OIL CHANGE, that will be $$$.$$
Good evening All,
How much is one expected to pay for an oil change from a dealer ?
Dom
No matter what you do with your Spyder or Can Am you will have to pay a large fee. I've not done it at a dealer and I more than likely will not. I will be changing to AMSOIL here on my next change. What bike you have? Most seem to be simple.
My dealer charged me slightly over 200. The labor rate was 95/hr at 1.5 hours. I will prolly change my own next time.
17 F3 Limited (Pearl White), Sena 10C intercom, X Grip iPhone mount, IPS key, spyder to go cup holder, Lamonster Highway Center Lane, TricLED engine lights, TricLED night rider, LS2 Helmets, Lamonster Bypass pipe, 2 Brothers Exhaust, mirror relocator kit, Bluetooth radio module, OEM Backrest, Rear LED Light Kit
Buy your parts from Bajaron and obtain whatever oil you wish. I chose Amsoil. Do it yourself and you will have less than $100 into it and the satisfaction that it is done right. The dealers near me didn't know to check the strainer. Good luck. This site offers support to get through your first oil change, and other minor maintenance work.
bajaron for filters, shell T6 rotela oil. used it in Honda, meanstreak and now my rt, never looked back, $5 a quart ful synthetic at auto zone or walmart
I just got quotes today
One dealer quoted 140.00, while the second quoted 225.00....
2016 F3T SE Pearl White
Purple powder coated wheels
Performance sway bar
LED headlights and fog lights
Short Reach handlebars
2010 RT A/C SE traded in
Originally Posted by poordom
Good evening All,
Dom
It's like real estate! Location, location location of the dealer in this instance will determine $
Gotta say..!!
oil changes are expensive on these roadsters. At least at the dealers with high labor rates. I get the kits for our RS at $66.00 online which has the filter, o-ring, two crush washers a gallon+1Qt brp semi-synthetic oil. Even at that add the $95.00 (per hour) labor rate and your at $161.00. This is the sm5 with only the engine oil filter. This could be less using non brp products...no jiffy lube for roadsters..!!
2012 RS sm5
Oil change costs
Good evening All,
Dom
Had the Dealer in Fort Myers Florida want over 400.00 to do an oil change on my 2012 RT, this is totally ridiculous ! Can't Can-Am adjust this ?
Western WI they get about $240 for oil change. The dealer I went to did more than just change oil though. They always update BUD's, change oil, and trans filter if part of maintenance required, always adjust belt tension, check the brakes, coolant, air filter, fuel filter, ext. Flat rate 240 but sometimes the actual hrs could come in less, some times actual hrs could be more. All washes out at the end. At least that way there were no surprises as to what my bill was.
2012 RT Limited: Utopia back rest, SealBoards, and Shark bluetooth communicators on VCAN Woody helmets.
John, about every time that Rotella is mentioned one or more folks say it can cause clutch slipping, and way back I believe someone said it DID cause slipping. I'm a fan of Rotella also but haven't used because of this. Just curious as to how many miles you've put on yours with that oil?
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
My dealer tells me 1/2 hour labor for a simple oil-change. So with the $66 kit off the shelf, that would be $106. But I've never done this yet... first change was at the 600 mile service, second at the 4,600 mile service, for around $265 each time at their $80/hour labor charge. Both were the standard "services" called for in the manual.
Can Am doesn't have control over the dealer service departments. It's like car dealers, I took my car in for the first oil change (it was new) and also ask them to rotate the tires, 98.00 dollars! I couldn't believe it, they said the oil was special and I told them I wasn't stupid. The next oil changes have been at an independent garage, the last one with tire rotation was, 36.00 dollars. (when tires are bought from this business you get free rotation for life). Point being, shop around and do what you can yourself. On my Spyder I change my oil and do minor adjustments, belt etc.
Happy Spyderlovers
SM OIL ? ? ?
John, I may be mis-taken but the last time I checked T6 Rotella is an " SM " oil...........and that's a NO NO ................Mike .....If you want to save MONEY on oil changes PENNZOIL PLATINUM PLUS is Full Syn and about $25 at Walmart......just sayin...annnnnnd it's not " SM "
Oil Change Cost
Dealer in this area charged $275.00 for oil change on RT-S.
Reese
2010 RT-S SE5 Orbital Blue
+1....I buy the kits as well and do the oil change myself. Changing oil in the Spyder is easier than doing it on the car. The oil change kits make it simple and just flat out work...no reason to over think an oil change. I'm not one to experiment with different oils when the recommended kit is as inexpensive as it is.
I do my own but I don't enjoy it. Laying on the ground with the bugs and little stones. Agh! I buy the oil and the crankcase filter. washers, and o-rings from BajaRon. The tranny filter is OEM and not available on the outside yet. Here's a tip, buy your oil now. You can always take it to the dealer with you. Oh, and btw, any REPUTABLE bike shop can change the oil. It doesn't need be a BRP dealer. Especially when the nearest dealer is a half hour away and the nearest bike shop is two minutes as in my case. I can't check the BUDS or belt at home, neither can they.
Happy Spyder Owner
States visited on the Spyder.
And if we live life without a passion, then we're not living.
Oil Change and Service
My dealer sales his own service program called Pre Paid Maintenance (PPM). This is a set contract that extends through the entire maintenance as recommended by BRP. It covers all labor, and oil and filters along with all the labor involved with inspections, corrections, Service Bulletins, Recalls, etc. It is steep up front, nearing $2,000, but it is well worth it when stretched out over three years. Of course it is good only at his dealerships.
My dealer said would run about $200 plus parts for the first one. I'm gonna have them do the first one just to make sure everything is ok and the big one at 14,000 which will be years from now, other then that I'm more then capable of doing all the others
Originally Posted by unclejay
If te BRP kits contain semi-synthetic, it is the wrong oil. Amsoil for me. You can get the kits minus oil on eBay
Please enlighten us with some factual documentation that the BRP oil, with the BRP label, in the BRP box, mentioned in the BRP manual, sold by the BRP dealer, is the "wrong oil" in a BRP product.
What kind of oil ???
Oldmanzues
If you have the dealer perform an oil change service--most experience the $250-$300 price range. My dealer currently charges $110 per hour. The $250 plus for an oil change scarred me the first time, as I had never owned a vehicle where the upkeep was so expensive.
The 14,000 mile service has to do with valve check and adjustments. Many people let the first one go because most have found no need at that point. That service adds about $800 to whatever else you are having done. I had my last valve check at 28,000 and nothing needed to be done. The mechanic failed to put a new gasket in and that led to an oil leak. The dealer fixed that issue and did not charge me for parts or labor to undo the mistake. When it comes to valve check--you decide what to do though.
