Results 1 to 13 of 13
    Active Member mustangbob's Avatar
    Jun 2013
    jackson, michigan, USA
    Default Christmas gifts installed
    DSCF0020.jpgDSCF0021.jpgDSCF0025.jpgDSCF0026.jpg mud flap and fender tip lights, other pics are home made heat deflector, hope it helps this summer.
    2012 RTS SE5, GT stripes, belt guard, hmt brake light, lower vent heat deflector, driver foot boards, Corbin seat, RH vent covers
    Very Active Member samewok's Avatar
    Oct 2011
    Jacksonville,Ar
    Why did you but the lights on the back of the frenders?
    4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
    15 rt , yes Black
    Very nice farkles. You did good!
    Jun 2013
    Default lights
    Quote Originally Posted by samewok View Post
    Their from custom dynamics, they work as running light and blinkers, any extra lights that help get you noticed on the road is a good thing
    Jan 2013
    lancater ohio
    Looks great
    Active Member Mowerman's Avatar
    Apr 2010
    Altoona, Iowa
    Quote Originally Posted by mustangbob View Post
    What did you use to make your heat deflector? Any more pics of it? Looks good. I would like to make one for my RT
    Proud Owner of a 2017 f3t
    Default Nicely done..!!
    you should be proud...congrats now on to the next mod...!!
    ​2012 RS sm5
    I can't wait to see what you cook up next!
    Jun 2013
    Default heat
    Quote Originally Posted by Mowerman View Post
    its a piece of HDPE plastic, 12$ for a 2x3' piece. I just made a pattern, mark where the bend is, flattened the pattern, trace and cut on band saw, heat up where bend marks are and use edge of bench for straight edge. I also made a rear mud flap.
    Very Active Member Jim&Teresa's Avatar
    Jun 2013
    Woodbury, MN
    Default Looks Great
    Great job....your bike looks great!
    Happy and safe rydin'
    2014 Spyder RT Limited - January 2014, Cognac/Black Seat, #958, born on 1-8-14
    2014 RT Limited , Cognac
    May 2012
    Beaumont, TX
    Looks good! Santa brought you some good stuff!
    2012 Can Am spyder RT: RED! Widow pegs with kuraykyn mounts, ride on sealant in all tires, stebel nautilus air horn, ELKA shocks, Ultimate saddle & driver backrest, digital clock & oil pressure gauge (replaced OEM gauges), xenon lights all around, Custom dynamics brake light, SEAL pup floor boards, Baja ron sway bar, chain guard, bump skid & block off plate (all from spyderpops), Baker air wings, Custom Dynamics turn signals & fender lights, custom paint job (hot rod flames)
    GOS member (Girls On Spyders) Spyder Smyles's Avatar
    Dec 2012
    Aberdeen, MD
    Love the lights on the fender, are they hard to install?
    CURRENT: 2015 Yellow RT-S SE6 "Smiling All the Way"
    CB, Satelite Radio, BRP Vented Windshield, BRP Adjustable Handwings, Cup Holder, EZ Pass Holder, Side Saddle Cargo Nets, Smiley Face FLO, Smiley Flower Face Decals, Tri Axel Handlebar's, Corbin Heated Seat, Baker Built Upper/Lower Air Wings, BumpSkid, High Third Brake/Running Light, Brake/Running Light/Turn Signal License Plate, Turn Signals in Mirrors.
    PAST: 2013 Yellow RT-S SE5 - Loaded with lots of goodies.
    Jun 2013
    Default not bad
    Quote Originally Posted by Spyder Smyles View Post
    you have to remove tires, fenders, run a wire up to the mirror for blinker, if you take your time and pay attention its ok.
