fender shakes more than the right.
    Mar 2012
    NJ
    Yea, sounds like balance. Head back to the dealer, they should be able to get it taken care of.
    Jun 2010
    Las Vegas
    I have noticed a "harmonic vibration" on the 2014 RT at speeds of 75 and up. Others have reported the same thing. I didn't look to see if the tires have a lot of weights on them but they are at equal pressure
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Santa Paula, Ca
    My right tire has a 5 inch long strip of weight. the left has one small weight.
    Default Have to agree..!!
    mounting and balancing is important and can cause these problems. Good idea to take it to the dealer and have them check it out. Usually if there are a lot of weights the tire was mounted wrong. Many times when the tire is on the rim but not seated it can move around on the rim..
    ​2012 RS sm5
    Santa Paula, Ca
    I will check tomorrow.
    Banged Up Member MouthPiece's Avatar
    Dec 2009
    Sanford, Florida
    Although probably not the answer to your problem, make sure you get a laser alignment.
    Chris
    Santa Paula, Ca
    Going to have the alignment done by the Squared away folks when they out here in February.
    I am going to get the tire balance checked tomorrow.
    2014 RTS SE6 White
    BajaRon Swaybar
    Elka front shocks supplied by Pitbull Power sports.
    Aligned By Squared Away
    Smooth Spyder belt tensioner
    Sprderpops Bump skid
    BRP TRI AXSIS Handle bars
    Luggage rack
    2013 STS SE5 Circuit Yellow. The Jenny Mobile!
    Mar 2012
    NJ
    Are we going to see a motec powered RT in the future?
    Active Member zbunker's Avatar
    Dec 2011
    Altamonte Spgs, FL
    Default Front End Issue
    Quote Originally Posted by SpyderAnn01 View Post
    Hi,
    You mention harmonic vibration as a symptom. I don't know, but doesn't that sound more like a belt tension issue? Although, sounds kind of early for the belt on a '14 to stretch, no?
    Ron
    Santa Paula, Ca
    Quote Originally Posted by DrewNJ View Post
    I am trying to keep from going there! The wife would kill me if I put a Motec ECU on our brand new toy . But the spyders have the same ECU as the watercraft. I can see it now!!! 9000 rpm turbo.
    2014 RTS SE6 White
    BajaRon Swaybar
    Luggage rack
    Mar 2012
    NJ
    Quote Originally Posted by Nils888 View Post
    Hahaha......Its in your blood! And nobody would be able to do it any better than you! You know that.
    Heck, its just an over glorified Spark ace motor, right....haha
    Nov 2013
    Blue Springs, Mo.
    Default Tire balance
    I had a similar problem with my RT. Had the tires balanced three times ; still vibrated and shook. Turned out to be a bad tire. My dealer promptly changed it and now all is good.
    Santa Paula, Ca
    It would be cool to see if the put the ACE engine in the RS. Then I would interested.
    2014 RTS SE6 White
    BajaRon Swaybar
    Luggage rack
    Santa Paula, Ca
    Quote Originally Posted by Spyderdale View Post
    I have been looking for after market tires. All I have found in the states so far is Federal 595 EVO 165/55/15. Kumho has tires. But only in Japan.
    2014 RTS SE6 White
    BajaRon Swaybar
    Luggage rack
    Tire pressures
    Tire balance
    Alignment
    Tire conditions (Could you have a busted belt within it?)
    That's about where your choices lie. Eliminate them; one at a t ime...
    Good Luck!
    Santa Paula, Ca
    Tire pressures
    Tire balance
    Alignment
    Good Luck!
    I am on it It would be a bummer if the tire or tires where bad. I have 300 miles on them so far.
    2014 RTS SE6 White
    BajaRon Swaybar
    Luggage rack
    Bryant, Arkansas
    20 PSI might be a little too high on pressure, i ride at 16.5 - 17 Lbs, but be sure both tires are equally pressured. (some folks like higher pressure but more pressure means more Bounce.
    Cruzr Joe
    Santa Paula, Ca
    Cruzr Joe
    Thanks Joe. I will try the lower pressure.
    2014 RTS SE6 White
    BajaRon Swaybar
    Luggage rack
    I forgot one... Check to make sure that the tires are seated properly on the rims too!
    It is looking like a pre delivery drive at highway speeds is in order--just to be sure.
    Santa Paula, Ca
    I went over to the tire shop with my wheels ant tires. The balance was not to far off. The bad part is the right wheel does not spin strait. Both tires are not very round.
    2014 RTS SE6 White
    BajaRon Swaybar
    Luggage rack
    It seems to be that the tires may be the culprit. With the new lower profile tires, did BRP get a batch of "bad" ones?
