11-01-2013, 09:57 AM
#101
2013 issues?
I have a 2013 RTS and have had very few issues (guess I'm the lucky one). Only issues I've had are
1. rear tire burned out at 8700 miles( no big deal) Have already talked with dealer and tech ( doughnuts help with the service dept)I do have a Kuhmo waiting for me when Spring comes by, that'll be first trip. 2. heat fix had no real heat problems before fix. 3. bad Purge valve- replaced all is good now. 4. Had a little challenge with bike doing the snake dance going at hwy speed 70+. That was straightened out with a BaJa Ron sway bar. These are the only things I've had(so far). The one thing I did do that I'll bet 80% of the people buying don't do is, I had salesman contact BRP and had a Build sheet sent to dealer before I picked up bike. Salesman was told if bike was started on a Monday or on a Friday I wont be buying it, and I have to see the build sheet. It was started on a Tuesday May21 and finished on a Thursday May 23rd, Now, Some may call BS on the build sheet thing but I feel it works I don't think it matters what you buy ie: Ford, Chevy, Toyota, etc., what I've noticed is if it's built on a Monday or Friday you'll(maybe) have issues. have had it happen throughout my short 63 yrs. There was a period of time (in my past) that I traded vehicles ever year in March. I only had one bad (Chevy) and sure enough it was started on a Monday. --- Just my two(three) cents worth for what it's worth. I love my bike and am having a ball on in( fair weather only- hehehe). I am so sorry for those of you that are having major issues with their bikes, I hope BRP unplugs their heads from their B***s. good luck to all.
11-01-2013, 09:58 AM
#102
Originally Posted by MT Kevin
105 degrees at fuel cap.
98 degrees at point of seat.(crotch area.)
169 degrees at radiator fan outlet.(air coming out on foot.)
this after 20 mile ride in 84 degree weather. The bike is still to hot for me but the customer does not mind it.
Those are actually pretty good numbers close to what I have since I insulated everything. My cap was 135 and crotch 120 before I did some insulating. Fan is actually a little higher than mine I get 150-160 but might be device differences.
11-01-2013, 10:16 AM
#103
Originally Posted by Lamonster
I guess it's time for me to jump in here. I too have a 2013 ST that runs hot, not motor hot but components hot. My right foot got so hot I couldn't keep it on the floor boards. Really surprised there has not been more complaints about that on the board. I've had to do a lot of work to mine to get it where I wanted to ride it. I've owned every make, model and year Spyder to date and the 2013 ST is the hottest of them all followed by my 2008. I really do feel bad for the folks that are having heat issues, I know if I couldn't work on my own bike I would be one of those people.
I will say that BRP does care and just because a fix has not happened soon enough for most of you that are having issues they are working on it. They are just as unhappy as you all, more so I would think seeing this has to have hurt the bottomline. At one time all we talked about here was the DPS and then it was the throttle bodies and now it's the heat. The DPS and the throttle body were real problems but are a thing of the past now. I'm sure we loss owners and members over those issues and we will most likely see some leave the product and the board over the heat issues. I hate that too but it is what it is and all I can do is to try and put it into perspective and hope for a good outcome. I'm confident there will be a resolve to these issues.
Lamont, thanks for checking in on this. I know your input is respected. I am either a very lucky 13 RT owner or a very naive one, but I don't appear to have the serious issues that others have had. My canister was melted slightly but that was it. On very long rides in very hot conditions my butt gets hot, but not enough to get off the bike. I have a blast ryding. You say that BRP is working on a fix! and everybody wants to believe you! and I do believe you. They asked us to do a survey and most of us obliged, but we have not heard anything from them. I think the negative tone on this board would be abated by some sort of communication from BRP. Just a letter to all owners stating that we are working on some "upgrades to the 13 models" would calm a lot of people down. I for one am going to Ryde the off my Spyder because I love it, and we are thinking about buying another one. But I think if BRP is indeed working on something, then they need to speak up. Don't you think so?
11-01-2013, 10:26 AM
#104
Pirate, i'm glad you are happy enough with your spyder and can ride it. However, you did have the serious issues others are complaining about. Your canister melted, meaning its VERY hot....isnt that really the entire issue? Your bike is running hot enough to melt components What would have happened if you rode further, or in hotter weather...
100% agree, The lack of communication is really an issue.
Rewaco RF-1 GT
Inline 4 cylinder Ford Zetec with multi-port fuel inject, 140 HP
0-60mph: 5.8 seconds
5 speed sync manual with reverse, mechanical dry clutch.
Front suspension: Trapezoidal fork with center spring
Rear suspension: Independent with Bilstein gas shock absorbers
Brake System: Grimeca calipers, linked ventilated discs, with booster
10.57 gallons
11-01-2013, 10:40 AM
#105
That's what I was thinking to, those are some temps that aren't too bad. Last time I went to the dealer I had the service writer come out and check mine as soon as I arrived there. He logged a temp of 153 on the cap and I made sure they put that on the work order. I do not even check the temp at the radiator.
11-01-2013, 10:53 AM
#106
We all will benefit
Yes, all Spyder owners, with or without heat problems,will benefit from aiding those with issues. These are very expensive toys that we do enjoy riding and we must join together to see that our ride is safe. So far, we have approached the problems as individuals. That rarely works when confronting any powerful organization. I own a 2013 rt without issues to date, however, I am more than willing to assist those who are experiencing problems. I could be next.
BRP cares. How do we know that? They left a thread and post where you could state your 2cents and feel better. But, that is all you will get from them without action. What kind of action depends on us. Let's face it, considering the price of our toys,many of us have probably been owners and management, not unionizers. So, are we upset enough to stage a ryde in at Co. hdqrs or picket dealers with poor service? Actions speak louder than words.
11-01-2013, 10:59 AM
#107
I have nothing but sympathy for the 2013 owners. I sat on the sidelines watching the post here about the RT problems through most of 2011. I wanted to buy a Spyder for a year before I pulled the trigger on a 2012. Finally last summer I realized it was what it was and I felt like I could "fix" the RT problems with the aftermarket support here. I have spent $1000 of dollars fixing what I felt were the weakness in my 2012. (Shocks, Swaybar, Block Off Plates, Belt Tensioner, Third Brake Light, Corbin Seat, Floorboards, ect...) I'm encouraged to see what people are doing with the exhaust wrap and I'm going to do that this winter. Will it make a huge difference...I don't know, but it's worth a run at it.
Having said all that, best wishes to the 2013 owners, don't give up on looking for heat solutions, but in the same breath, don't expect BRP to fix it for you.
11-01-2013, 11:03 AM
#108
11-01-2013, 11:05 AM
#109
Originally Posted by spyder3
[/B]
well it was pretty long 800 miles, and 108, when I brought it in for the recall.
11-01-2013, 11:22 AM
#110
This forum help me understand the other things that I don't know. This is the place my frustation is vented. Humors and Jokes help me get through the day.
SORRY if you have enough of these, but the intention is to lighten up and share the good stuff we have in common.
This forum is like a food buffet to me. I eat only that I like and ignore the rest.
11-01-2013, 11:32 AM
#111
11-01-2013, 01:28 PM
#112
Originally Posted by 3 Wheel Addict
Yes, I believe the cooling system has the capacity to handle the cooling of the engine very well. A lean burning or over advanced timing will promote hotter combustion temps and that will make the exhaust system hotter as well but the cooling system can handle the cylinder head temps but once the heat is in the pipes it can not be controlled anymore and relies on air movement over the pipes to control that extra heat. Air flow through the panels now may be ok for an ideal running motor but if that balance is tilted the airflow may not be enough.
Thanks
11-01-2013, 03:52 PM
#113
So, what is your cap and crotch temp since you've done the insulating? And what/where did you insulate? This is the kind of information we need to know. Air temp coming off the radiator is pretty immaterial since it's controlled more by the ambient temp and thermostat than anything else.
CincySpyder posted today that he'd installed a fan that kept his under-tupperware temps at ambient temperature. That's the kind of mod that should help you.
11-01-2013, 04:24 PM
#114
11-01-2013, 04:32 PM
#115
Question: Was this reading taken by you, or a trained medical professional?? nurse.jpg
11-01-2013, 05:50 PM
#116
11-01-2013, 06:17 PM
#117
11-01-2013, 06:19 PM
#118
Originally Posted by mindman
100%
If available where you live, Lemon Laws should be invoked for sure!
If not....keep the pressure on!
It would be very interesting to know just how many sales BRP has lost as a result of people reading this website. Since it is one of the largest - if not THE largest Spyder oriented website, my guess is that they've lost a LOT of potential buyers.
Lets hope that's not the case. Would much prefer a potential buyer would become better informed and use the knowledge gained here to make an informed decision. jm2c
11-01-2013, 06:24 PM
#119
We're most likely not best-served, by creating an adversarial relationship at this time...
11-01-2013, 06:30 PM
#120
Owners of 2013's have major problems and that is horrible. Would it be a good idea to create a new heading on Spyderlovers for 2013 issues? This would better organize issues for those that need help and us "lucky" 2012 and earlier people.
Just thinking...
11-01-2013, 06:43 PM
#121
11-01-2013, 06:47 PM
#122
Just thinking...
Please quit saying 2013 owners like it is all of us, it seems to be "some" RT owners and maybe 2-3 ST owners.
11-01-2013, 07:02 PM
#123
11-01-2013, 07:20 PM
#124
11-01-2013, 07:33 PM
#125
I have had enough "spyder loving" from non 2013 owners
Good evening All,
Well after being off the forum for a little while, I just couldn't stay away any longer.
I have read most of the recent complaints, and I fully sympathize with all that have had and that are still having problems with your Spyders, non standing of the year they were constructed.
I figured I would stay away since some people took offence to my constaint complaining about BRP, but then I figured that I had as much right being here than the others.
We, that have problems are happy and envious of the folks that enjoy and have no problems or complaints with your Spyders, you in turn should understand how frustrated and anoyed at the lack of response or positive feedback BRP is provides us.
Its a bloody joke, again I will sound like a **** disturber, honestly at this point I don't give a damn, if you are not with us and support our complaints then you are against us, and hopefully all the guys that are buying 2014 models have no problems with your machines, otherwise your complaints may also fall on deaf ears.
Now to all of you that are having any type of problems as minor or major they may be, we should stick together and prepare to comfront BRP with our issues.
My recommendation is that we prepare a list of names with addresses, and problems and look at the possibility of a CLASS ACTION. that is all BRP needs with a new 2014 in production.
For some reason the last time I started rocking the boat and got everyone anoyed at me, we had some action from Steve at BRP, this time lets regroup and go way up the latter, in my book it is obvious by now, that these people assume we are all yahoos with no gults to persue these issues any further.
Maybe by regrouping in this fashion, the 2014 line will either be produced with a much higher quality control or the line will fail under presure of the existing unsatisfied customers.
I think it is time to S**t or get off the pot, they are ignoring us, so lets make sure we do something to catch their attention, maybe start writting articles to your local new paper or favorite motorcycle magazine explaing in detail the problems that a great number of us are having, or catch tsome TV anchor people, or even look at boycotting or even better showing up at event prepared by BRP passing out list of problems like Spyders catching fire, etc.
We got to do what we got to do.
Who ever wants in, please send me your suggestions and comments, via private e-mail maybe we can get thing done.
Its time to go ahead with real action.
Enough of the BS and lack of action.
Dom
