03-07-2014, 08:15 PM
#201
AutoTune O2 Bung Locations:
For the front header, the bung closest to the header at the very top is the OEM bung. The one closest to my hand is where I had them put the AutoTune bung. It is within the recommended 13" distance from the header and is in wide open space inside the tupperware.
The rear header was the tricky one. The bung closest to the header is the OEM bung. The bung to the right on the down tube is the AutoTune bung. This is literally the only spot that this can go. The header is wedged between the back of the engine and the gas tank. The way they are placed, the frame rail will run between them. Notice that the AutoTune bung is turned forward because if it isn't, then you won't be able to get the bodywork put back on the bike as the O2 sensor will stick out too far.
03-07-2014, 08:19 PM
#202
Here is a quick comparison between the catalytic converter and the bypass pipe. The cat weighs 12 pounds and the converter weighs 6 pounds. Remember that the cat sits right underneath the gas tank, so getting rid of it will not only reduce heat, but increase HP.
03-07-2014, 08:22 PM
#203
Total Weight Savings:
Now that I've got all of the aftermarket parts back and weighed, here are the measurements.
OEM Muffler = 20 lbs.
Akraprovic = 10 lbs.
OEM Cat = 12 lbs.
Cat Bypass = 6 lbs.
OEM Airbox = 11 lbs.
KewlMetal = 2 lbs.
Total Weight Savings = 25 lbs.
03-07-2014, 08:44 PM
#204
I always wondered if you could tap into the wires and use the oem O-2 sensors to feed both the stock and autotune systems? Do you know if the OEM O-2 sensor a wideband O-2 sensor?
Jerry
13 ST Limited F/R suspension, Corbin, GIVI top case
16 Vespa Primavera 150: Stock
16 Piaggio BV350: Suspension, braking mods in work
14 HD XL1200T: F/R suspension and brake mods; Corbin saddle and bags
09 Aprilia SC250: F/R suspension and minor brake mods
97 Honda PC800: F/R wheels, F/R suspension, and F/R brake Mods; Corbin saddle
90 CB-1: In work, long term project
89 Honda NT650: F/R suspension; Corbin saddle
03-08-2014, 08:46 AM
#205
I do not know.
I do know the answer to this one though. The PCV comes with an O2 Optimizer module that plugs in-line to the OEM O2 sensors. The AutoTune comes with its set of O2 sensors, which is why the bungs need to be welded in. Both sets of sensors are used, but not simultaneously so that they don't battle each other. Dyno Jet sent me an explanation about how it works and how it controls them. I can post it if you want.
03-10-2014, 08:01 PM
#206
Final AutoTune O2 Sensor Locations:
I got the entire exhaust system installed and thought it would be good to show the AutoTune O2 sensor locations. Here is a shot of the front cylinder header pipe. The O2 sensor to the left is the OEM O2 sensor. The sensor to the right that is standing vertical is the AutoTune O2 sensor.
If you are going with the AutoTune AT300 that has a sensor on each header pipe, then this photo shows what I think is the best / only spot for the AutoTune O2 sensor on the rear header pipe. You can see that I had it welded in at a 45 degree angle toward the front of the bike. This is the only way it will clear the engine case, parking brake and side panel once it is installed.
Here is another shot of that sensor on the rear header pipe. In the background, you can see the OEM O2 sensor. This header pipe runs between the engine and gas tank and there is literally no other spot in there where you could get the AutoTune sensor installed.
03-10-2014, 08:08 PM
#207
Here are a couple more photos of the main header pipe. I think the ceramic coating looks great and has a nice, clean look to it.
Finally, here is a shot from underneath the bike that shows the cat bypass. This was pretty tough going on as the tolerances are extremely tight. It took some finessing to get it installed. Look above the Y-pipe and you can see all of the open space that was once consumed by the catalytic converter.
The Akrapovic silencer is installed as well, but I forgot to take photos of it. I'll post those once I start putting the bodywork back on.
03-10-2014, 10:21 PM
#208
Originally Posted by stewartj239
I do not know.
Can you post them?
I am wondering if the autotune comes with the O-2 sensors because they need them and you may not have them in your exhaust system. If you can tap into the stock sensors because they are wide-band sensors, you would not need to weld on bungs; just tap into the wiring as the O-2 sensor can send the same signal to both units.
Jerry
Edit: the installation looks good, very clean. My only wish was for you to have wraped the pipes since you had them out. It would never be easier than that time.
Question: Are you going to leave the bodywork off until you get the bike running?
03-10-2014, 11:16 PM
#209
You don't wrap a ceramic coated exhaust pipe, it will overheat the metal
Can you post them?
Jerry
Ceramic coated exhaust pipes replace the hot rod wrap.
Ceramic is much better at reducing exhaust heat.
What are the major benefits of coatings?
Depending on the environment that they are used in, coatings can provide multiple benefits for the part. In most cases, coatings are used to improve thermal management and increase engine efficiency.
Jim K
03-11-2014, 07:22 AM
#210
what I am trying to understand is this;
if the factory ECU is the "master" controller but then it's signals are then sent out HSED on the factory base software and the feedback of the factory sensors does the Power Commander then take that signal and adjust it again based on its base Map and feedback from its sensors?
if this is the case how can that not result in the two not fighting each other constantly?
because the factory base Map is most likely setup differently than the Power Commander?
03-11-2014, 06:39 PM
#211
Can you post them?
Jerry
Here are the quotes from the Dyno Jet tech support:
"The Power Commander adds/subtract fuel over/under the ECU."
"The Auto-tune should be inactive in the stock closed loop range. This is done by specifying a Target AFR of zero (0) in the RPMs and throttle positions that the vehicle is in closed loop. The Target AFR tables of our Spyder RT predeveloped map files should reflect this. You should see a huge section of the Target AFR table at lower cruising RPMs and throttle positions has all zeroes (0’s) specified. This is the closed loop range in which the stock O2 sensors are active. You do not want your stock O2 sensors and your Auto-tune O2 sensors active at the same time. They can essentially “fight” with each other."
"The stock closed loop range is tuned by a combination of a blanket fuel change in the closed loop range of the fuel tables in the Power Commander map file and the O2 Optimizer settings."
"With the O2 Optimizers set to zero (0), the clean air injection system blocked off, and a blanket fuel change of 8-12 in the Power Commander map the stock closed loop RPMs and throttle positions should run at an AFR of about 13.6 – 13.9. This is what we found will give the best performance. If you wish to change the AFR in this range, you can do so with a combination of Power Commander manual fuel increases and O2 Optimizer setting modifications. I would not recommend adjusting the O2 Optimizers settings more than +/- 20, if at all."
03-11-2014, 06:42 PM
#212
spyderyderjim is correct. You do either or, not both.
Absolutely! With all of the work that was done, I may not have something hooked back up or wired correctly. I need the hear the bike and run well before the bodywork goes back on.
03-11-2014, 06:51 PM
#213
The stock ECM knows nothing about the PCV. The PCV knows everything about the stock ECM. This is nothing new. DynoJet has been around a long time and they have these setups in just about every bike made. If it didn't work, we'd know about it. You need to have some faith
Here is a good intro video:
http://www.powercommander.com/powerc....aspx#ytplayer
03-11-2014, 07:34 PM
#214
I understand the coating is for the temp control. The wrap does 2 things, temp and noise suppression. The reason for the wrap at this time is noise control as you have addressed the temp part. The cost to do the wrap is very small and will never be easier when the pipes are off.
But, at this stage, the pipes are back on, so it is a moot point.
Jerry
03-11-2014, 08:10 PM
#215
Jerry
I did research this a while back. Doing both keeps too much heat in the pipe, the wrap traps moisture and the wrap can scratch the ceramic. The general consensus was that you do either or. In addition, doing both is overkill for the Spyder, especially when I don't really have a heat issue to begin with.
03-11-2014, 08:16 PM
#216
well sorry I am skeptical about the persons selling me the goods seeing they benefit the most from that sale. That said I am keeping and open mind and interested your expereince with this setup.
I also agree to do both will cause more issues like Stewart says one or the other. I choose wrap and will share the heat gun at the rear header at idle with the Tupperware off then again once I wrap same spot. I will use the IR heat gun shoot the spot once the fan comes on then once a I wrap I will do the procedure again and share the data.
03-11-2014, 08:46 PM
#217
To put your mind at ease, why not post your questions to Dyno Jet tech support? They are fantastic and they will fully answer any question you give them about any of their products. Honestly, it is the only way that you will get the answers you're looking for.
http://www.powercommander.com/powerc...l_support.aspx
03-12-2014, 08:46 AM
#218
I talked with three different mfg of aftermarket FM systems got two that gave me the same answer and one who didn't PC seems to be a little more bold about what they can do. the other two were honest to the point that I we agreed putting there systems on the a Spyder was a waste of money.
that's why I am curious as to your'e firsthand experience. thus waiting for the report back once you have things running and some time on it.
03-12-2014, 11:43 AM
#219
Sounds good. I will definitely provide the feedback.
Just an FYI, the two main reasons why I installed a PCV / AutoTune were:
- With the heat problems reported on the 2013, I was convinced that it was due to lean jetting. Even though I did NOT experience the problems with melted parts, I know that in general, bikes run lean from the factory and I wanted that corrected.
- With all of the modifications with the airbox, cat removal and silencer, the OEM ECU would never be able to adjust to that much change.
As stated before, the PCV solved the lean / surging problems on my VFR800, so I do have some past history with it.
03-12-2014, 07:30 PM
#220
I appreciate the feedback
I am staying with the stock muffler but did remove the cat and went with the Kewl Metal air filter. just got my top vent body panels from Veritka Trikes they are out standing fit and primed finish. I dropped them off for hydrographic dipping today but they will force allot of air into the engine compartment and out the bottom past the y pipe.
03-12-2014, 08:08 PM
#221
Do you have pictures you can post? What is the installation procedure?
03-12-2014, 08:48 PM
#222
I will but it will be 3 weeks before they will be finished with the hydro graphing and clear coat. this guy I took them too is top notch and really retentive about his work but is also 2 hours south and dropped them off today. but as soon as I pick them up and get them installed I will post pics. They replace the entire upper panel under the mirror.
I am having them doing a boa pattern over black then clear coat over the top the boa pattern is subtle and the lighter actually looks a shade of brown like the trike. If this looks as good as I think then I will be doing some more panels next winter.
03-16-2014, 04:35 PM
#223
So I had a little bit of a scare yesterday. I now have everything hooked up (headers, cat bypass, Akrapovic, KewlMetal air filter, PCV, O2 Optimizer and AutoTune. Before I put the bodywork back on, I wanted to make sure it runs. Getting sick of waiting for warmer weather, I decided to pull it out into the driveway. It was 35 degrees, I turned on the ignition, hit the start button and it fired right up. All joy quickly faded when I saw the check engine light come on
After letting it run for a little while, I noticed that the temperature reading on the display was bouncing all over the place. It was going from -70 to +50 degrees. It was all over the map. I shut it down and decided to do some research. Come to find out, If the temperature sensor (AAPTS) gives incorrect readings, it will cause the check engine light to come on. I was glad to discover that as it explained what I was seeing. I then opened my shop manual for the Spyder to determine where the temp sensor resides. Much to my surprise, it resides in the frunk. When I saw that, a smile came across my face as I had not put the frunk back on yet, meaning that the temp sensor was disconnected.
Today, I got the frunk out of the basement, brought it to the garage and put it back on the bike. There are 8 connectors that needed to be hooked up and then the wire to pop the lid of the frunk. Once completed, I rolled the Spyder back out to the driveway. Today it was just 15 degrees, but I didn't care as I had to verify that the problem was resolved.
I hit the start button and it fired right up with NO check engine light. It is gone. I stopped and restarted the bike numerous times throughout the day and the light is now gone - as it should be now that the temp sensor is hooked up. I let the bike get a thorough warm up and made sure the fan kicked on. It sounds great and the throttle seems to be much more responsive than before. With the cat, stock air box and stock muffler gone, I'm sure the engine is no longer choked up.
At this point, I am extremely pleased that adding the PCV, O2 Optimizer and AutoTune is working just fine with no issues. That was my biggest fear. I'm now going to proceed with putting the bodywork back on and and getting it ready to ride
03-16-2014, 05:38 PM
#224
On a raining Sunday, I sat down and read this whole article. Very enjoyable and very imformative.
I am pleased all worked well, after you had that moment
03-16-2014, 05:47 PM
#225
Thanks for the update let us know when you get few miles on and how things are working out great job on sharing your entire adventure.
