Results 1 to 4 of 4
    Member 1957cushman's Avatar
    Feb 2013
    Maumelle, AR
    Default Throttle return hesitation on up shift SE5
    About 1 out of 20 times I up shift my 2012 RT SE5 transmission there is a longer hesitation for throttle return than normal. Any one else having this problem?
    Very Active Member ARCTIC's Avatar
    May 2012
    IOWA
    I think it's normal. Seems like a 2-3 shift it will bobble a little trying to get everything lined up. It happens in the 5,000- 5,500 rpm range.
    2017 Chevrolet Camaro SS convertible. 2017 GMC Sierra cc diesel. 2017 Arctic cat RR 137 ES
    Jul 2011
    Mitchell, Ontario, Canada
    If you twist the throttle to accelerate before the shift is complete the shift computer will take longer to feather in the clutch.
    2018 F3 LIMITED
    Sep 2011
    North Central Illinois
    Quote Originally Posted by 1957cushman View Post
    If I assume you are rolling-off the throttle when shifting, instead try using the manual's recommendation of not rolling-off the throttle when shifting the SE5, (and shift at higher rpm's (5,000+) and see if your shifts improve...)
    SL #7026
    VBA #652
    HOG #3935417
    2011 Viper-Red Spyder RT SE5 & Trailer
    2017 HD Ultra Limited
    Former Rides: 2014 HD Ultra Limited; '04 Kawa Nomad; '09 HD Ultra-Classic; and many Hondas through the years.
    Spyder Newbies Do's & Do Not's: http://www.spyderlovers.com/forums/s...-Spyder-owners
