Results 1 to 20 of 20
Thread: A Part Missing?
    Invalid Emails
    May 2013
    Jacksonville TX
    Default A Part Missing?
    I have driven my 600 miles since I got. I was looking at it today and noticed both sides down where your foot would be pointing on the left side is a black grill but on the right side is just open where the grill on the left side. Is this the way it is or is the piece missing?
    Jun 2010
    Las Vegas
    There is no grill on the right side. That is the way it is meant to be. You can buy an aftermarket set of grilles from spyderpops.com if you just can't live with it not matching.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Nov 2012
    Albuquerque, NM
    No part missing, I thought that too and asked the dealer about it. The dealer said that most new owners ask that very question so you are not alone.
    Active Member telespec's Avatar
    Nov 2012
    Houston, TX
    Default Grill
    You mention left but you're talking about right, their not one for right that comes from BRP.
    2012 RTS SE5
    SpyderPops BumpSkid Guard
    PowerSportsWraps Phoenix Bird
    GloRyder Lights for Front Wheels with Remote
    Lamonster IPS
    PowerSportsWraps RT Dash Kit Woodgrain
    Custom Dynamics Chrome License Plate Frame
    Shortee Antenna
    Knight Riderz Light Bar Blue
    Front and Back Spyder Decal
    Volt Meter
    Digital Clock
    Wolo Bad Boy Horn
    Lamonster LED Headlights and Fog Lights
    LED Tip Lights
    LED Light Strips for Front Fenders
    LED Light Strips for Left and Right Turn Signal
    Third Brake Light for Rear
    2012 RTS , Blue
    Oct 2009
    Virginia Beach, VA
    Our venders here have inserts for the area your talking about. Here's one; http://www.customdynamics.com/can_am...r_Inlet_Covers
    Here is another; http://www.esicycleproducts.com/spyd...letcovers.html, Hope this helps.
    Invalid Emails
    May 2013
    Jacksonville TX
    Default Thanks a lot
    Thanks a lot guys I guess I will quit looking. Most people ask the dealer about the grill. I didn't notice it for a month. I never get on form the side, old cowboy training. I really should not be left alone.
    Thanks again
    Spyderless Member
    Dec 2008
    north/central n.j.
    Quote Originally Posted by Doug I View Post
    Thanks again
    Think of it as a speed hole,
    No restriction (grill) allows for more air flow!
    Default Maybe..!!
    They should add it to the manual..natural question seeing as there are grilles everywhere else..!!
    Invalid Emails
    Dec 2010
    Augusta Georgia
    I took the left side off on my RT and then both sides looked the same with marginal improvement in airflow.
    Danbury Connecticut
    Default Is this the one you mean ?
    IBA #47122
    2020 RT Limited Asphalt Grey
    Is that one from Kewlmetal?
    Active Member bobnaquin's Avatar
    Nov 2011
    St George UTah
    It is that way by design. You can add a piece there but recognize it will likely make the machine run hotter.
    Dec 2010
    Telford, UK
    It would be doing a new Spyder owner a service if the dealership pointed out that nothing is missing from the empty space on the RHS. I was caught out thinking I had lost the grill riding my new machine home from the dealership.
    Danbury Connecticut
    No. That is a BRP OEM grill.
    Do you remember when BRP did the panel changeout for the oil filter access?
    The left grill was replaced as part of that campaign. There were oodles of left grills available that the dealers could give away.
    I reworked one so it would fit on the right side. Consequently, it is shaped and has the same contour as the left side grill.
    Both Kewlmetal and ESI panels are flat.
    IBA #47122
    Ooh...
    If you come across another "excess" BRP grille...
    Spyderless Member
    Dec 2008
    north/central n.j.
    They'll add that to the manual, When they add that the gas tank is 6 gal. not 6.6 gal....
    Welcome to the growing membership in the "my right grill is missing" club. I am guessing most of us have asked that question. When I bought my new 2008, I took a special "stealth" visit to my dealer to check out the other Spyders. This was in order to make sure they did not have grills on the right side.
    that it would not hurt to put the information in the manual--for those that read it, of course. Or, when the vehicle is delivered, make it a part of the "show the new " introduction.
    This one pops up so often, that the dealerships really should try to point out the lack of the grille as part of the delivery process...
    Invalid Emails
    May 2013
    Jacksonville TX
    Default Not Missing part.
    After that many responses it makes us newbies feel good that there are that people out there willing to take time to explain things to us. And not make us feel stupid. But akspyderman mentioned the dealer explaining things to you when he delivered it to you. I don't seem to remember anything about that. Unless they explain it to the original buyer that full fills that obligation I think.
