front tires
got a 2010 rts and feel the front tires need replaced. are there any sizes that wont have problems with the nanny. also is there a brand and style that has been tested and reccomended by others that have tryed other sizes??
gary (τΏτ)
2010 can am spyder RTS-SE5 limited... #0058
timeless black
lighting by .......Big Dog Productions
pin striping by..Letterfly
exhaust by.......Spyder1attitude
strobe brake lights by...Custom Dynamics
K & N air filter
here's my list:
SPYDER TIRES
For front tires:
165/65R14 BARUM POLARIS 2
165/65R14 KLEBER KRISALP 3
165/65R14 UNIROYAL MS PLUS 5
165/65R14 SEMPERIT WINTER-GRIP
165/65R14 PIRELLI W190 SNOWCONTROL
165/65R14 GOODYEAR ULTRAGRIP 7
165/65R14 DUNLOP SP WINTER SPORT M3
165/65R14 CONTINENTAL TS 800
165/65R14 MICHELIN ALPIN A3
For rear tire:
-Federal 225/50R15 SS-595 91W
-Fulda 225/50R15 Cart extremo
-Michelin 225/50R15 PI.Exalto PE-2
-Toyo R888 225/50R15, approved for road, but not good under rain (aquaplanning).
-Pirelli P Zero A
-Dunlop SP9000
personally, i'm running KUMHO's up front, as well as the rear... with exceptional performance from both...
Front are: KUMHO Solus HM, P175/65R14, Rear is: KUMHO AST, 225/50R15....
Stay with the OEM size, and you'll NEVER have a problem...
Banged Up Member
Not only that, but with a 2010 RT-S you should get JUST around 24,000 miles on your front OEM's.
Chris
Chris
.... That may be true if you live in the land where a twisty is an On-Ramp...
but, where I live the twisties start a mile from my house... and, yes, my 2012 Ltd is starting to show serious wear on the front tires with only 10,000. mi!
I just ordered 2 of the few remaining Bridgestone Potenzas to be ready to replace the front tires next season. I already replaced the rear with a Toyo Proxes.
Have to agree..!!
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
I might try some different brands of tires; the sizes will stay as BRP intended...
changing brands
Originally Posted by SPYD3R
here's my list:
SPYDER TIRES
For front tires:
For rear tire:
-Pirelli P Zero A
-Dunlop SP9000
let me ask if you change a front tire and replace it with other than a OEM name should you than change both tires not to have two different brands on the front
NO BIKE AT THIS TIME
Senior MOMENTS Member
Different Brand Tires
I am not a tire expert by any means of the word.
I thing other more experienced people will chime in later on their expertise.
My suggestion would be that different brands would be ok given they are similar tread design (directional / highway / off road traction tires).
Most definitely the tires should be the same exact size in with and height.
Other than that you would have to look at the 2 different tread patterns
If it Feels Good, Do It !!
Too Much Is Just Enough !
2011 RS~S Pure Magnesium / Black ~M~
never, and i mean NEVER use two different front tires... not even a good idear for cars... tires are cheap enough...
Did you have the Bridgestone Potenzas on your list for front tires?
I know that firefly is using a set right now; he seems to like them!
They do come in the OEM sizing also...
I have the Potenzas which I had installed at 15000 miles in July.Since then I did a 4700 mile trip to Nova Scotia as well of lots of rydes and they are excellent.
ivor
AND THIS ONE
here's my list:
SPYDER TIRES
For front tires:
NEW SIZE YOKOHAMA " S " DRIVE , 185/55 -14 ...V -speed rated FRONT .......this tire has a HUGH footprint, but will fit in the fender 2008 thru 2012..Mike
For rear tire:
-Pirelli P Zero A
-Dunlop SP9000
I only got about 17 K out of my front tires and 20k out of the back, but I believe most vehicle people say never to use different brands on the "same axle".
It makes sense to me. No two tire brands are compounded the same and under extreme ( serve to avoid a wreck), they would react differently.
Just my thoughts
Oldmanzues
ok thanks all...i guess id better stay with oem sizes...now just deciding what brand i should use .......so many brands so so so
gary (τΏτ)
timeless black
K & N air filter
Like Jack did, I also ordered a pair of the few remaining Bridgestone Potenzas 165/65R14 tires from The Tire Rack and have them in hand and ready to be installed at my 14,600 mile service, which will be in another month at our current ryding rate.
My OEM tires have had an inherent wobble at about 42 mph since day one and I have finally decided to do away with them.
Carl
2012 White RT Limited and 2013 Yellow ST-S Think 3 .i.
2012 RT Tires P165/65-R14
I am also having trouble finding tires. Every time I look it up P165/65 - R15 comes up. Can I use that size? I thought the r-14/15 was the rim size.
Mike just told you that they do. I just searched Tire Rack and Amazon and found many of them.
https://www.tirerack.com/tires/TireS...earDiameter=14
There's another thread going on about trying to find the right size tires in a 14" wheel size. I did post in that one
that a quick Google search turned up a bunch of tires in 165/65-14.
Peggy and Howard
Hers: 2013 Spyder ST-S SM5
Tire Rack and Discount Tire both stock the Bridgestone Potenza 165/65R14. We also stock them and have installed many sets. Great tire for the older Spyders that have 14" wheels.
