...in the pink (Girls On Spyders)
Bummer..!!
Sadly seems when you stop in heat the "heat soak" syndrome kicks in. Then you get the high heat warning. Not always engine heat but air intake but still a pain. It's like you need to blow out the accumulated air under the tupper wear. Wonder if you go to the Kewl metal air cleaner and eliminating the oem air box could clear this problem up..?? Hope they can figure this out and you can trust your ryde....
2012 RS sm5
High Temps...Limp Mode
My 2010 Rt has never given me heat issues except for occasional hot right foot which Spyderpops corrected. Been out riding all summer here in Arkansas with temps in the 90's and even into triple digits and no overheating issues. What makes the 2013 so different?
#IamARyder #RideASpyder #CanAmSpyder
"High Temps...Limp Mode"
This shouldn't be "our" problem to fix !!!
BRP... are you listening ???
....and we're gonna ride, we're gonna ride.....
ride like the one-eyed Jack of Diamonds, with
the devil close behind,.....we're gonna ride....
2008 GS.....PE # 2888
Originally Posted by Chupaca
Sadly seems when you stop in heat, the "heat soak" syndrome kicks in. Then you get the high heat warning. Not always engine heat but air intake but still a pain. It's like you need to blow out the accumulated air under the tupperware.
I think that you're right on track, Gene.
Wherever that temperature sensor is under the bodywork; a bit of airflow to it might just make all of the difference!
Ok, here's the answer-
my son had a 2009 Buell Ulysses .
Great bike with that big air-cooled Harley Twin. Damn, I couldn't get on it, too tall for my short legs!
When ya shut that bike down, a fan at the rear of the motor would come on to cool things down a bit.
BRP, you listening.......
Bill
Using a blower to reduce operating temps & heat soak...
I have been testing use of a 12v blower under the Rh front fender on my RT with very good results. Recently I had a chance to get some good tests on the trip to Birmingham and more than once was able to pull down the temps under the tupperware by turning on the blower. Running the blower for a short period after shutoff puts a halt to heat soak... Replacing the stock airbox (with KewlMetal Kit) is probably a key part of this since a blower would have limited effect with that huge airbox still in place.
Using a dash gauge I installed demonstrates the drop in temps, no maybes about it! I live in Tennessee with moderate heat and the improvement is clear... .Texas or Florida would be a far better test!
I am still experimenting with postioning of the fan and am about to try a larger blower (4") to replace the one shown below...
Here's a couple of pics of what I have been testing so far...
I totally agree with you!
Sorry, don't take this the wrong way, but if we continue to try and solve this problem, BRP arn't going to make any effort to anti up and fix it, and the majority of us will suffer due to it, besides if your solution which seems to be a good one ends up causing some other problem, what happens to BRP Warranty. I'm not wanting to or should I invest more money to solve a major problem that is BRPS
The radiator fan on my 2010 usually runs, after the spyder if turned off for maybe 15 seconds. Not sure of the exact time but it does run. I have the bottom panels removed and utilize spyderpops block off plate (upper hole). I am sure this helps remove some of the heat build up when the machine is shut down. I have never had a heat issue while running or during shutdown,( just the typical right foot heat hence the blockoff plate). Does the fan run after shutdown on the 2013 models?? Just trying to figure out why there is such a difference in the models with the heat being trapped.
Happy Spyderlovers
yes...the fan runs after shutdown....30seconds....the bottom panel has been removed....the panels on each side...one that covers oil and opposite ...where they connect to upper panel has no vent...that open area on the earlier models...has been shut off....I asked at Owners event if I could just cut a vent in each or completely out...the techs told me no...but I would like to...just to let the hot air out
What have you got to lose by now? I would go ahead and put a 3 or 4 inch hole in each bottom plate.
Carl
2012 White RT Limited and 2013 Yellow ST-S Think 3 .i.
sorry
Charlene! so sorry to hear this! but what the heck the Atwood fan looks cheap looks like a good solution. wonder if it'll work if I keep my stock airbox on my 2012 RT?
2012 RT A&C bought new 42312 sold July 2018 56k miles currently driving a 2014 RTSE6 LTD bought October 2018 w 6800 miles nicely farkled
Carl
It's not bottom plate...that one is off.....it's the one that cover the oil tank and opposite .....I really want to...have sat out in the shop studying the panel....by husband, Mark says wait
2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
I sent you a PM that may help with ST heat soak
Sorry to hear of heat soak/limp mode problem on your ST. You have ridden in higher temps than 90 deg & no problems.
Time for BRP to help your dealer solve your ST heat problems !!!
Jim
Soooo... you'd rather be miserable, and wait for somebody else to come up with an idea?
Sea Doo GTI-SE 90 Jet Ski!!
I guess that I'm just stubborn... If my bike was having a problem that I could adequately address; I'd tackle it just so that I could ride it without having to complain about it...
Most of what has been suggested as ways to combat the heat issues are not invasive and completely reversible. BRP knows that this is an issue; they also know that a lot of folks are going to try to do what is necessary to be able to ride their bikes.
Voiding a warranty?? I doubt it...
HEAT ISSUES
Bob, I totally agree with you. BRP has known about these heat issues and melting of the MC caps on some 2013's, but to my knowledge has done nothing. If we riders were to wait for BRP, our whole riding season is shot! Many of us including myself have had success solving our own heat issues. My MC cap is now well insulated and the heat issues on my left leg have been solved. I am a happy Spyder rider. Thanks to others on this forum, we can solve a lot of issues.
Wellll not miserable, just frustated that the solution (not the idea) come from the right people in this case its BRP, wouldn't you agree.
they know (BRP) that a lot of folks are going to try----- I rest my case
