Page 1 of 2 12 LastLast
Results 1 to 25 of 36
Thread: Is this normal?
    Mar 2013
    Marion, Arkansas
    Default Is this normal?
    I recently purchased a 2012 RT-S new from a dealer back in March. My question to all Rt owners, is it normal after the bike maybe sits a week or more when I start the bike there is some blue smoke, probably oil burning, coming out the exhaust pipe. After a few moments the blue smoke quits and everything is fine. I hope this is a normal thing and not a problem coming up down the road. If the bike has been running and turn it off like when your getting gas or refreshments and go and start the bike back up, there is no blue smoke on restart. The bike has over 2000 miles on it and I don't run it hard but I am shifting at the correct RPM's, around 5000. Should I be concerned or is this just normal burn off of oil after sitting for a week or more? Thanks for all reply's.
    Invalid Emails
    May 2011
    Tulsa Oklahoma
    Hope not, mine is an 09 with 30k on the clock, no smoke at any time.
    May 2013
    Hollister,Ca.
    No smoking on my wife's 2011 with 1800 miles.Only condensation when could.
    Aug 2007
    Greeneville, TN
    Nope...
    Invalid Emails
    Ormond Beach FL
    Cool Blue smoke
    If the engine only has 2,000 miles it should not smoke (to young) I would mention it to your servicing dealer at first chance. What is telling you that when it is setting that your having minor oil seeping into the cylinders during the sitting period.
    This could be indicative of leaking piston rings (no seated in yet, or one maybe broken during the engine assembly procedure. A third option could be leaky valve guides or valve guide seals.
    Keep a close eye on your oil levels in the interim. I would almost be willing to bet the dealer says keep track of your oil levels and continue to ride and enjoy for another 1,000 miles or so giving all the components longer to seat themselves.
    western Colorado
    Quote Originally Posted by Ex-Rocket View Post
    Nope not normal...you need to RYde it more
    Very Active Member grumpybob's Avatar
    Nov 2009
    Fulton NY
    Nope, not with my 2012 RT, Probably only have 2K on it.
    Will keep watching. Can't add more here except no smoke on four different 's.
    Mar 2008
    Allegan, MI
    Are you sure it is blue smoke and not just steam? It isn't uncommon to see a little steam from condensed moisure in the exhaust system immediately after startup under some climatic conditions. If it truly is smoke, it indicates that you have a problem (like valve guides).....or someone has stuffed a BMR boxer motor in your chassis.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Blue smoke... not the best thing to see upon startup.
    Bob and Roger have you covered for suggestions to give the dealer...
    Good Luck; please let us know what is found!
    Mar 2013
    Marion, Arkansas
    Quote Originally Posted by NancysToy View Post
    Yes it is blue smoke for sure. I have own many bikes over the years and I know the difference between condensation and blue smoke. The blue smoke will stay blue in the air for awhile and then slowly disappear when it mixes with normal air. I did check the oil level and did have to add maybe a 1/4 quart to bring it back up to full. I have put right around 1500 miles on the bike since the dealership did my 600 mile service. I have read here that isn't excessive amount for these bikes as they do consume some oil. Does that amount of oil sound out of line or not?
    Mar 2008
    Allegan, MI
    That's not unusual oil usage for a Spyder, I'm afraid. Shouldn't be seeing the oil smoke on startup unless oil is being pulled into the cylinders on shutdown. That is usually a result of bad valve guides/seals or bad oil drainage from the heads. I'd run it by the dealer. It might be easiest to video it happening, otherwise you would have to leave it at the dealer overnight. Be sure to stress that it is persistent and lingering. I wouldn't have asked had I known.
    -Scotty
    Very Active Member DR Buck's Avatar
    Apr 2012
    Fauquier County VA - Virginia's most carefully pronounced county.
    Quote Originally Posted by Rattigan_Roger View Post
    Conjecture:
    If you were over the line on oil the blue smoke might be residual oil in the airbox burning off.
    2012 RT Limited - Pearl White
    My Mods -
    http://www.spyderlovers.com/forums/showthread.php?39494-DR-Buck-s-2012-RT-Limited-Mods
    2012 RT Limited , Full size brake peddel White w/Red Highlights
    Aug 2007
    Greeneville, TN
    Most likely valve guides, though that is not normal with the mileage that you have.
    Oil in the air box does not usually get to the throttle bodies and certainly wouldn't get there overnight as the Spyder sat parked.
    It could be something else, even stuck oil ring, but you won't know till you take it to the dealership and get it sorted out. Chances are it will only get worse if you don't do anything.
    Let us know what you find.
    Active Member Tim Pringle's Avatar
    Dec 2011
    Huntsville AL
    Sounds to me like too much fuel was dumped in the cylinders on start up since the blue smoke cleared up. The same thing will happen when you hold the throttle wide open to clear a flooded carburetor. I've seen this occur on several older bikes I have owned.
    Mar 2013
    Marion, Arkansas
    I will be taking the Spyder to the dealership this weekend. Right now I'm not a happy camper.
    Registered Users Grandpa Spyder's Avatar
    Feb 2012
    Portsmouth, Va.
    I don't know, mine has never sat that long.
    Grandpa Spyder 2015 F3S
    May God Bless All Of those Who Serve Our Country
    Life is Good
    Link to all of my Mods with pictures, http://www.spyderlovers.com/forums/s...-with-pictures
    Active Member doublenaughtspy's Avatar
    Jun 2013
    north carolina
    Default up in smoke
    Purchased my spyder in April 13 now have 4800 miles no smoke. Have dealer check it ASAP or it may cost you big time>
    Quote Originally Posted by Grandpa Spyder View Post
    Oh... now that's just bragging!
    Mar 2013
    Marion, Arkansas
    Well this morning I took a short video with my camera of the bike starting up and some blue smoke upon start up. The bike hasn't been started since last weekend. I then rode to my dealership which is probably about 40 miles away. Talked to the service manager about the blue smoke concern and also mentioned about the flopping gas gauge. I offered to show him the video of my bike starting up but he didn't want to see it. What he did say though was to email the video showing the blue smoke on start up and to also video the gas gauge flopping to him. He said he would then contract BRP and get a case #. Does this all sound to be the correct procedure in getting a case # from BRP? Or is he just trying to blow this off or what? Or should I be looking for another dealership? I'm going to send the video of both items to him and see if I get a case # or not, and see if he even gets in contact with me. Time will tell what the outcome will be. Just need some reassurance if this is correct procedure or not. Thanks
    The procedure sounds right. Work through dealer, dealer works through BRP to solve it. If you do not get good results, then you contact BRP. I am surprised that the dealer does not appear to want to look at and work on the to try to determine what the heck is going on.
    He gave you the correct info for this... BRP is called, and they assign the case #...
    The video was a GREAT idea!
    Then the fun of sorting out what happened, how it happened, and who's going to pay for it starts!
    Registered Users lookerjdc's Avatar
    Aug 2012
    Melbourne, Florida
    after 9000 miles I dont think I ever turned around to look at what was coming out of the pipe (if anything) when I was starting up the bike so............
    1. it is what it is - 2014 Black RT-S - Baja Ron Anti-Sway bar, lots of LEDs, Spyderpops Skid Plate, Twisted Sister HID Driving Lights, Tricled 2nd, 3rd & 4th brake lights, F4 Customs vented windshield, Lamonster highway pegs, Ultimate Tall Boy seat, Utopia backrest
    Aug 2012
    Melbourne, Florida
    as to the bouncing gas gauge..... there was a notice sent out by BRP late last year or early this year and the dealer should replace the existing gauge with a NEW gauge for NO CHARGE
    Mar 2013
    Marion, Arkansas
    Default UPDATE
    Well today the dealership called me regarding the 2 videos that I made. One was of the blue smoke coming out the exhaust pipe when I started it and the other was a video of the bouncing gas gauge. They said they would order a new gauge and call me when it comes in. Covered under warranty. As far as the blue smoke goes , this is what the dealership told me that BRP said about the situation. My bike only has 2100 miles and BRP said that the piston rings hasn't sealed the cylinder walls as yet. Does that sounds correct? Well at least they have my complaint on file so we will see what the final outcome of this will be. Just how long does it take the piston rings to smooth out the cylinder walls, mileage wise? I would of figured that 2100 miles would of been enough miles to smooth out the walls but I'm not that smart to figure that out. Let me know if this all sounds correct to everybody.
