Results 1 to 7 of 7
    Invalid Emails
    Jul 2013
    Wayne, NJ
    Default Adding LED lights for rear lighting/braking - Need help
    Can anyone offer any advice or tips for installing aftermarket LED lights for rear of ST ? I haven't done any mod's yet to a Can Am so not sure where to start or which panels I have to remove.
    Not sure if I can do rear light & brake in one?
    Thanks.
    Very Active Member bullant12's Avatar
    Oct 2010
    Somewhere out there...
    Quote Originally Posted by 333Club View Post
    Thanks.
    Check with TricLED.com on the RS/GS section, RS and ST share the same similar brake lights.
    May all your encounters with the law begin with the words: "nice trike!".[/B]
    2015 Can-Am Spyder F3-S SM-6 Can-am Red/Black SM-6 with 2010 Black RT-622 trailer (hitch in the works).
    Previously owned:
    2010 Can-Am Spyder RT SM-5
    2011 Can-Am Spyder RS-S SM-5
    2013 Can-Am Spyder RT-S SM-5
    Default Here's what you do..!!
    go online to green manuals and get/download one. If you are going to do some of your own work this is the best thing to have. The owners manual has a good deal of information as well. But for wiring diagrams etc you will need a shop manual...good luck..
    ​2012 RS sm5
    Dec 2013
    uk
    I received them they did not come with the mount necessary to mount them on my 2013 Spyder SE5 ST-S. And I guess Givi doesn't make a mount yet for my specific spyder. Does anyone have any ideas or suggestions on what I could possibly do?
    Registered Users quickster47's Avatar
    Jun 2012
    Cumberland Cove - Monterey, TN
    Quote Originally Posted by Abbysam007 View Post
    What exactly is it that you received?
    Carl
    2012 White RT Limited and 2013 Yellow ST-S Think 3 .i.
    Very Active Member JKMSPYDER's Avatar
    Dec 2012
    Murphy, NC
    Default BRAKE LIGHTS
    I don't know what you ordered but Custom Dynamics makes a 3rd brake light that is plug and play. They are a site sponsor. They also make LED's for the two brake lights on the ST's and even rear LED turn signals. All are plug and play and very easy to install.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Spyderpops Brake/Run/Turn Signal LED's
    Lamonster Garage LED Fog Lights and Headlights
    2013 ST-S retired 1/9/16 at 25,061 miles
    2015 F3S sold at 77,565 miles.
    2015 F3-S , BajaRon Plugs Can-Am Red
    May 2009
    Connecticut
    http://tricled.com/TricLed.com/ST_ST-S.html
    Check These out from TricLed (Sponsor) They are running and Brake and go under the passenger grab handle!
    OEM type connections under the rear cover!! They will give you excellent rear visibility.
    Sea Doo GTI-SE 90 Jet Ski!!
