auto versus manual transmission opinion
looking at purchasing a spyder in the next year and was wondering about everyones opinions. of manual versus auto transmission. Please post WHY.
Senior MOMENTS Member
Auto Verses Manual Trans shift
Have you read all the posts on when to shift up or down on an Auto trans?
With an auto shift transmission it is imperative that you keep your RPM above 3500 (give or take a few hundred). If you run / cruise under that RPM there is a chance your clutch is not fully engaged causing slippage which can cause premature DEATH on your wallet.
It is not as critical with a manual shift transmission.
If it Feels Good, Do It !!
Too Much Is Just Enough !
2011 RS~S Pure Magnesium / Black ~M~
2018 F3 LIMITED
First there is no option for an automatic transmission. BRP calls it a semi-automatic and that is a stretch. The only time it will shift for you is on the down shift when you are too busy or lazy to do it yourself. Other then that you have to decide when to shift up or down. The big difference is there is no clutch for you to control.
It really doesn't matter what other people think about one or the other it would be best if you rode both and decided for yourself.
2018 F3 LIMITED
trans
Originally Posted by billybovine
Not if they buy a 2014 RT!!!
YES you are right..
choices, choices..!!
first off I have the manual transmission on my spyder as well as my cars. I have not driven the semi trans spyder has put out. Know many that have them and love them. Good amount of them can't handle or don't want to deal with the clutch. I on the other hand like having control. I like coasting down hill by simply pulling in the clutch. I like leaving the bike in gear when parked. I like downshifting when I want. I like not having the bike hang up in gears and having the clutch fully engage when I release the lever. Etc...just me. .!!
2012 RS sm5
I vote for the SE5. If you set the trailer option on, it won't let you upshift if the RPMs after the shift are below 3500. Also, it will automatically downshift when the RPMs fall below about 3300. Plus, it's a heck of a lot easier than a manual. No clutch to work and hitting the paddle can be done even if your feet are on highway pegs.
Silver Shadow
2013 RT-S Lamonster Edition (vented windshield,
NBV highway pegs, Two Brothers exhaust)
Additional Mods: SpyderPops BumpSkid, Elka 1+ shocks, BajaRon Anti-Sway Bar
A Veteran is someone who, at one point in his or her life, wrote a blank check made payable to The United States of America, for an amount of up to and including my life.
The semi auto is convenient for sure and if I lived and drove in the city all the time I would have one but I prefer the control of the sm and search the posts the repair problems are 10 to 1 for the se plus 1500 more cost more service expense more heat on the left side having to worry about not dropping under 3500rpm plus you can bump start a dead battery machine ill take a Manuel thanks
2 happy happy spyders
I have owned both versions of the . 2008 SM5 and the other three, SE5's. The ONLY trouble I have experienced with the SE5 is that the linkage disconnected on my 2010. One time. Other than that, I can say all have been good.
I recently rented an SM5 (the only version available), and did not like it as much as my original purchase. I guess I have grown soft since 2010. I like the ease of using my thumb or fingers to change gears. The rental about drove me nuts with all the clutching and foot shifting--but I made it anyway.
Its a personal call--just like seats, helmets, gear.
Bottom line, I recommend test driving both flavors to see what you like best. The SE5 will also cost about $1,500 more per bike.
Test drove the SE and bought an SM.
Love the SM for reasons others have said, control.
However when stuck in traffic the SE would be better for sure!
So if you plan to do a lot of in traffic or in town with a lot of stop and go, the SE would be the best bet.
Bob
2011 RT-S SM5 - Black
magical member
Been ridding motorbikes for many years and I love the semi automatic. You still have to shift,so you still have control. You just have paddle shifters on the handle bars to go up and down the gears no clutch.
If your in a hurry and open her up you can shift through the gears extremely easy with paddle shifting. You can still manually paddle shift down but if the spyder will do it for you as you come to a stop or your RPM drops and you accelerate.
SE on 2013 you have to keep your RPM hight to keep the clutch engaged, not really an issue once you are used to it and it becomes habit. If you plan to tow a trailer on the 2013 and below you have to put the spyder in trailer mode, this basically alter the shift points. With a manual you don't have to worry about RPM or trailer mode as you control the shift points.
To me an SE is the best of both worlds, I can shift down when I want or leave the spyder to work it out. You have to shift up anyway just flick of the thumb, no clutch, no rolling off the gas.
The new 2014 RT's with the new triple don't have have trailer mode or the need to watch the RPM as they have the torque to handle.
harry
"Draco dormiens nunquam titillandus"
My Rides;
Nimbus 2000, Ford Anglia, 2012 Spyder RT Limited, Pre 14 Vintage Classic Collectors Edition!
Favorite Ride;
Nimbus 2000 boy this thing can fly.
Mods:
Charm of invisibility, Reparo Charm (cuts down on service cost)
One always wonders about roads not taken.
Manual shift--the only way to go for me!!!
Don't think I'll ever buy a car without a manual transmission if I can avoid it, LOVE manuals... in cars.
On the Spyder, the SE is the only way to go for me. Part of its unique charm, and soooo much more fun than riding the manual Spyder IME. They designed this setup very well.
Silver 2010 RS SE5: Triple Play, Taillight, Brightsides, Fender Tips, Easy Risers; Evo Sway Bar; Airhawk R & Beadrider; latch springs; Grab-On grips; Crampbuster; 24" Madstad smoke windshield & deflectors; N-R round bag & soft saddlebags; BRP handlebar bag; Throttlemeister; Spyderpops Missing Air Dam & Air Mgmt System; Rivco driver & passenger boards & pegs; ISCI parking brake extension; Ultimate Midrider Seat w/both backrests, Fox Racing Shocks, Yoshi R-77 exhaust and a whole lotta love!
I have the SE, I would not call it automatic as the only thing it does automatically is done shift. You have to shift up at the right time when the clutch is engaged. I have to deal with a lot of traffic so it works for me. I never let it down shift cause it seems like it waits to late and I don't like the way it feels when it down shifts automatically.
I recommend trying both and decide what works best for you.
If you ryde like there's no tomorrow, there won't be any
Accidents hurt - safety doesn't
Motorbike Professor
Manual for me because I don't want to learn something new to do with my left thumb. With 25 other motorcycles in the stable, the less that changes from one to the other the better. For my wife it was a manual because she could get one at least six months before the SE was available.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
I think that's gonna be a matter of what you feel more comfortable with and what type of bike you want. If your gonna go with a touring model I would thing the SE5 would be a pretty good choice. I have a RSS and I think with being a sport bike manual is the only option I would choose. I can shift my manual just as fast if not faster then any push button shift out there and I still feel manuals have more control. If you have ridden manual bikes in the past these are really no difference, if you have no bike riding experience try them both but working the clutch takes practice but comes pretty quick.
What ever you decide make the bike your own and you'll be happy.
I've been riding motorcycles since 1968 and went with the semi-auto on my Spyder. Will do the same if I get a 2014. Why? No clutch lever. That is really great in heavy traffic, large group rides and parades. You still shift...like a paddle shifter on a race car or a sports car...but don't have to worry about the clutch. I love not having my left hand cramp up in heavy traffic.
YMMV.
Phil
I may be old, but I got to see all the cool bands.
2011 Spyder RT-AC
If I recall the technical stats about the SE transmission, this is not true-- the SE5 shifts faster than the manual, no matter how fast a rider can shift.
Well I have not road many SE5 but I'd be willing to test that theory
Either would be enjoyable. I have ridden for over 25 yrs with a manual, BUT, before you buy, try the semi-auto. IT'S JUST PLAIN FUN!
My $.02.
harry
I love my SE 5, I can't wait for SE 6
2012 Spyder RT SE5 Brake pedal mod
My 2011 RT was an SM (manual) and my 2012 RT is an SE (I have no idea what the E stands for). I prefer the semi auto for three reasons....
1. The top of my left boot stays shined
2. My left wrist continually thanks me for going to the semi auto, especially in heavy traffic
3. I can tell folks it shifts just like a Ferrari
Penny and Rick have owned many motorcycles starting in 1974 with Hondas, then to Suzukis, Gold Wings and ultimately Spyders.
74 Honda 360T (pair); 78 Suzuki GS 1000 (pair); 82 Honda Aspencade; 84 Honda 400; 87 Yamaha 1100; 99 Honda Valkyrie; 01 Suzuki Burgman(triked); 02 Honda GL 1800(triked); 10 Spyder RTSE; 11 Spyder RTSM; 12 Spyder RTSL (pair); 20 Spyder RTL (current)
2018 F3 LIMITED
Yeah
but ya never know a clean fast shift
