Results 1 to 16 of 16
    Very Active Member bluestratos's Avatar
    Jun 2011
    Lynden, WA
    Default New Digital Water Temp Gauge Install
    I just purchased a Innovative Motor Sports water temp gauge to match the Air Fuel ratio gauge I am installing. The water temp is both Volts and Water temp so I need to install the water temp sensor which has 1/8 PT external threads. What have others done or recommend for this install? Is there a good location already existing to install this or, if not how else do I get it done?
    Thanks for any help,
    Randy
    Jun 2011
    Lynden, WA
    Anyone?
    Mar 2012
    NJ
    Just like the AFR gauge, you are in uncharted waters......
    Keep us posted on how you mount it all up.
    Doug
    Sent from my DROID using Tapatalk
    Jun 2011
    Lynden, WA
    Lol... I think there is a least one member that did this before, hopefully he or she reads this. Mean while I will keep searching.
    Registered Users TuckMiddle's Avatar
    Sep 2011
    Waleska, GA
    Have you tried Fastenal, or what the proper spelling.?
    They have stores all over and might have the right T, if there's room for it, on the radiator. I can't find the name of the outfit in FL where I got a special T for the oil pressure sending unit and original warning light sender. It's in the forum someplace.
    Where did you find the combo gauge- that's a great idea, is it digital?
    Tuck
    Sep 2011
    Waleska, GA
    Sorry, I see it's digital. Got a pic or a site to go to?
    Very Active Member cjackg's Avatar
    Chattanooga TN
    What type of AFR gauge are you installing, narrow band or wide band? Are you adding a new O2 sensor for the AFR gauge?
    The reports I have read indicate that using a narrow band gauge with the existing oem O2 sensor does not give meaningful readings, but some others on here have done this and may have comments.....
    Mar 2012
    NJ
    Don't waste your time with a narrowband gauge. It just isn't accurate/consistent enough to give a good reading.
    The innovate mtx-l is a nice, inexpensive wideband. It also has a narrowband output to wire into the ecu connection if desired.
    I like the idea of also having a coolant temp gauge.
    Just an idea...What about putting the sensor in the radiator drain?? Just have to be super careful taking the plug out as they have been known to break the plug threads.....
    Mar 2008
    Hesston, PA
    Quote Originally Posted by bluestratos View Post
    Randy
    Below is a T connection we use on our Can-am V twin ATV's...
    http://www.jtatv.com/Coolant_Gauge_I...ee_p/t-100.htm
    Jun 2011
    Lynden, WA
    The gauges are from innovative motor sports and yes, I am installing the wide band gauge O2 sensors just before the muffler, one for the gauge an done for the Power Commander Auto Tune (I have not cat now). I finally worked out that the radiator temperature sender adapter I needed is a 28mm. base on Lammont's post where he did a similar mod so it is ordered and on it's way.
    Right now I have a narrow band gauge temporally installed and the readings require some interpretation to be kind, lol... But, with a bit of practice I can judge that I am on the rich side right now at idle and wide open, the rest of the time it is spot on but a bit rich. Every so often it goes a bit lean when I roll on the throttle a bit aggressively but not wide open.
    Very Active Member jwulf74's Avatar
    Jul 2013
    Piedmont, SD (Black Hills)
    Quote Originally Posted by larryd View Post
    Any idea if that Tee is compatible with the Spyder? Looks like it needs to be installed inline in a water line and the ones on the Spydef look bigger than the largest Tee. I do like their gauge and hookup if it will work.
    2017 Can Am Commander Limited
    2012 Cadillac CTS-V Black Diamond
    2020 F3 Limited Magma Red (miss the 2011 Viper red)
    2010 RT622 - Black
    Jun 2011
    Lynden, WA
    This is the size I used:
    Upgr8 28mm Blue Water Temperature Sensor Adapter Radiator Hose 1/8 NPT Temp Gauge O.d
    Jul 2013
    Which hose did you install that on?
    2010 RT622 - Black
    Jun 2011
    Lynden, WA
    the top hose, just after the bend as it comes out of the rad.
    Jul 2013
    Thanks!
    I may give this a shot this summer. I need to find a combined water and air temp digital gauge that I like.
    2010 RT622 - Black
    E. WA
    Default coolant temp.
    I too inserted a 28mm sensor adapter in the upper radiator hose. Took out a chunk about an inch long to compensate for the adapter. I bought an Oetiker clamp tool but after trying four different size clamps, I gave up and found some spring loaded constant tension worm drive clamps. With the wide temp variations in the RT coolant system, I wanted something a little better than a plain worm drive clamp. A plain clamp will squish out the hose ends if the engine is cool when the clamp is tightened. The engine heats up and the hose gets squashed. If you tighten when warm, the hose may leak when it cools. The Oetikers have a bit of constant tension function built into the design but I couldn't make them work in that confined space.
