Results 1 to 12 of 12
    Mar 2009
    Angry Stater and HID lights
    Hi guys
    wanted to ask you in regards to the HID lights . After i sent them u on my Spyder GS my battery started loosing power. took it in and they said my stater needs upgrading as they is not enough juice to charge my battery . They recommended i buy the RT stater as it has more power.
    They want to charge me 1200 dollars for the stater , the flywheel and the stater cap . WTH! its their own HID product and i have to pay for it to work properly?
    any ideas folks
    Jun 2013
    queens ny
    Default hid
    Quote Originally Posted by MMagic View Post
    Hi guys
    any ideas folks
    tell them you want your money back. if they sell them for the bike than they should work
    NO BIKE AT THIS TIME
    Default Something is amiss..!!
    I don't think the hid lighting has much to do with your stater unless you have a mess of other electrical add ons. If they suggest the RT stater you must have a heavy load. Check with ebay, amazon, cheapparts.com for staters. Replacing it is not that involved check around for labor rates..good luck..!!
    ​2012 RS sm5
    Mar 2008
    Allegan, MI
    Your dealer has made a misdiagnosis...or at least a mistaken correlation. Except at the moment of starting, HIDs generally take less juice than the OEM lights. Your problems are probably coincidental. Your charging system and your battery need to be tested. You can do these tests yourself, after a fashion. Before testing, check that the battery connections, at the battery, not the jump start terminals, are free of oxidation/corrosion and are tight. Poor battery connections prevent proper charging.
    Charging System:
    The system should read 13-14 volts with the engine running at 4000 rpm. If not, have the charging system thoroughly tested by a dealer. Note that low rpm operation can be ineffective in recharging the battery with a large accessory load.
    Battery ability to take a charge:
    If the charging system checks out, charge the battery on a maintainer (if possible) or by taking a long ride. A good battery should read 13 or more volts immediately after fully charging. If it reads less than 12.7, it needs to be replaced.
    Battery ability to hold a charge:
    After charging, let the battery sit off the charger for several hours to overnight. It should read 12.7 volts or higher in the morning. If less, charge it again and disconnect it overnight, then test again. If it is OK then, parasitic losses in the electrical system are pulling it down, such as from continuously powered accessories or component faullts. If it is still low after sitting disconnected, the battery needs to be replaced.
    Battery load test:
    A crude load test can be run by holding the throttle wide open to prevent starting, then taking a reading while cranking. It should read 10.0 volts or greater. If less, replace the battery or have a dealer confirm with a proper load test.
    I suspect you have a bad battery or connections if you are not chronically running at low (below 4000) rpm.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Mar 2009
    Quote Originally Posted by NancysToy View Post
    Charging System:
    Battery load test:
    Thanks a bunch guys and gals i will follow the test suggested this weekend
    although its a brand new battery from April of this year what type of batteries do you guys recommend .
    currently my bike has no other power accessories. other then the fog lights and the HIDs (BRP brand the ones for the spyder)
    i was reading somewhere that the ballasts can cause a drain if they are interfering with each other ( too Close to each other) and to mount them on the plastic not the metal frame any thoughts on that?
    Mar 2008
    Allegan, MI
    With a brand new battery, check your battery connections first, for sure...most common cause of failure. Also check that the rear frame ground (negative jump start terminal under the seat on a 2008-2012) is tight.
    -Scotty
    Just wanted to chime in: Had a 2008 GS which I had the dealer install the BRP factory HID's on. There were no issues about battery losing power or stator needing to be replaced. When I did the install, heck, RT's were still two years away.
    Very Active Member billrob71's Avatar
    Jun 2013
    Delaware
    The hid lights draw less power then the normal halogen bulbs.
    Your stator may have issues they can short and not charge but your headlights should not have done it.
    Default HID's
    "OR THEY ARE TRYING TO RIP YOU OFF"......It has happened ...I know I was ripped off by the" DEALER FROM H*LL" ...." LAND AIR " IN ESSEX JCT VT........go there at your own PERIL ....Mike
    Jul 2019
    Tennessee
    Did you ever figure out what the problem was?
    Idaho
    Quote Originally Posted by Azbizzle03 View Post
    Be careful about posting on old threads. This one is 6 years old and the OP hasn't been here since. Sometimes it is OK to bring up an old thread if you need info that anyone can provide about the original topic and don't have to have a response from the original posters.
    2014 Copper RTS
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    And when you use a touch screen to navigate, you need to be aware of where you touch the screen......or you may like an old post. And you can't undo it!
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
