Results 1 to 25 of 36
    Active Member kawakii's Avatar
    Apr 2011
    NH
    Default Led headlight worth it ?
    Is changing out our stock headlights to HID headlights worth it ?
    Is there a lot of difference between the normal headlight ( which are good in my opinion) to the HID headlights ?
    2013 RS-S Neutron Green/Black, Shark RSR2 helmet, Shark Evoline 3 helmet, Sena SMH20, Corbin Seat, Wheelchair Rack, TricLED fender lights, TricLed Underglow kit (green), Trunk Liner, STL Handlebars, Web Boards Driver Floorboards, backrest, BRP Saddlebags, ISCI Handbrake
    Aug 2012
    Boston, MA
    Default HID headlight
    You will not regret installing this headlight upgrade! I also changed the foglights on my RT to HID.
    kriemer
    Very Active Member DriftersWay's Avatar
    Jun 2013
    Uniontown, Pa
    Is this a simple change of the bulb or do you have to change out the whole light assembly.
    2022 F3 Limited , Monolith Black / Dark
    Mar 2008
    Allegan, MI
    Quote Originally Posted by DriftersWay View Post
    There is more to it than a simple bulb change.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Jun 2013
    Uniontown, Pa
    I was afraid you was going to say that. Sounds like a winter job. Thanks
    Jan 2013
    lancater ohio
    Hid are nice but with led all you do is change the bulb.......look for a set of them
    Registered Users 5PYD3R's Avatar
    Jul 2011
    Bay City, Michigan
    The HID kit is VERY nice. I picked them up last year from a dealer on mark down. Dont regret it at all. If your mechanically inclined, it is not a bad install at all. Did mine in just over an hour.
    Mar 2008
    Allegan, MI
    Quote Originally Posted by greatrides View Post
    LEDs do not project enough to be used as headlights at currently available US technology levels. HIDs are the only source that will cast more light down the road.
    -Scotty
    rayeade
    Guest
    Harley bikes have led headlights as an option but they are expensive.
    Mar 2013
    Sorry, but I have to disagree with you. If done correctly LED headlights do project as far if not farther then HID's.
    I have had the HID in my Harley and now I have the LED headlight in the Harley. The LED is great, but spendy. The thing I like about the LED is that it is self contained where as the HID has ballest for each light that you need to find a place for and I had two ballests go out and take out the bulbs which were expensive to replace.
    That being said I am not aware of true LED headlights for the Spyder.
    2015 F3S , White & Blue
    Very Active Member ARCTIC's Avatar
    May 2012
    IOWA
    The HID headlights are 3x brighter!!! I can see so much better Last night on our ride home we stopped at a parking lot before everyone went their own separate ways and I got the "holy **** those headlights are so damn bright".
    2017 Chevrolet Camaro SS convertible. 2017 GMC Sierra cc diesel. 2017 Arctic cat RR 137 ES
    May 2012
    IOWA
    Quote Originally Posted by PW2013STL View Post
    There is no LED headlights that have the long distance projection power that HID has....... PERIOD. I've researched it thoroughly.
    Apr 2011
    NH
    Thanks everyone. Seeing some places have them marked down to under 400.00 from 900.00 originally I was thinking it might be time to do them or at least buy the kit and put away for a winter project.
    Apr 2011
    NH
    Does anyone know where to buy LED bulbs that will fit in the current Spyder headlights ? I didn't know this may be an option. Our Harley has led headlights and works great.
    Invalid Emails
    Jun 2010
    Jackson, Michigan
    $400.00...You're gonna steal them....far better than the stock set-up...No comparison
    Aug 2013
    Rochester NY
    Default Where to order LED headlight bulb
    Hi,
    I am a new spyder RT owner, so far 200 miles and loving every minute of it. This is a very interesting thread. I love HID however the kits are big time expensive. Does anyone have a link or manufacturer part number for a LED bulb for the spyder?
    Thanks,
    Mike McCormick
    May 2012
    IOWA
    Quote Originally Posted by kawakii View Post
    There's no such kit for putting LED in a spyder headlight. The Harleys work because they have a big round headlight that can be replaced with a fixture that has tons of LED elements in it. The small surface area of the projector beams won't allow for enough LED elements to provide necessary light. U shoulda bought one of those kits that I pm'd you about $349 shipped is Damn near free. I'm pretty sure the last kit was purchased a few days ago but out wouldn't hurt to check.
    Quote Originally Posted by Littlebadwolf View Post
    x2
    Quote Originally Posted by mike3119 View Post
    Hi,
    Thanks,
    Mike McCormick
    It would be interesting if someone should develop a kit for the RT. Maybe one of our vendors would take on this task
    Registered Users XenonDepot's Avatar
    May 2011
    Canada
    Hi,
    Thanks,
    Mike McCormick
    Unfortunately LED bulbs would not provide enough light output to be used as your low beams. Currently our brightest LED bulb is rated at 750 lumen which is still less than a halogen bulb. An HID kit would be your best option still. If you use the Spyder Lovers forum coupon code "SL" you can get a XenonDepot HID kit as low as $89.99 shipped.
    Let me know if you have any additional questions.
    Danny
    Registered Users SpydherLuv's Avatar
    Mar 2011
    Fair Oaks, CA
    Is it safe to assume that my RT would still suffer from the effects of the headlight shutter system with an HID kit installed?
    May 2012
    IOWA
    Quote Originally Posted by SpydherLuv View Post
    The shutters stay in place as your hi/lo beam switch
    Mar 2011
    Fair Oaks, CA
    That's what I thought, thanks Arctic. So, basically, the "winking" or "bright lights" affect doesn't go away with HID's, it just makes it brighter, right?
    Mar 2008
    Allegan, MI
    That would be true...only changes in headlight aiming and riding with brights in the daytime can affect the "winking". Having the HID's can make the light do its job well enough that owners are more inclined to lower the aim, however, and still feel they see far enough ahead.
    -Scotty
    Aug 2013
    Does all this only apply to RT Spyders?
    Or are all Spyder headlights basically the same?
    In other words, will these kits work on my measly old ST-S ? LOL
    Mar 2008
    Allegan, MI
    Quote Originally Posted by SNOOPY View Post
    This applies to the RS and RT. The ST does not have the projector lenses and shutters. You may be able to fit some sort of HID replacement, but you will need to find the standard bulb number to get the right one and there may not be a plug-n-play kit yet. Probably a dual-element bulb, but I don't know which one.
    -Scotty
    Apr 2011
    NH
    Thanks for everyone's input. We got the BRP HID kit on clearance for 349.00 instead of 925.00 so my significant other bought them as my birthday present
