Results 1 to 8 of 8
    Invalid Emails
    May 2013
    Jacksonville TX
    Default Right Hand Break
    I'll try again. I thought I asked this before but will try again. I am trying to find a used or cheap right hand break for my 2012 RT S SE5 I am curtly in a nursing rehab facility and it doesn't look like I will be able to ryde withe out a right hand break. I can't move my right leg and very little on my left side. If someone has a used one or knows where I can buy a a reasonable one. Thanks Doug II
    Doug,
    I'd contact ISCI directly...
    They have a pretty good habit of trying to help folks out when they can!
    http://isciride.com/iscirtpartsinstalled.htm
    You just don't see too many of their brake systems for sale used...
    And I couldn't imagine that anybody has a similar setup that'd be nearly as well-built!
    MOgang Member & Monster Member
    SteveMac's Avatar
    Mar 2011
    Jackson, Missouri
    Doug
    Contact Billy at ISCI here. http://www.isciride.com
    They are a site vendor and have helped with disability discounts in the past. It is worth asking at the very least. And even though more expensive than some other options, this isn't really an area where you want to cut cost at risk of safety.
    When I owned my Spyder,,, If I could only do one modification, then the ISCI handbrake was absolutely, without doubt, the one I would choose. It is that important, if you need it.
    Oct 2013
    Brownsburg, IN
    I'll give an "amen" to the quality of the ISCI unit. In addition to he purchase price, though, take into consideration that it is not a quick, easy installation. Maybe ISCI will install free?
    Good advice about contacting ISCI. Let's see what happens.
    Invalid Emails
    May 2013
    Jacksonville TX
    Default Right
    THANKS GUYS I'LL GIVE IT A TRY. FELL IN THE BATHROOM LAST NIGHT. GOT CHEWED OUT BY NURSE FOR TRYING TO GO ALONE, SEE YOU OUT THERE. STAY SAFE DOUG
    Registered Users Rockwall's Avatar
    Jan 2013
    Northern Illinois
    Good luck with your health and getting back home and into the wind again. Bell well Brother!
    2012 Spyder RS SM5 - Steel Black Metallic "The Murder"
    Southern Cruisers Riding Club - Chapter 072 - Northern Illinois
    Two Brothers M2 Pipe; TB Juice Box; Hartco Custom Saddle; Rivco Driver Floorboards; Rivco Heel Toe Shifter; ESI Highway Pegs & Brackets; ESI 4.5" Easy Riser Handlebar Risers; BajaRon Sway Bar; Cycle Sounds Series 3 200 Watt Sound System; 14" Touring Windshield; Custom Dynamics Mirror Extensions; Kuryakyn ISO Grips; Kuryakyn Throttle Boss; Kuryakyn End Weights; Frunk Liner.
    Very Active Member AbNormy's Avatar
    Apr 2012
    SW Austin
    :what: get better soon
    Sent from my HTCONE using Tapatalk
    2012 RT A&C bought new 42312 sold July 2018 56k miles currently driving a 2014 RTSE6 LTD bought October 2018 w 6800 miles nicely farkled
    2014 RT SE6 LTD , White
