R-35 Saddle Bags
Does anyone have a picture of what the saddle bags look like fully removed?
I've seen pictures with the frames still attached, but my understanding is using a small tool, the frame also disconnects from the Spyder.
If I were to add them, I'd probably use them on rare occasions and would rather leave them off a majority of the time...
Current Spyder:
"Can-Am Red"/Black 2015 Spyder F3-S with Heated Handle Grips, Gauge Spoiler, Fog Lights, 12V port, Akrapovic Exhaust, Driver and Passenger Backrests
Previous Spyder:
"Can-Am Red"/Black 2012 Spyder RS-S with Can-Am Comfort Seat, Comfort Grips, Rigid Saddle Bags, HID lights, Fog Lghts, 12V Accessory port, Trunk Liner, Hindle exhaust, Flash2Pass, SpyderPops BumpSkid, Side Grilles, Missing Air Dam, Air Management System, BajaRon Anti-Sway Bar
The frame does disconnect pretty easily. All that's different then (if memory serves) is a hole in each (l + r) side vent covers and the longer arm on the turn signal stalk. Turn signals look "factory" but are just moved on the higher stalk. I thought I'd take mine off when not using them, but I've actually kind of grown to like the looks. They seem to balance out the bike more to me.
Motorbike Professor
I don't have a picture, but all that shows is the turn signal extension "stalks" that are the rear mounts for the bag frame. Looks so close to stock you'd have to know what you were looking for to notice the difference. Even with the frames left in place and the bags removed the Spyder isn't ugly. The blake frames sorta disappear. The frames literally go on and off in 15 seconds using the special wrench that comes with the set. Don't forget if you buy the BRP bags and mounts, you have to buy the color panels separately. They are needed, so don't forget them.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
That's not my experience. They come off very easily and quickly but putting them back on can be a pita. The alignment of the stalks connecting point cause me to some times have to loosen the bolts holding the stalks in order to use the key to lock them in place and then re-tighten the mounting bolts.
2013 Pure Magnesium Spyder RS-SM5 Cal Sci medium clear windshield, R-35 hard sided saddlebags and fitments rack, 2013 Can-Am Spyder ST Limited Embroidered Stock Seat, Trunk opening spring, fire extinguisher, Passenger backrest and rack, Added side mirrors, Handlebar bag.
Does anyone know, did the R35 change in the last few years?
I'm watching some auctions with Part Number 219400127. It appears the current 2009-2012 model is listed everywhere as 219400301.
I'm wondering if they are identical... I could imagine a scenario where all they did was update documentation to include a new model year and had to change the part number because of it...
Current Spyder:
Previous Spyder:
Motorbike Professor
Loosen the body panels, back off all the mounting fasteners, then attach the frames. Then tighten all mounting fasteners securely. This will align the frames with the mounts. After that, they should install easily every time. Had the same problem with Nancy's until I did a realignment with the frames in place.
-Scotty
Motorbike Professor
If what you are watching is for the 2013 or the ST, they are different than the earlier ones...same bags, different mounts.
-Scotty
The number was different completely... Neither the current RS or 2013 RS/ST versions.
I called the store up, they said it was the 2009 model year, but that they should fit the 2012.
Is this true? Or do the 2012 units include something to make them work on the 2009?
Maybe its as simple as the older ones said GS and the newer ones had a new model because of new packaging and instructions saying RS?
Current Spyder:
Previous Spyder:
I'm going to have to do that myself. Left frame is fine but right is a brute. I rarely take them off so it has not been a high priority.
2018 F3 LIMITED
Motorbike Professor
The 2008 to 2012 GS and RS are the same and the bags for anything in that range should fit just fine. You are probably right about the GS designation being the difference in part numbers...or they made some other minor change. Nancy has the earliest version on her 2008.
-Scotty
I don't see how what you wrote will make a difference. The body panels (plastic tuppterware stuff) does not interfere with the alignment of the saddlebag rack. Attaching the frames (saddlebag rack) without having the saddlebags may not allow the saddlebags to be attached after everything is tight.
In theory having the saddlebags attached to the rack on the bike and then tightening down the racks attachment bolts to the bikes frame should insure that when you remove the bags they should go back on without any problem as at that point everything is all lined up. In reality this is not what happens for me. I suspect there is a part of the rack that is not straight and when the bolts are tightened it pulls (flexing the rack frame) the rack so that the bags no longer fit after they are removed, but I can not find the bad area.
Motorbike Professor
It is not the body panels that is the problem. It is the mounting bracket alignment (and tightness). The body has to be loosened to get at the bracket mounting screws. The instructions call for tightening the brackets down as they are installed, without the bag mounting carriers attached. This can leave them out of line. Furthermore, if the brackets aren't tightened securly, the alignment can change. The trick is to loosen the brackets, install the mounting carriers, then tighten the brackets securely. After that the frames should go on and off readily every time. You do not need to install the bags themselves when doing this, just the bag carriers. The bags themselves fit in slots in the carriers, and do not affect how the carriers mount to the Spyder. Several of us have experienced this problem and have cured it this way. It costs nothing but your time to try it.
-Scotty
For someone doing a fresh install, do you need to put the body panels on before doing that adjustment or can you put the carriers on while the body panels are off and get it all properly aligned?
Current Spyder:
Previous Spyder:
Motorbike Professor
They need to be left loose until the carriers are installed and the brackets are tightened into place. Basically, just install
the carriers before you tighten the fasteners, then proceed as instructed. There is something else missing in the instructions, but I don't remember what it is. Firefly had an instructive thread about the installation that points out that error.
-Scotty
A few of us had to notch out the cover on the left hand side where the bracket comes down. The bolt holes on the cover underneath the bike would not line up. I just kept trimming away to get it right. This procedure was not in my instructions, but I believe later it was added.
HAPPY SPYDER OWNER
GULF COAST SPYDERRYDERS
Could you take a picture of where you notched it out? What tool did you use to do so? I just bought a pair of these saddle bags from 2009 so it probably has the old instructions
Current Spyder:
Previous Spyder:
Motorbike Professor
You need to fit yours up to see if the panel needs to be modified. Most fit OK, and each fits a little differently, so if notching must be done to fit...it cannot be done ahead of time.
-Scotty
I can send you a pic when I get home. I'm offshore working right now. You could send ERAGS a pm. He had to notch out his also. Some people did not have to notch out at all. As far as taking the brackets off....if they are lined up correctly... they go on and off quickly. I've had mine on since 2009 and have not had to make any adjustments.
HAPPY SPYDER OWNER
Are the two saddle bags not identical? The right side saddle bag included the rear reflector installed, the left side saddle bag did not include a rear reflector. I'm still waiting for my color panels to show up, I don't know if its different, but that just seems odd to me.
Current Spyder:
Previous Spyder:
Motorbike Professor
The bags are identical (mirror images) the reflectors are held in by the color panels, so they can be lost if you ride before the panels are installed. they can also fall out on the garage floor or the packaging.
-Scotty
The reflector definitely isn't anywhere to be found, I haven't begun mounting anything yet.
Guess I'll have to demand my money back.
Current Spyder:
Previous Spyder:
Motorbike Professor
You can buy a replacement reflector from GIVI.
-Scotty
I'm assuming I'd have to call them? Their spare parts in their online store doesn't include reflectors.
I see they have 3 models of the V35, is there a particular one that Can-Am used?
Current Spyder:
Previous Spyder:
Motorbike Professor
I don't know...you'd have to call them. Other owners have reported here that they have obtained replacement reflectors from GIVI.
-Scotty
