Results 1 to 10 of 10
    Jun 2011
    lincoln de
    Default SE-5 shift problem
    Got left stranded today when my Spyder (SE-5) would not shift. The mechanism would not kick back so that you could shift to the next gear. After shutting down the bike I tried to restart, and because it was in gear I put foot on the brake and it went down to neutral. After that it would not shift up or down. Anyone else ever experience this problem or know how to fix it. I'd really appreciate any suggestions.
    Mar 2008
    Allegan, MI
    Look underneath the left side and see if the shift linkage came loose. Also check your oil level.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Active Member Y-me's Avatar
    Feb 2011
    NY
    I was having a similar problem with my old ryde which was a 10' RS-S SE5.
    When it would lock in gear while underway I would stop, shutdown and attempt to start in neutral using the brake with no luck.
    Even though they did not show any sign that they were loose or heat shifted I could get going again by pulling MAIN 1&2 relays and reinserting them.
    Then it would shift again for awhile.
    Jun 2011
    lincoln de
    Oil level is good, just had it changed not long ago. Also linkage was tight. Had to take linkage off to push rod in so that I could get into first gear. The rod does not go back into the mechanism. Had to drive about thirty miles in first gear to get home.
    Default SHIFTING
    Quote Originally Posted by baldeagle55 View Post
    Please keep us all posted as to what was done to fix this........MIKE
    Active Member 1VENOM's Avatar
    Oct 2009
    Virginia Beach, VA
    Catching a Yellow Jacket in your helmet at 65 mph can double your vocabulary
    Registered Users Bazeel's Avatar
    Mar 2013
    Virginia
    I know this is going to sound really lame, but did you ensure that the shift paddle was tight? There is a screw connecting it to the handlebar, and if it becomes loose it will allow some 'play' in the paddle, and cause major issues when shifting.
    A real biker doesn't care about your opinion on his lifestyle, or his choice of steed.
    Active Member PaSpyderRyder's Avatar
    Jun 2013
    Carlisle, PA
    Cool Same Problem
    I had the same problem with my 2011 RT, turned out a nut came off the shift linkage.
    Registered Users fyrertuck's Avatar
    Jun 2012
    Greenfield, MA
    oil level. When mine starts going funny it is the oil level.
    2012 Spyder RT-SE5 Gray 5-31-12 First 5,075 miles on 10-8-12
    NBV kit highway brackets with pegs Bajaron sway bar Lave exh wrap
    Grip Buddies AirHawk 2 His & Her's Walmart Front driving lights
    Spyderpops upper block off plate, belt guard, bump Skid
    BRP
    trailer hitch Napa 6 to 4 wire power converter Ram GPS upper dash
    Baker build air wings the New 3 piece full set Kewl Metal GPS hand bar
    Inspector Gadgets rear mudd flap type, Air deflectors upper & lower A-frame
    Mine too!
    Except for right now...
    1st to 2nd upshifts; it kind of "holds" for a moment before it seems to fully engage and let the rpm levels drop down for the next gear...
