2013 Recall
Yesterday I had the safety recall done on my 2013 RT Limited. The master cylinder was not damaged, however the evap. cannister had damage from the heat. Also the right side panel at the bottom near the brake pedal was deformed out in a small area. Anyone else have the heat issue with the right side panel?
Don't know..!!
I haven't heard that part mentioned. Maybe they haven't paid that much attention to that area..good to know and thanks for the info, I'm sure many will take a second look...
Yes! Mine was damaged in the same spot. Dealer ordered replacement.
Good thing you've notice it, it may very well cause by heat coming from the exhaust pipe. Keep your eyes on it. Have fun with your ride.
Recall done and both exhaust exhaust gaskets changed.
Thanks for the info. Let me go check.
YES
Hey Sam, Yes, my right side panel had to be replaced when I took my 'blackcurrant' in for the recall. Dealer brought it to my attention, and ordered a new piece. They will 'back' it with heat tape when it's installed... next time I take it in... Curt
