Results 1 to 25 of 32
    Jul 2013
    Johnson City, TN
    Default erasing preset stations on a Can-AM RT-S Radio
    I just purchased a 2011 Can-AM RT-S and love it. I have discovered one problem however that I have not been able to figure out. The previous owner set 12 of the 15 preset stations for his area. I have been able to add 3 for my location but I cannot figure out how to erase his presets.
    Anybody figure this out?
    Jul 2011
    Florida
    Good luck with that. I have a 2013 RT LTD with the same problem. At some point I may disconnect my battery to see if that will erase all of the presets so that I can start over.
    2014 Black RT SE
    Registered Users quickster47's Avatar
    Jun 2012
    Cumberland Cove - Monterey, TN
    I think I remember from some previous discussion that there is no way to erase a preset station (DUMB - DUMB - DUMB) and that you can only overwrite them.
    Now is that stupid or what?
    Carl
    2012 White RT Limited and 2013 Yellow ST-S Think 3 .i.
    Active Member BitSlayer's Avatar
    Jul 2011
    Oklahoma
    I have even had the problem where station information will update the display and will not let me set the pre-set to one of the higher numbers. This is not a very user friendly design for the radio's user interface.
    Regards,
    BitSlayer
    2015 Spyder RT Limited - Perl White
    - Having fun with my knees in the breeze
    Active Member BlueKnight's Avatar
    Feb 2011
    Hamburg, New York
    Disconnecting the battery will not clear them, I tried.
    Very Active Member finless's Avatar
    May 2013
    Stanton, ca
    You have to overwrite them. It's a major pain too. There for sure is a bug here in the software.
    What will happen is once you tune in the radio station manually and press the down arrow to set it, when your scrolling through the preset numbers, "sometimes" it wont let you do it and the number keeps going back to the last open preset or to preset 1.
    The tip I found is set ALL the presets so there is none left (I used very high station numbers to do this). Then it seems to let you overwrite anyone you want. Also do not set a preset and then try to set the same radio station to another preset. e.g. setting 2 to the same station. It wont let you do that.
    Again the code here is super flaky!
    Bob
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    Arrow Radio Supplier
    Quote Originally Posted by finless View Post
    Bob
    FYI
    http://www.radiosound.com/customer_service.php
    Jul 2011
    Mitchell, Ontario, Canada
    Default Overwrite only.
    I use this procedure from the Quick Reference Booklet and it works for me to overwrite. I have not found a way to erase.
    Jul 2013
    Johnson City, TN
    Thumbs up Thanks for all of the great feedback!
    It's reassuring to discover that I'm not the only one having this problem. It doesn't fix the problem, but it is allows me to let it go.
    Jun 2013
    Laporte, IN
    Default THANK YOU!
    I thought I was the only one who was having so much trouble with the radio. It drives me crazy!!!!
    Maybe with these instructions I can manage to change that.
    Jul 2011
    Oklahoma
    What was causing this to occur for me is when I was setting a station that published "information" (e.g. song name, artist, etc.). Once the display would update to show the information it would reset to preset 1. Very bad design for the the user interface. Obviously the people who build the radio has not used it.
    Regards,
    BitSlayer
    May 2013
    Stanton, ca
    Quote Originally Posted by DaveNur View Post
    What else would you expect from BRP?
    Sheesh Dave! I have only been here a short time and no offense but your kind of a downer!
    I know your not happy with you BRP experience but why bring everyone else that is enjoying themselves down?
    Do you really have that much time on your hands and hate, to spend that much time on bringing negative?
    Just sayin.....
    Sometimes a positive attitude can bring happiness!
    Bob
    Jul 2011
    Oklahoma
    Dave,
    No offense, but I have enjoyed most aspects of my Spyder. The only thing that I am disappointed in is the radio and comm system. I would have expected more for those. However, I have had nothing but good experiences with the rest of the bike.
    I sincerely hope you find the root of your issues and get them worked out so you can enjoy your ride as much as the majority of us do.
    Regards,
    BitSlayer
    Regards,
    BitSlayer
    Vermont
    Default Pre -Set Radio Stations
    Quote Originally Posted by dfox View Post
    Did you look in the owners manual? ( Just trying to help) Deanna777
    Invalid Emails
    Jul 2010
    1/2way tween STJames and Salem Mo
    Question
    You can preset????I am lazy and just push the right arrow to get the next station that I can hear, If I don't like it I push it again.
    magical member harrypottar's Avatar
    May 2012
    Bellingham MA
    Default can not be done the definitive answer
    So with this question coming up quite a bit, I emailed the radio manufacture/supplier of the BRB radio's
    This is their response and I guess John Smith really does exist. (I altered the email so it couldn't be scraped)
    You cannot delete preset radio stations. But you can overwrite any station in memory with another station of your choice. Even is there was a way to reset the radio, there would be default stations stored in each memory location.
    If you have any other questions, I will be happy to assist you.
    Best regards,
    John Smith
    Senior Technical Advisor
    johns AT radiosound dot com
    Personally I have never set a preset I just use the scan feature to locate a station as I travel (when not using the iPod).
    harry
    "Draco dormiens nunquam titillandus"
    My Rides;
    Nimbus 2000, Ford Anglia, 2012 Spyder RT Limited, Pre 14 Vintage Classic Collectors Edition!
    Favorite Ride;
    Nimbus 2000 boy this thing can fly.
    Mods:
    Charm of invisibility, Reparo Charm (cuts down on service cost)
    One always wonders about roads not taken.
    Very Active Member AbNormy's Avatar
    Apr 2012
    SW Austin
    Thanks thought I wasn't holding my lips right.
    Sent from my HTCONE using Tapatalk
    2012 RT A&C bought new 42312 sold July 2018 56k miles currently driving a 2014 RTSE6 LTD bought October 2018 w 6800 miles nicely farkled
    2014 RT SE6 LTD , White
    Registered Users 3 Wheel Addict's Avatar
    Southwest Ohio
    Like the fact that it will only control Ipod crap! Do they think everybody owns apple junk? Even my 02 Wing would control a standard MP3 player!
    Member Snoopy1266's Avatar
    Woodland, CA
    How do you get it to scan to another station not on preset. Mine will only scan to the next preset station. I am limited to about 5 stations with no way to search and add more. This is the only frustrating thing I have had to deal with. My Spyder is trying very hard to make me like country music since that is the only station it will let me listen to.
    Apr 2012
    Quote Originally Posted by Snoopy1266 View Post
    Depress the button longer.
    Very Active Member garb55's Avatar
    Coolidge Arizona
    I thought everyone from Woodland Calif. liked country
    Oh well your bike will convert you soon.
    Woodland, CA
    Quote Originally Posted by Jerbear View Post
    I've tried that. It doesn't even change stations doing that. I guess I will just have to live with country music.
    Jul 2011
    In FM, AM, XM, WX mode. A short press of left or right button takes you to next or previous preset. A long press will seek up or down to active station.
    Mar 2008
    Allegan, MI
    I've never been able to change an existing preset untill all the slots are filled. Just add a new one for the station you desire. It is a crummy setup, but it is all we have available.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    It STILL beats having to listen to the Missus yammer on and on, and on and on...
Tags for this Thread
