Results 1 to 19 of 19
Thread: $191.53
    Very Active Member btcherm's Avatar
    Howard City, Michigan
    Default $191.53
    took my 2012 rts in for service, had the engine oil and filter and transmission filter change ,
    had belt tension adjusted,and had the antifreeze level checked for winter.
    the bill came to $191.53 .and they checked for any new updates. they have always treated me right from the day I brought my bike from them, they always go out of their way to help their
    customers .
    They are (Lakeside Motor Sports) in Mecosta ,Mi.
    The salesman told me that their service dept. is what always brings customers back and brings new one in to buy their machine and he said I was now one of their can am family member and
    they would treat me right, their can am technician is very knowledgeable and go out of his way
    to help you,he know these bike inside and out..
    Jun 2013
    queens ny
    Default price
    that is a very good price
    NO BIKE AT THIS TIME
    Very Active Member daveinva's Avatar
    Mar 2011
    Washington, D.C.
    Shoot, I'd pay that price for labor alone around these parts.
    Silver 2010 RS SE5: Triple Play, Taillight, Brightsides, Fender Tips, Easy Risers; Evo Sway Bar; Airhawk R & Beadrider; latch springs; Grab-On grips; Crampbuster; 24" Madstad smoke windshield & deflectors; N-R round bag & soft saddlebags; BRP handlebar bag; Throttlemeister; Spyderpops Missing Air Dam & Air Mgmt System; Rivco driver & passenger boards & pegs; ISCI parking brake extension; Ultimate Midrider Seat w/both backrests, Fox Racing Shocks, Yoshi R-77 exhaust and a whole lotta love!
    A dealer with an excellent Service Department is worth his weight in Platinum!
    on having one!
    Very Active Member DR Buck's Avatar
    Apr 2012
    Fauquier County VA - Virginia's most carefully pronounced county.
    Although that is a great price for Spyder service the pathetic thing is I can get the same service on my Toyota plus tire rotation for $39.
    2012 RT Limited - Pearl White
    My Mods -
    http://www.spyderlovers.com/forums/showthread.php?39494-DR-Buck-s-2012-RT-Limited-Mods
    2012 RT Limited , Full size brake peddel White w/Red Highlights
    Very Active Member SNOOPY's Avatar
    Aug 2013
    Quote Originally Posted by DR Buck View Post
    So true, it is crazy what they charge for these services.
    Aug 2012
    Semmes, Alabama .
    Not a bad price at all, my dealer would charge a minimum of $300, thankful that I bought a ppm on mine.
    Default Great..!!
    wish that was Lakeside California..!! Most of our rydes start from there....
    ​2012 RS sm5
    Very Active Member Magdave's Avatar
    Jun 2013
    NE South Carolina
    on having one!
    2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
    Sep 2012
    Ontario,Canada
    Should only drive your Japanese Toyota then. Leave the riding to rest of us !!
    Compared to what most of us have to pay to have our 's serviced--you got a good deal. Also helps when the servicing gets it right and knows what they are doing. These days, any dealer with a good service rep is a good draw IMO.
    Yes, it costs less to have the same thing done on a car--but we drive 's for different reasons.
    Danbury Connecticut
    Sure, but a lot of that goes into parts as well.
    Don't forget, if you get all BRP suplly, the filters and fluids are around $80.
    I agree. The price to have your Spyder serviced seems on a par or better with other Spyder service, but Spyder Service is more expensive than a car.
    Geez, try getting work done on your boat !
    IBA #47122
    2020 RT Limited Asphalt Grey
    Invalid Emails
    Oct 2011
    Binghamton NY
    Default unfortunitly
    I guess the difference here is they have to take half the bike body parts off to do most work , and that is a pain.
    The Toyota not so much.
    Very Active Member Dan McNally's Avatar
    Jun 2013
    Quote Originally Posted by Yelhelp View Post
    . . . if your dealer had to pull the left front quarterpanel off your Toyota for an oil change, the oil change would cost a tad more!
    "Topper" is my Pearl White 2013 RT-LTD
    Professional Retiree - liked it so much when I retired from the USAF, that I started another career so I could do it again!
    Happy to be a member of the Maryland Spyder Web - find us at
    http://www.meetup.com/MarylandSpyderWeb/
    Sep 2013
    summerfield fl.
    Default 2012rts
    My dealer down here in Ocala FL. said it would be 950.00 to 1000.00 for my 15000 mile service.
    Jun 2013
    NE South Carolina
    Quote Originally Posted by kenk View Post
    If you have the valve check done it can be that range ( a little on the high side actually) but quite a bit of the honest dealers say the valve check is not needed it they need adjusted you can tell without tearing it down.
    They are quoting you for the valve check--about $600-$800 extra depending on your dealer. I have had two of them done--on two different machnes. 2008 @ 12,000 (recommended at that time), 2010 @ 28,000 miles. Neither required any adjustment at that amount of miles.
    I feel I am out $1600 for preventative maintaince that was not required. The new 2014 RT--requires no valve checks.
    It is your call as to whether or not you wish to go along with it. I also know that there are some dealers out there that may charge for the service and not do it--because they know they can get away with it. I do not know if your dealer is one of those.
    Invalid Emails
    Apr 2012
    Canal Winchester, OH
    I have a boat, as well as my Spyder, and the same thing. In Ohio, you have to pay the mechanics year round even though the season is about 8 months (if your lucky) for a motorcycle and less then that for a ski boat.
    What sucks is all the people who COULD take their boat/motorcycle in for service during off-peak periods, but wait to get service till the dealer is busy. So on top of the high prices - you have LONG waiting periods.
    You get used to it - but it still sucks !!
    Registered Users dick574's Avatar
    Jul 2011
    Mentone, IN
    My dealer, R/T Sales in Zulu, IN is also fair, honest & very, very reliable. Todd the service tech is beyond competent & is always proactive in his work. They are also a sponsor (Spyder City) so I trust them with all my work & highly recommend them to anyone who is looking for an excellent dealer. Keep up the good work R/T.
