adding oil between oil changes
how much oil is average to add between oil changes?
Just like with every other internal combustion engine; there is no average... They use what they use. The key, is to get an idea of what yours needs.
(Mine however; uses about 14 oz between changes...)
It appears that different Spyder use different amounts. From my experience I will add oil twice. From the add line to the full mark is 1/2 a quart so that is 1 quart between oil changes.
Bob's advice is right on the mark. It will depend on what kind of riding you typically do.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
I add about 4 oz every 1,000 miles. I measure how much and keep a log book. Yes. You are right. I am OCD about my Spyder.
Little checking..!!
I check after every long ryde. Usually add a couple ounces. This would be about 10-14 oz.'s between oil changes. Those being every 4600-5000 miles depending on where I ryde or where I am...
About the same with me............
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
My RT has 11000 miles on it and has had the 600 mile oil change plus two additional. The last change I got the level about 1/4 inch over full when really hot. After almost 3000 miles it is still more than 1/8 inch over full. To date, I have not added any oil between changes.
My 2012 RT Ltd with 16,000 miles uses about a half a quart every 2,000 miles and has ever since it was new.
My wife's RT Ltd with 12,000 miles never uses any... in fact I think it manufactures the stuff. Whenever I check it the level is always just on the line.
When I asked my tech about this he responded that the tolerances on all engines are different. When he pulled the engine speed reports from BUDS we found that her Spyder spends more time in the 5,000 rpm plus range than mine does so that may be a clue.
Penny and Rick have owned many motorcycles starting in 1974 with Hondas, then to Suzukis, Gold Wings and ultimately Spyders.
74 Honda 360T (pair); 78 Suzuki GS 1000 (pair); 82 Honda Aspencade; 84 Honda 400; 87 Yamaha 1100; 99 Honda Valkyrie; 01 Suzuki Burgman(triked); 02 Honda GL 1800(triked); 10 Spyder RTSE; 11 Spyder RTSM; 12 Spyder RTSL (pair); 20 Spyder RTL (current)
Add oil
Is it Friday yet? ... Oh yeah, I forgot. I'm retired
Past bikes
2010 RS - Sold
2012 RT - Sold
2014 RT - Testing completed
2016 F3-T Audio package - Sold
GOS member (Girls On Spyders)
My friends RT 2012 w 3000 miles has an oil leak. It's at the dealer waiting for service. Anyone had this problem? Can it be serious?
It can be serious, Then again it might ''Not'' be serious... It depends..
Is it just blow-by from over filling the OIL tank, Thats ''Not'' serious,
More info would help....
Nahhhh...; it's not serious!
Harleys have been lea...
Oh! Hi Bobbo!
Oh! Hi Bobbo!
Yea, I heard that about Harleys, They must have figured that out when they built mine.
Over 20 thousand miles on my Tri, And i never added a drop of oil between oil changes
[5 thousand mile oil changes]
Oh! Hi Bobbo!
Can't be as bad as they used to be.
I had an AMF Harley... the AMF meant Always Messy Floors!
My buddie traded his2010 Harley for a new 2013 because the 10 sounded like it was going to fly apart and they couldn't seem to get it fixed.On our labor day weekend ride,his new one used 2 1/2 quarts of oil in 900 miles.He aint very happy.It goes into the shop tomorrow.I guess I shouldn't complain about the quart that the spyder used on that trp.
Oh! Hi Bobbo!
they're just marking their territories bob!
I think that this kid just found "Harley Country"
The Spyder is the only IC engine I've had to add oil to between changes since I sold my '81 C-10 Custom Deluxe... I forget to check it often.
Thanks for reminding me to do that and you just gave me an excuse to go for a ride to warm it up to operating temperature first.
JT
Big oil leaks are serious, small oil leaks are just annoying. If you check your oil every few hundred miles as specified, and don't have to add much (if any) each time, it is not serious. If you can't keep up or the oil pressure drops between changes, it is way too much. There is a service bulltetin for leaks at the water pump...either oil or water. That may be your friend's problem. Good to get it fixed either way.
