Results 1 to 17 of 17
Thread: torx tip sizes
    washington state
    Default torx tip sizes
    What torx tip sizes is use to remove all tupperwares if needed?
    Aug 2013
    I would suggest just getting a set, usually cheaper than buying 3-4 separate. Home depot has a set that is reasonable.
    I think most of the main panels are T30. Some of the stuff around the dash area is T15. There may be an oddball or two around the bike as well.
    Jun 2011
    Near Lexington, NC
    Harbor Freight has them cheap as well.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Jun 2013
    Austin TX
    Default there in your kit
    check your kit most are in there
    Houston
    Most of the bolts holding on the Tupperware are M6 torx head bolts. These use a T27 torx. Be careful not to order a torx plus bit.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    RT-S PE#0031
    Jun 2009
    Snellville, GA USA
    This is incorrect. T30 Torx is the correct size.
    Mar 2009
    Beavercreek, Ohio
    Sears has nice bit sets, including the one with the "pin holes" needed for some panels. Mine use a handle like a screwdriver with changeable bits
    Oldmanzues
    Oct 2010
    Somewhere out there...
    Quote Originally Posted by Oldmanzues View Post
    Oldmanzues
    DO NOT REMOVE THOSE TORAX SCREWS!!! Those are not needed for removal. They are simply to hold the pegs that insert into grommets. Again DO NOT REMOVE THE SAFETY SCREWS!
    Jul 2011
    Mitchell, Ontario, Canada
    Default Get the set
    A agree with getting the set of torx bits. When I owned my 09 GS most of the bodywork was T30 with the odd screw needing T15 and T20. My ST is the same except they put in some 6mm Allen head. Really!!!! BRP whut's up with that. Torx, Allen both are fine pick one and go with it!!!
    Sorry for my short rant.
    washington state
    Quote Originally Posted by bullant12 View Post
    Torax screws, where are they?
    Houston
    Quote Originally Posted by MarkLawson View Post
    Sorry, I have both bits. While a T30 can be jammed in to force the bolt to turn, it does not fit correctly and will bugger the fastener (bugger = technical term). Been using theses exact same fastners on my Ford GT for several years and the same debate happened on that forum for a while too. The correct bit for an M6 Torx Button Head Screw is T27.....Or what ever fits when you need to remove it.
    Oct 2010
    Quote Originally Posted by jerpinoy View Post
    The 2 chrome ones with the safety pins on the left and right sides, around knee level.
    Jan 2018
    TX
    Question Help please
    I know this is a oldy but can someone tell me what size security torx these 4 do not remove bolts are? it appears we have 1 on each side that is loose
    Northern Kalifornia
    Default One more time....
    Quote Originally Posted by joeam View Post
    Apr 2015
    Tucson, AZ USA
    Default I think you tighten the nut on the inside
    I had a similar problem with a couple of these being loose; the bent-post ones I believe. My memory is I tightened them by tightening the nut on the inside-side of the side panel after I positioned them at the angle I wanted. I hope I'm remembering correctly.
    Rob
    Jan 2018
    TX
    I dont want to remove them i want to tighten them as they are loose will try the back side as suggested thanks for the help!!
    INDIANA, USA
    Default Torx
    All Good Info HERE.
    ENJOY YOUR LIFE WITH A SPYDER
