Page 1 of 3 123 LastLast
Results 1 to 25 of 65
Thread: Fuel economy
    Apr 2012
    College Station Tx
    Default Fuel economy
    I read on BRPs site that the 2014 Spyders could get 62 mpg, is this really true?
    Jul 2011
    Mitchell, Ontario, Canada
    Tested at constant speed. Fuel mileage may vary depending on Spyder RT models, personal riding habits, weather conditions, trip length, vehicle condition, vehicle configuration and other conditions. Up to 202 miles tested at constant speed 75 mph (325 km at 120 km/h). Break-in mileage may Tested at constant speed. Fuel mileage may vary depending on Spyder RT models, personal riding habits, weather conditions, trip length, vehicle condition, vehicle configuration and other conditions. Up to 202 miles tested at constant speed 75 mph (325 km at 120 km/h). Break-in mileage may vary.
    vary.
    Invalid Emails
    May 2013
    Jacksonville TX
    Default 62 Miles Per Gal.
    Right Billy!!!!!!!!!!!! One more cylinder and 30 more MPG some one is smoking those funny cigarettes.
    Actually; the extra horsepower and torque CAN get you better mileage.
    You simply don't have to grab as much throttle under normal conditions...
    But 62mpg??
    Registered Users EnjoyingTheRyde's Avatar
    Sidney & Rangeley Plantation Maine
    Default 62 mpg?
    That would be sweet!
    His: 2012 HD Tri Glide Ember Red/Merlot
    Hers: 2012 Can Am Spyder
    RT-S Quantum Blue Metallic
    Very Active Member Pennyrick's Avatar
    Feb 2011
    Loganville, ga
    Quote Originally Posted by jbtoups View Post
    Could be referring to kilometers, not miles and the Imperial gallon is a bit larger than the US gallon.... so maybe downhill with a tailwind it could happen.
    Penny and Rick have owned many motorcycles starting in 1974 with Honda’s, then to Suzukis, Gold Wings and ultimately Spyders.
    ‘74 Honda 360T (pair); ‘78 Suzuki GS 1000 (pair); ‘’82 Honda Aspencade; ‘84 Honda 400; ‘87 Yamaha 1100; ‘99 Honda Valkyrie; ‘01 Suzuki Burgman(triked); ‘02 Honda GL 1800(triked); ‘10 Spyder RTSE; ‘11 Spyder RTSM; ‘12 Spyder RTSL (pair); ‘20 Spyder RTL (current)
    Registered Users acinpcola's Avatar
    May 2011
    Cantonment, FL
    I think you read the 2014 can get to about 252 miles doing a constant speed of 62 mph.
    AC
    2014 RT S SE-6 Cognac, 2014 Indian Chieftain. Retired Navy Chief
    Jul 2011
    Default Need math lessons
    It appears someone at BRP requires math lessons or at least a refresher course. The math does not work no matter what calculator you use.
    Active Member nhoj's Avatar
    Apr 2012
    Aurora Ontario, Canada
    Its a misprint. 100 Kph = 62 mph not 62 mpg.
    It can travel (claimed) 252 miles @ 62 MPH.
    Marilyn 2023 RTL Red
    John 2023 RTL Black
    previous:
    2015 RTS SE6 Red
    2015 F3S SE6 Silver
    2011 RT SM5 Silver
    2013 STS SM5 Silver
    "common sense will prevail....but we see no sign of that"
    I just got back from a chili cook-off
    My brain is too weak from all of the chili to do any Math...
    Aug 2013
    Quebec City, Quebec
    Yes, it's a misprint. 62 mph is what you have to read....
    Jun 2013
    queens ny
    Default misprint
    just found the first problems with the 14's
    NO BIKE AT THIS TIME
    Aug 2013
    Quebec City, Quebec
    That will put some « heat » on BRP... lol...
    I'll go along with the above explanations. Since most owners seem to be reporting around 30 mpg, the thought of doubling the mileage per gallon seems a bit out of focus. Time will tell what the numbers show when people start reporting real world use.
    When it came to deciding on a 2014 RT or not, miles per gallon actually was not one of the things I even thought about--until now. For me, that will not be a deal breaker.
    Apr 2013
    Mesa, AZ
    Don't forget the 2014 have a 6 speed transmission so not running at as high rpms as the 2013 and older. Don't know if that makes a difference or not.
    2013 Spyder RT SE5
    Very Active Member den1953's Avatar
    Fostoria, Ohio
    Default Physics
    The new motor may be somewhat more efficient but is still pushing a 1012 pound vehicle with a 150 to 250 pound rider and that's solo with no gear in the storage compartments. The 2014 is almost identical in aerodynamics and rolling friction so no gains there. I would guess if it got 40 mpg it would be an improvement but 62 would be nearly impossible. Realistically 40 mpg would be a good ballpark guess
    Quote Originally Posted by Harpo View Post
    With the lower rpm operation and the 6th gear on the RT, I am guessing maybe a mile or two per gallon improvement. Time will tell.
    That's all? My guess, is that it'll show about a 4 mpg bump in economy...
    But;
    May 2011
    Cantonment, FL
    did you say time only 21 days till December
    washington state
    I think you'll get more mpg if you put it on a trailer
    2012 Spyder RT SE5 Brake pedal mod
    Active Member Texas's Avatar
    Oct 2013
    Austin, TX
    That would be about 100% improvement in mileage. I don't know of any manufacturer who has done that in one model year. That being said, my BMW K1600GTL gets 50+ MPG on every fill up. Yes, I get at minimum 300 miles per tank, but usually closer to 350 miles per tank. Once I pushed it beyond the 350 mark, but that scared me too much, so I don't do that anymore. The BMW is an inline 6, and the Germans have done the best job to date of anyone else when it comes to giving you both power (160HP) and high MPG. The BMW is also more aerodynamic than the Spyder, less rubber on the road, which means less friction, and about 200 pound lighter.
    I'm positive BRP meant 62 MPH and simply forgot to provide the MPGs. Since the MPGs aren't really anything to brag about, they went for total miles per tank. I'm usually a stickler about MPGs, but I'm getting tired of balancing big, heavy bikes, and with my wife on the pillion, we don't ride for speed, but rather comfort and ease-of-use, which allows for more distance with less discomfort. I've never liked regular trikes, so unless I want to spend $70K on a T-Rex, the Spyder RT-s is the one for me.
    Oct 2007
    ho,,,,brother plse don,t believe what they say
    bigger engine take less gas,,,,hey !!!!! santa clauss is coming the 25 of december,,, right!!
    Very Active Member Oldmanzues's Avatar
    Mar 2009
    Beavercreek, Ohio
    The 2014 were supposed to have a wonderful, newly discovered fuel injection system. It got over 62 MPG, but BRP did not want to brag. The Gas companys found out and paid BRP to stay with the old system on the new engine.
    A friend of a Friend of a Friend of a Friend got this from the tail end of a Moose, so it must be true
    Oldmanzues
    Very Happy Spyder Owner
    Aug 2013
    Quebec City, Quebec
    252 miles per tank! 6.86 US Gallon in tank = 36.7 mpg
    Jul 2011
    Default Typo
    It's obviously a typo they meant MPH not MPG.
    The 2014 RT has a 6.9 gallon tank and based on the range of 252 miles that works out to 36.5 MPG. That sounds reasonable to me.
    According to the BRP promotional material most of the efficiency gains come from the engine with their patented ACE technology. The main features of the ACE engine are the spherical heads, square bore and extra slippery coated bearings.
    We will soon find out for sure when customers start taking delivery.
