Page 1 of 2 12 LastLast
Results 1 to 25 of 27
    Active Member Indyron's Avatar
    Apr 2013
    Sunbury, OH
    Default Can-AM Spyder RT Luggage Rack
    Anyone have any experience with the Can-AM Spyder RT Luggage Rack offered by Value Accessories?
    Thanks!
    2021 Sea to Sky, 2013 RT Ltd, 2005 Bombardier Outlander ATV
    May 2013
    Toledo Ohio
    Yes i have one there Great, only problem my half cover does not fit now
    Apr 2013
    Sunbury, OH
    Default THANKS!
    Quote Originally Posted by jimb57 View Post
    Saved me some money!
    Sep 2013
    Olympia, Wa
    Default Trunk Rack
    I have one I got from www.BigBikeParts.com and I like it.
    Dave
    GOS member (Girls On Spyders)
    May 2012
    Russellville, Kentucky
    Just got mine yesterday. Looking forward to installing it.
    Dee
    Feb 2009
    Canby, OR
    Ordered mine in May, got it two weeks ago, and my SO spirited it away for a Christmas present (who needs a rack in the NorthWet winter????). So I'll tell you if I like it in January, when I finally get to install it…..
    Active Member rick_w's Avatar
    May 2013
    NE Ohio, Madison
    Quote Originally Posted by Indyron View Post
    Thanks!
    We just got another shipment of the Big Bike Parts Luggage Racks in a few days ago. We have several left right now that are not spoken for. We do have a lot more coming in.
    http://store.valueaccessories.net/Ca...ggageRack.aspx
    The feedback on those has been 100% favorable.
    We also have a lot of the TricLed Lighting in stock now. We can answer most of your questions on the lighting, we have installed just about all of it on our own RT.
    Rick
    Value-Accessories
    May 2013
    Redlands, Ca
    Default This one...
    Feb 2012
    San Jose California
    Default What to do with the Antenna
    I just ordered this Trunk Rack, while looking to the trunk looks as I will not be able to use it for language that is wider then the rack since the antenna is in the way.
    Any experience with this issue?
    May 2013
    Redlands, Ca
    Quote Originally Posted by szohar View Post
    Don't center luggage on it or get a shorter antenna or a bag that's not so wide. I did the last one. Taller and narrower bag.
    Apr 2010
    Ft. White, Florida
    Default RT Rear Deck Rack
    Check out my avitar. They come in chrome and silver powder coat too.
    full time RV
    Default RT rear deck rack
    I like the pic that Inspector Gadget posted. Where can I get a rear rack like it?
    Mar 2012
    Cape Cod Mass
    Default HIGH MOUNT LIGHT CAUTION
    One cautions regarding racks on RTs. You may not be able to mount a HML if the rack follows the truck lid angle.
    the BRP trunk rack interfers with the HML. WE USE A Diamond R which is a flat rack. Fits and easy to install and looks great. JMHO.
    mike s
    Aug 2013
    Northern California
    Quote Originally Posted by Dan_Ashley View Post
    Do you have a half cover for your bike and does it still fit?
    Nov 2013
    Central Texas
    Sold my half cover & bought a full cover from Bib Bike Parts. Fits fine, cost less than the BRP half cover. here is the link.
    http://www.bigbikeparts.com/template...&GroupGuid=668
    Nov 2013
    Central Texas
    Quote Originally Posted by rick_w View Post
    Rick
    Value-Accessories
    This is the rack that I have as well. Full cover fits over it, no problem.
    Mar 2012
    Cape Cod Mass
    Default Will not clear HML
    Pirate looks at --
    if the white Rt in your sig is the bike you are thinking of putting that rack on, be forwarded. It will not clear your HML.
    MIKE S
    Mar 2012
    Cape Cod Mass
    Default Weight limitation on trunk mount rack
    You don't want a bag much larger than the width of the rack because there is a weight limitation as to how much stress the trunk lid and trunk shell ( the colored part of the trunk lid) can take. The bigger the bag, the heavier one will tend to pack it.
    again JMHO and YMMV
    MIKE S
    Aug 2013
    Northern California
    Default Agreed
    Quote Originally Posted by Mspiv View Post
    Pirate looks at --
    MIKE S
    yep I have been through that, and bummed that it won't work. But I think the one Dan has will still work.
    Mar 2012
    Cape Cod Mass
    Quote Originally Posted by Pirate looks at -- View Post
    Also check out Diamond R. I think he is a Sponsers here. A bit pricie but a great looking great functioning rack.
    mike s
    May 2013
    Stanton, ca
    Also be aware about weight you put on the rack!
    Open your trunk and see the sticker that says "20 lbs max? Do not overload"!
    So now with what you have in the trunk and the rack, you get 20 lbs. That is not a lot if you think about it.
    So be careful with loading. My bet is this has to do with the rear shock and airbag. Overloading my cause big trouble.
    Bob
    Apr 2017
    Sierra Vista, AZ
    Default Luggag Rack
    Thanks!
    Ordered one two days ago and waiting for it to arrive. I ride with some Spyders that have them on and they look great.
    Active Member Charlottes Web's Avatar
    Northeast PA.
    I have the Diamond R flat rack and the 1/2 cover fits good
    Christine
    Apr 2017
    Delaware
    I got one but won't fit because I have the third brake light on the trunk
    Mar 2017
    Salisbury,NC
    Quote Originally Posted by DesertRider View Post
    i ordered one cause i needed extra storage space. if rack would get in way of 3rd brake light, they have a rod risers of about 3/4 " (talking about big bike parts-show chrome rack- from value acc)
