Page 1 of 2 12 LastLast
Results 1 to 25 of 48
    May 2013
    Stanton, ca
    Default Check / Fix your BRP Pressure Gauge
    Hey folks, so I tried to use my supplied pressure gauge (comes in the tool bag under the seat) and found it to act weird and not reliable. Here were the symptoms I had.
    1) If I held the gauge onto the valve stem the pressure reading would just keep climbing! e.g. when reading the front tire I would get 17.5 initial reading but as I held the gauge on the steam longer, it would keep climbing to like 37 PSI.
    2) Comparing what it reads initially and comparing it to the very common "pen" style pressure gauge, it consistently read about 2-3 PSI less than the pen style gauge.
    So something was up and I could not trust the gauge! I decided to take it apart and see what's up.
    See the attached pictures.
    I found the metal strap held on by 2 screws was not tight! This strap holds the pressure sensor inside the chamber and against the O-ring.
    Additionally I found the rubber O-ring was displaced and not in the grove but instead tipped inside the pressure chamber.
    Bottom line the pressure chamber was leaking air and thus causing the reading to be inaccurate and flakey operation.
    Hope this helps someone,
    Bob
    2011 RT-S SM5 - Black
    Default Good to know..!!
    haven't used the gauge as yet but will check it out...thanks for the post and solution..!!
    ​2012 RS sm5
    Very good information. Thank you. And this is supposed to keep our multi $K machine running safely?
    Bob
    YOu are one FEARLESS uhhh...guy!
    Now that you've got it back together;s it giving you accurate and repeatable reading?
    May 2013
    Stanton, ca
    Yes it is working and matches my other pen style gauge. I would not have posted the fix unless it worked.
    Bob
    You just knew that I had to ask...
    Spyderless Member
    Dec 2008
    north/central n.j.
    The Spyder was the only Trike/Bike I bought that came with a air gauge, First time I used it I realized it wasn't very accurate, So it stayed where it belonged in the back of my tool cabinet where the sun never reaches... I have 3 other gauges, And they all read different, So I throw out the low and high reading and use the middle one....
    May 2013
    Stanton, ca
    Confucius says:
    "Man with too many pressure gauges, never knows the tire pressure".
    Bob
    I only use the BuRP gauge...
    I've got two others, and since they never agree; I just pick and use one consistently for a vehicle. (As long as the tires don't seem to mind the choice!)
    Very Active Member jthornton's Avatar
    Feb 2013
    Poplar Bluff, MO
    Are any of the gauges you guys use repeatable enough to get the tire pressure difference between the front tires within 0.5 psig as stated in the manual?
    I gave up trying to find a gauge with a hysteresis below 0.5 psig to balance the tire pressure and just fill them both at the same time now. Even if I'm off by 2 lbs at least the Spyder goes straight down the highway when both front tires are at the same pressure.
    JT
    May 2013
    Stanton, ca
    No.... I have 3 pen style gauges and as you state they are off by about .5 PSI. But at least I got my Spyder gauge to be in the same range as those! It was way off before I took it apart.
    I think the tell tale sign if the gauge is not working right is if you hold it on the stem it keeps climbing up way past the correct pressure! This is due to the chamber leaking air around the rubber o-ring seal.
    I think I am going to go pick up a quality expanded scale dial pressure gauge and just stick with that.
    Bob
    John,
    Tell us all a little bit more about your solution...
    washington state
    This is one of the reason why I like this Forum and members like you.
    2012 Spyder RT SE5 Brake pedal mod
    Feb 2013
    Poplar Bluff, MO
    John,
    Bob, after some research I found some quick disconnects that work on the Spyder valve stems. Actually that was the last thing I found... anyhow I got a cross and a schrader valve and a couple of hoses and a gauge. At first I had clip on air chucks but they would hang up on removal which means you lost whatever you gained by filling both tires at the same time. Then finally I found some air chucks that did not hang up when you removed them. On my rig I used a 0-30 psig gauge with a 4" dial (so I could see it without my glasses) for easy reading. This meant that I could not use 100 psig shop air to inflate the front tires with but that is no problem, I just use my bicycle tire pump. It only takes a few seconds to plug the rig in and a couple of pumps on the bicycle pump and I'm 18 psig on both tires. I made one for Cruzr Joe without the gauge so he could use shop air and a regular air gauge. On the one with the gauge you can see the clip on air chucks that I replaced with the quick connect chucks.
    JT
    Feb 2013
    Poplar Bluff, MO
    Quote Originally Posted by finless View Post
    Bob
    I'll have to take another look at my Spyder gauge and see if I can fix it just for backup on the road. Mine was DOA.
    JT
    Are you going to produce these for sale???
    (I like the big gauge; for the same reason as you do! )
    Active Member dshogman's Avatar
    Jun 2011
    Texas
    Me too......... I would buy one just to get rid of the PITA factor of checking the tires.
    David Horn, Kerrville, TX
    Fulltime RVer
    2014 Phaeton 40ft motorhome w/TandemTow trailer
    2014 Mazda CX5 (Soul Red)
    Ringo, the travelin' canine (just black and tan)
    ohhh... you've still got to check them!
    Feb 2013
    Poplar Bluff, MO
    I have considered that Bob, if I get a hose crimping machine. Otherwise all the parts are off the shelf items and anyone with an adjustable wrench could build one.
    JT
    May 2013
    Stanton, ca
    Quote Originally Posted by jthornton View Post
    JT
    You sure about that
    I think some folks may not want to hassle with DIY and just buy the thing!
    Bob
    Western Kentucky
    Default BRP pressure gauge
    Mine did not work when it was new...I guess I should take it to the dealer for a replacement...especially since it's only 3 months old!
    Feb 2013
    Poplar Bluff, MO
    You sure about that
    Bob
    I think your right actually, I just get caught up in my little bubble where I do/fix/make everything.
    That explains why I made one for Cruzr Joe...
    JT
    You sure about that
    Bob
    You read my mind... which is about like reading a comic book!
    John,
    You let me know when the time is right...
    Feb 2013
    Poplar Bluff, MO
    John,
    Ok, will do.
    JT
    Thanks!
    But does this count as a farkle, or a tool?
