Page 1 of 4 1234 LastLast
Results 1 to 25 of 77
Thread: 2014's Coming
    Very Active Member Papa's Avatar
    Aug 2010
    Mundelein IL
    Default 2014's Coming
    So the dealers get to see the 2014's on September 14. What do you think will be announced (besides colors being shifted between models).
    Let the speculation begin.......
    Illinois Patriot Guard
    Founding member of Woodstock Spyder Ryders
    2014 RTS SE6 - White
    2010 RT/AC SE5 retired with 26,536 miles
    Jun 2013
    queens ny
    Default 2014
    it would be nice for a 6 th gear
    NO BIKE AT THIS TIME
    I have previously stated that I am guessing some new colors. Also, some possible body design changes (per the video that was shown in earlier thread).
    With all the difficulty on the 2013 ST's, I am thinking that they will not be introducing to much along the way of bigger and better. This is my way of saying probably not the bigger engine that many of us have been discussing for about three years now.
    All speculation on my part. I have a 50% chance of being right/wrong I guess.
    I have a feeling that the announcement will hit SL precisely when BRP says it will be okay. I am hoping we do not get into a lot of pre-hype this go around, it did not seem to bode well for the 2013 model year.
    Very Active Member Magdave's Avatar
    Jun 2013
    NE South Carolina
    Some better ventilation if the teaser pics are correct looks to be some extra vent holes in the front. I have also heard a 3 cylinder in the RT's.
    2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
    Did I hear somebody say "Flux Capacitor"?
    Very Active Member Pennyrick's Avatar
    Feb 2011
    Loganville, ga
    Quote Originally Posted by cuznjohn View Post
    why?
    Penny and Rick have owned many motorcycles starting in 1974 with Honda’s, then to Suzukis, Gold Wings and ultimately Spyders.
    ‘74 Honda 360T (pair); ‘78 Suzuki GS 1000 (pair); ‘’82 Honda Aspencade; ‘84 Honda 400; ‘87 Yamaha 1100; ‘99 Honda Valkyrie; ‘01 Suzuki Burgman(triked); ‘02 Honda GL 1800(triked); ‘10 Spyder RTSE; ‘11 Spyder RTSM; ‘12 Spyder RTSL (pair); ‘20 Spyder RTL (current)
    ...in the pink (Girls On Spyders) flamingobabe's Avatar
    May 2010
    Friendswood, Texas
    So where are the dealers meeting for Club????
    Quote Originally Posted by Papa View Post
    #IamARyder #RideASpyder #CanAmSpyder
    Jun 2013
    queens ny
    Default gears
    Quote Originally Posted by Double Trouble View Post
    why?
    because most of my bikes had them and i feel better millage would be achieved with a sixth gear
    Default Hard to say..!!
    like volkswagen and mini's they claim 47 changes and all you notice is different rim's and colors. Hopefully they get all the issues solved on the past models. I myself am very happy with what they have now.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Feb 2011
    Loganville, ga
    If you ride a Spyder correctly you move into fifth gear around 65-70 mph when the Rotax is in the lower end of it's optimum power band. If you had a sixth gear you would be upshifting at 85-90 mph and that doesn't make a whole lot of sense.
    I rarely use fifth gear unless we are running in a 70-75 speed limit zone and my fuel mileage runs around 31-33 mpg. If the Rotax is lugged down under 4,000 rpm you will find it uses more fuel than if you run it in the rpm range where it is most comfortable and performs best.
    A Spyder is not like most bikes.
    Invalid Emails
    Ormond Beach FL
    Cool
    No but they all get a new unbalanced wobblestor shaft assembly to add to the front wheel stability
    Very Active Member spydaman60's Avatar
    May 2012
    sussex, nj and tug hill, ny (west turin)
    why do you want a 6th gear? I hardly ever get out of 4th!
    Registered Users carajony's Avatar
    Dec 2012
    Central Florida,, Orlando
    arntufun
    Guest
    Sorry , but you are forgetting that if you add a 6th gear it would lower the gear ratio and the Spyders sweet spot would no longer be in the 5000 RPM range, it would be lower. With that said, it would in fact save fuel if a 6th gear was added because your motor would now spin at less RPM's in it's sweet spot. Class dismissed !!!!
    Feb 2011
    Loganville, ga
    Quote Originally Posted by arntufun View Post
    Okay, but you would then be changing the gear ratios all down the line instead of just adding a sixth gear. Would this added gear be the new 1:1? My understanding is that the optimum power band on the Rotax is between 4,800 and 6,000 rpm where it makes the most horsepower and torque... I think the torque begins to fall off earlier than 6,000 but the horsepower is still climbing. Reducing the RPM takes the engine away from it's sweet spot regardless of what gear you are in.
    Don't dismiss my class though, because I still need to learn more. Anyone have anything to add to this... Scotty????
    By the way, I am sorry we hijacked this thread.
    Aug 2008
    MA & NH
    Default Love our '13
    No issues other than a minor problem with our radio.
    Jun 2010
    Las Vegas
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Very Active Member bruiser's Avatar
    Eastern North Carolina
    Warp core.
    USAF '69-'89 E7
    Thailand/Vietnam 1972
    Member: Royal Order of Rat Bastards
    So, are we discussing SE or SM??
    USAF '69-'89 E7
    Very Active Member stewartj239's Avatar
    Jul 2013
    Syracuse, NY
    Quote Originally Posted by Sarge707 View Post
    Go Back to the 2012 and prior frame and FIX the heating problems they caused in the 2013,s because I want No part of a New Spyder until they make it RIGHT for the people who spent their hard earned $$$ on a 2013 and are having heat, melting, and fire related problems!!!!!!!!!!!!
    When people ask me about the Spyder and where to try it I tell them ALL about the 2013 problems because they have a right to know??
    The only issue I've had with our 2013 is with the Heim Joint - which broke. Is there a summary of other issues that I should be looking out for? We're at about the 2000 mile mark and everything is running great right now.
    Active Member willey's Avatar
    Jul 2013
    martinsburg,ohio
    Default 2013RTS
    We have a 2013RTS we now have 8200 trouble free miles on it.I was in 5th gear last night for the first time in a long time.We were on the free way running 75 mph.I never shift into 5th under 70mph.Why do I need a 6th gear?I love this bike,Its like driving a sports car.I often wonder if the folks that are knocking the 2013s own one or are just repeating what they read here.I can find nothing wrong with my 2013.Its a great bike.
    Very Active Member mrfats's Avatar
    Jul 2011
    Morgantown, WV
    Who buys a Spyder for the mileage?
    Invalid Emails
    Dec 2010
    Augusta Georgia
    Quote Originally Posted by mrfats View Post
    Nobody!
    Senior MOMENTS Member MrLooney's Avatar
    Sep 2012
    Salem, Oregon! BUDDAH'S Country
    Default I'M WAITIN
    I'm Waitin For The on this one
    If it Feels Good, Do It !!
    Too Much Is Just Enough !
    2011 RS~S Pure Magnesium / Black ~M~
    Nov 2012
    North Las Vegas, NV
    Want to go that 200mph on the speedo?
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
