LED Display fading on A 2012 RT Limited
My LED display has started to fad to almost black in the upper and lower portions.I can just bearly see the large speed numbers.Has anyone had this problem????...............Montery
Mine malfunctioned a different way but the replacement cluster was a quick install.. Strange thing is they can't set the mileage when they replace so your bike starts over again at zero.. Only the buds computer knows the true mileage after that
BUDS does not know your actual mileage. It will not be stored anywhere when the cluster is replaced...unless you record it or the dealer does.
Led Display
Thanks for heads up on the mileage issue,I wouln't have thought about loosing a record of my milage
Thanks for your fast response,I have odered a new display through my dealer,no telling when it will get here....
No idea how they are getting away with this but that is a violation of federal vehicle regulations. The dealer or BRP needs to correct the odometer. A bike with an 'unknown mileage' title is worth significantly less at resale. I think you need to contact BRP and not take the dealers word for it.
In the auto business,years ago,before the mileage was stored in computers,this was the only way we could do it..We had an adhesive sticker we installed on the drivers door jam by the vin sticker...Then,technology advanced to where we had to down the car,call the mileage in when we ordered the cluster so they could burn it in and we received the cluster next day..Now,the cluster is just a display,when we change the computer,we can burn the mileage in..Couldn't tell you about current Federal law
Do you have a reference for that? What regulation number, page paragraph?
From everything I can find,there are state by state laws that have to be followed..But,there is a common thread..It is not the replacement that is against the law..It is the non-disclosure on odometer statements when selling a vehicle that will get you slapped with a fraud lawsuit..So,record keeping by the owner and dealer is a must to back up your statements..
*****Federal Law mandates that a person may repair or replace an odometer if the mileage registered on the replacement odometer remains the same as before the repair or replacement. Federal Law also prohibits disconnecting, resetting or altering an odometer with the intent to change the mileage registered by the odometer.*******
Just found this 2nd paragraph.....This was updated 8/2011 on the site I found it.
I don't know about elsewhere, but in Michigan if the odometer is swapped the original and replacement odometer readings are to be recorded on a sticker placed on the left side door pillar. That's pretty hard to do on a Spyder, so they instantly become "Actual Mileage Unknown" vehicles on the title if they are sold...even if you know the actual mileage. Unless you can prove it with the sticker signed and dated by the dealer, it doesn't exist. I'm on my fourth cluster, and the only one who knows my true mileage is me.
LED display fade
Just came back from a trip in the Gulf Coast heat. I was stuck in bumper to bumper traffic for 2 hours, bike got hotter than usual but did not overheat (surprisingly 103 degrees) but after 1 1/2 hours the digital display completely blacked out. Visually it returned after I got out of traffic and temperature came back to normal. Will check with "dealer" on this when I call for my "recall parts"
BRP has already commented on this "problem" here. The display is programmed to shut down under high heat conditions to protect it from failure. It may be irritating, inconvenient, and possibly a safety problem...but it is done by design.
mileage
you would think that with all the computers on the bike that the original mileage would be able to be pulled up with no problems, and being the dash is electronic it should be set back to the original mileage with just a computer
