Where would YOU wire led fogs into?
Just picked up a pair of Bolt on fog lights for my 2012 RS. They are led and pull just over an amp each. My question is, where do you feel they can be most easily tapped into? I do not need a switch, as long as they light when the ignition is on. Thanks.
2012 RS SE5
Mods:
Bad Boy Air Horn
Two Brothers Exhaust
K&N air filter
LED mud flap lights
Tips Kit
Brake Light Modulator
IPS Key Cover
Up/out mirror Extensions
RSS stitched seat cover
Cal Sci touring windshield
5 spoke wheel upgrade
Ram mount Iphone cradle
LED turn signal indicators
Frunk Liner
BRP 12 Volt Outlet
Third brake light
Double Play tail light
Baha Ron's Sway Bar
Oxford Heated Grips
Battery Tender Jr
HID Headlight upgrade
LED fog light upgrade
LED FOG
IMHO, if they are LED I would just tap into the nearest wires ........like the fender lamps...........this shouldn't upset anything.....But you might want to PM Roger Rattigan or Scotty about this.........Mike
Light hookup
I wired mine to the factory accessory wires you will have to put a 3 amp mini fuse in the fuse box wires are next to the left front top shock bolt you will have to remove left Tupperware to accesses the wires you don,t need a switch power shuts down 30 second,s after shutting the bike down.
Thanks. Just pm'd you.
2012 RS SE5
Mods:
Bad Boy Air Horn
K&N air filter
LED mud flap lights
Tips Kit
IPS Key Cover
Frunk Liner
BRP 12 Volt Outlet
Third brake light
Baha Ron's Sway Bar
Oxford Heated Grips
Battery Tender Jr
