JOHN
Sometimes you have to talk it out and think long and hard about things like this. I don't think I am having heat issuses like your experiencing . My bike get very hot at the glovebox area and by my wife's leg as a passenger. Also I here gas boiling in the tank after short rides I have not started touring yet because I just don't trust the bike enough. Right now I am concentrating on getting mine to handle better.
I have thought a lot about what to do with mine also. I am going to work on the handling right now and wait to see if BRP comes up with something for our heat issues. It was just last week that we all filled out the survey and they see what is being talked about on this forum. I don't want to take a loss either so I am going to wait and see what happens. If BRP does nothing and my bike starts to run even hotter where I can't ride it. I will take it back to the dealer and walk away from it and stop making payments!!! Also I would contact Nydia Hahn Consumer advocate from Channel 6 action news Philadelphia.
As for you I think you should wait and see what BRP comes up with and not make any Hastie decisions.
GOOD LUCK
John
Life is short, sometime you just have to walk away from something and find something else that pleases you, good luck with whatever decision you make
Cruzr Joe
i was wrong
i just got back from the dealer and they are still working on the bike and it is the first time i have seen it fully apart, the way the pipes are run on the left side is just dumb. right by the gas tank with no heat shields. the thing i was wrong about is the anti freeze, they are not changing it as i thought the new anti freeze is being used in their 4 wheelers and he has a call into steve from brp to see if they want to try it, but they don't have it in stock so if he wants to change it brp will have to send it. there doesn't look like there is any heat damage to the MC or the canister and they are getting ready to put the band aids on them. the buds report was sent to brp and i guess they are waiting t see what brp says. so that's it so far and i did tell them i changed my mind and will give the bike another chance.
NO BIKE AT THIS TIME
Good luck and keep us posted.
Great News
That's great news that nothing has begun to get damaged. And here is my "no tech savy" 2 cents. Last week went to our dealer (which I believe is one of the best), Clem's in Enumclaw, Washington. Ended up purchasing an extended warranty for my 2011 RT S SE5. But was very tempted with the pricing on the 2013's. Plus, Randy, our spydee tech is waiting to hear from BRP because he has come up with a solution for a heat shield type of protection for the pipe area because he believes that has been behind a lot of the heating problems. Clem's believe BRP will be coming out with some sort of fix based on his technique. Clem's is already using the protection on any new 2013's going out the door now. Not sure if this is different from the BRP fix already out there but believe it is. Best wishes to you and all the luck.
Can you elaborate more on his new heat fix? Or, please advise what he's doing after you get more information.
2013 RT Ltd. SE5
Sorry
That's all I've got, unfortunately. Since I have a 2011, I did not go into detail with them on the fix. I was semi seriously thinking of trading my 2011 and when I was asking them about the heating issues, this is the information they gave me. I then decided to get the extended for my 2011 and bide my time to see how the 2014's perform.
Well my current situation has not changed, dealer won't help and BRP wont call back. Last trip to the dealer netted me the hottest temp on the gas cap yet and it was only 74 degrees out that morning! (153 degrees on a plastic cap) I did a long ride this past sunday and had to stop about 60 miles in and place a towel over the front of the seat to keep the heat off of my nuts! They was a roasting.... now later that evening when it got cool that heat was kinda nice but not so much when it was 85 out. I rode about 220 miles to another dealer to see if they have seen any issues with the heat, their response was kinda beating around the bush, like they have but don't want to talk about it??? He kept changing the subject and avoiding my questions, weird....
phone call
i just got off the phone with steve from brp. according to the buds report he received from my dealer my bike is running hot, lol i knew that. he also told me that the report shows i am shifting at the right rpm's and running the bike in the right rpm range, but he said the tec's are working on the problem and they hope to have a solution in the next couple of weeks, just when the holidays are coming and i said i was going to supply the roasted chest nuts
Well, maybe, just maybe they can find something john. It would sure help alot of people including you.
Rewaco RF-1 GT
Inline 4 cylinder Ford Zetec with multi-port fuel inject, 140 HP
0-60mph: 5.8 seconds
5 speed sync manual with reverse, mechanical dry clutch.
Front suspension: Trapezoidal fork with center spring
Rear suspension: Independent with Bilstein gas shock absorbers
Brake System: Grimeca calipers, linked ventilated discs, with booster
10.57 gallons
amazing
what really amazed me was they could tell what rpm's i was shifting at and what rpm's i was cruising at
yeah, they get that info from the buds readout....It sounds like they were at the very least, honest about your issue.
Rewaco RF-1 GT
10.57 gallons
WOW
Illegitimi non Carborundum
2013 RT-S Circuit Yellow with Black Trailer
new-new update
i just called the dealer about hearing from brp. he told me the canister was melted and one is on order so no bike until it comes in being the bike is all apart so now it is just a waiting game to get the bike back. i was really starting to think i was going nuts with everyone not having problems saying the people with problems have the poor me's and we were cry babies, so believe it or not i feel a lil better knowing they did find a problem and that i was not loosing it
HEY BRP STEVE
there are bunch of people following the outcome of this issue--sure hope brp is on this one. congrats to cuz john for being so persistent, I sure hope it works out well for the "cuz" and the rest of the 2013 owners with problems.
persistent
i was only persistent because i have a health problem with my feet due to diabetes and i can not have my foot burnt because diabetics don't heal well, if the problem with my feet didn't exist i might of just learned to live with the heat problem. but being my brother in law lost toes due to a burn and he was a worst diabetic than i am i said i will not lose body parts and put my health at risk over a bike that i bought because of not being able to ride two wheels anymore. so lucky for me and us, that i did have concerns and i pushed the issue to the point where i am getting something done. i just hope they find a fix for us 13 owners and we can ride till our hearts are happy again.
i just got off the phone with steve from brp. according to the buds report he received from my dealer my bike is [PHP]running hot[/PHP], lol i knew that. he also told me that the report shows i am shifting at the right rpm's and running the bike in the right rpm range, but he said the tec's are working on the problem and they hope to have a solution in the next couple of weeks, just when the holidays are coming and i said i was going to supply the roasted chest nuts
So if it is running hot is it running too lean or is there a problem with the cooling system?Just my thoughts.
don't know
i get really bad gas millage but i don't know what is going on with brp and what they are thinking. as long as they can come up with a fix that's all that really matters. when a friend of mine looked at the muffler the other day he thought the bike was running rich by the black in the rear baffles. i just hope a fix is soon found
I'm curious about the whole "running lean/running rich" issue as well...
John,
If you're talking with BRP about it; ask them:
If the bike is running lean, and heats up...
Does it then go to some sort of enrichening mode, to add fuel to cool the combustion chamber?
Lousy fuel mileage could also be the purge valve (I think...)
well
John,
there has to be a good reason for everything that is going on. so i guess if they can see what rpm's that i am shifting at and what rpm's i am cruising at than they can see everything the bike is doing and try to find a fix. i just hope they can't see that every tine i ride i stop at a donuts shop or a pastrami sandwich i eat because that can really be embarrassing
John, get that thing on the rode and we can meet up for a ride....
Rewaco RF-1 GT
10.57 gallons
John,
with all the codes the spyders throw, you'd think that it would throw one for a bad purge valve, wouldn't you?
10-18-2013, 11:38 AM
#100
Can any of our canadien friends tell us what that means when it's said north of the border?
Rewaco RF-1 GT
10.57 gallons
