NEW BAKE PEDLE
Very nice..!!
really O'reilly has that pedal...? Good job looks great..!!
2012 RS sm5
Brake pedal.....
Originally Posted by whitjim10
Look great, what is the part number. I think this will be of interest to other Spyder owners. Thanks for posting. How difficult is the install? Ryde safely. Paco
Chase the wind every chance you get.....! 2013 Circuit Yellow RT-SE5
Mods: Bump Skid, foam grips; Tric-LED 3rd & 4th tail lights, Mirror turn signals, & front fender lights; CB, Shortee CB & Radio Antennas, NBV Highway Pegs, USA & CA flags on Rivco flag mounts, Black widow frunk logo, Utopia Driver backrest, Sheepskin Driver Seat pad, running & brake light license frame, Chrome Luggage Rack, Ram mount on dashboard for iPad Mini for GPS, Race Tech shocks all around.
SuWEET!!
That really looks good.... Thanks for sharing
Bob
Good job and look nice.
2012 Spyder RT SE5 Brake pedal mod
Unless it bolts just like the stock one I would not trust it. There are plenty of supporting venders that have a proper fitting pedal replacement. That looks like one of those strap on ones. Would you bet you life on it? It does look good though....
2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
ITS BOLTED ON NOT STRAPED ON, THANKS
NEW BRAKE PEDEL
THIS IS WHAT I DID, I TOOK THE ORIGINAL BRAKE PEDEL OFF AND TOOK THE MOUNTING PLATE OUT OF THE RUBBER HAD TO BURN IT OUT WITH A TORCH THEN MOUNTED MOUNTING PLATE TO NEW BRAKE PEDEL.I HAD TO DRILL THREE HOLES
TO MOUNT THE PLATE TO THE NEW PEDEL. THEN USED THE TWO SCREWS TO MOUNT BACK TO THE BRAKE PEDEL.
OK nice but you don't have to yell at us
