"Blackhole" at the rear of the saddle
I was changing my factory saddle out with a new aftermarket seat and I looked to see that dreaded blackhole and it appears to be just a depression so I didn't see the hole in the front of that depression until I hear the tink tink tink of my right seat bolt disappearing into the singularity. I nearly my pants envisioning a tear down of the entire rear portion of my Spyder. What I did find was the black hole ends in the rear tire wheel well and you can gently pry open an area where the panels come together and using a strong magnet (I have a number of neodymium magnets) the bolt slipped right out. Granted a non magnetic part will be much harder but a steel nut or bolt isn't that hard to retrieve. Trying from the top appears most difficult due to the angles. So bottom line trust the advice from the people on this board the black hole lives!
2010 RT Audio & Convenience
Ultimate "Tall Boy" seat
Elka stage1+R Shocks
BajaRon sway bar
Audio technica rear speakers
iPod mounted in trunk
Steel replacement radio mast
Ram "X" iPhone mount
black hole
i have very large hands for tight spots so i went and ordered a bunch of all different bolts and screws that belong on the bike just to have them for when they disappear
NO BIKE AT THIS TIME
Blackhole
When I work on my seat hinge bolts I cover the area with adhesive carpet cover. You can buy it at Home Depot, Lowe's, or a carpet supply house. It is sticky on one side so it won't slide around. Works great and holds down the frustration level.
Live and learn..!!
this is like playing "plinko" blind folded and the roadster is a bit large to shake hoping it will fall out. Glad you found what you lost..!!
2012 RS sm5
I am Lucky
On the street at the end of my driveway. There appears to be an anti black hole force. Days or weeks later the missing items appear there!!!!
2018 F3 LIMITED
If Amelia Earhart shows up; please let us know...
For the record, there ain't a shop towel large enough to cover the largest of all black holes in the Spyder.
You know, the one that sucks up all the money spent on payments, dealer service, farkling, gear, gas, etc., etc.
Silver 2010 RS SE5: Triple Play, Taillight, Brightsides, Fender Tips, Easy Risers; Evo Sway Bar; Airhawk R & Beadrider; latch springs; Grab-On grips; Crampbuster; 24" Madstad smoke windshield & deflectors; N-R round bag & soft saddlebags; BRP handlebar bag; Throttlemeister; Spyderpops Missing Air Dam & Air Mgmt System; Rivco driver & passenger boards & pegs; ISCI parking brake extension; Ultimate Midrider Seat w/both backrests, Fox Racing Shocks, Yoshi R-77 exhaust and a whole lotta love!
parts
Originally Posted by Pappazippy
....I hear the tink tink tink of my right seat bolt disappearing into the singularity.
Love that description! On that evidence I think my house has many singularities. Stuff goes missing all the time yet there is only my wife and I living here and neither of us are squirrels. Some of it gets found, like the napkin ring which disappeared for about 10 years, it turned up under the hi-fi cabinet in the lounge when it came time to replace the carpet, which is as far from the dining room as you can get! Amazing.
2011 RT-S SE5, Acumen Tempest Cat-1 Alarm, SmoothSpyder Belt Tensioner,
Autocom Super Pro Auto, Garmin Zumo 550 BT, 10amp Socket, Front Fender LED's,
Grip Puppies, Spyderpop Belt Guard, Nautilus Horn, Shortee Antenna, BajaRon's Swaybar,
Cree LED Day Running Lights.
Found out there is a black hole at the handlebars too.
USAF '69-'89 E7
Thailand/Vietnam 1972
