Results 1 to 16 of 16
    Aug 2010
    Georgetown, Ontario, Canada
    Default Go Pro camera mounting location
    Anyone had success with mounting the camera without too much vibration? So far I've come to the conclusion that the suction cup is the only option.
    Active Member condorflysu's Avatar
    Feb 2013
    Brampton, Ontario, Canada
    Top of my Helmet...works great.. think I'm absorbing the vibes for the Cam.
    Aug 2012
    CO
    This thread -> http://www.spyderlovers.com/forums/s...Gopro+mounting
    And this is mounted on the other side using the suction cup.
    You decide. I have found the trick is to keep the distance between the mount and the camera as short as possible to minimize the vibration, and using a couple small bungees as both a safety tether and additional stabilization.
    FWIW I've had a GoPro sticky mount and the short attachment on a race bike at 130mph with no appreciable shake.
    JLohPhotos
    2008 GS , Millennium Yellow
    Very Active Member DocRags's Avatar
    Jun 2011
    Milton, FL
    We tried our GoPro in various spots and Ed thought the chest mount worked the best.
    2008 GS Phantom, 2012 RT Limited
    Cheryl Reinhart Ragsdale
    Registered Users quickster47's Avatar
    Jun 2012
    Cumberland Cove - Monterey, TN
    Helmet mount is the best option I've found for the GoPro. All the places I tried on the body and windshield and air deflectors had too much vibration.
    Carl
    2012 White RT Limited and 2013 Yellow ST-S Think 3 .i.
    Aug 2012
    Semmes, Alabama .
    Don't mount it on top of the mirror, I found out the hard way, I have a mount on the side of my helmet so it doesn't interfere with the opening and closing of my module helmet. It will take get video if you remember to turn it on.
    magical member harrypottar's Avatar
    May 2012
    Bellingham MA
    Quote Originally Posted by DocRags View Post
    , but people really look at you funny while you're wearing the chest mount. You do get a nice frame of the top of the spyder dash.
    harry
    "Draco dormiens nunquam titillandus"
    My Rides;
    Nimbus 2000, Ford Anglia, 2012 Spyder RT Limited, Pre 14 Vintage Classic Collectors Edition!
    Favorite Ride;
    Nimbus 2000 boy this thing can fly.
    Mods:
    Charm of invisibility, Reparo Charm (cuts down on service cost)
    One always wonders about roads not taken.
    Aug 2012
    CO
    Just don't mount it on top of your helmet... you look like a Teletubbie.
    JLohPhotos
    Registered Users joet82's Avatar
    Oct 2010
    Winlock, WA
    When I had my GP2 (its since dissapeared), I had it mounted in the same spot as the video above. Haven't tried it on my helmet, but I like that concept better as it shows where you look during a ryde.
    RS - 55K+ miles, F3 - 200 miles and counting.
    Invalid Emails
    Aug 2012
    Coon Rapids, MN
    I use this to mount my cheaper knockoff camera on the lip of the dash shooting thru the windshield. Works well if you keep the bugs cleaned off the windscreen.clampMount.jpg
    Aug 2012
    CO
    Quote Originally Posted by redflasher View Post
    I have one of those clamps too. They're BEEFY! Rock solid alternative to a RAM ball mount.
    JLohPhotos
    Invalid Emails
    Aug 2012
    Coon Rapids, MN
    Active Member sinkhole's Avatar
    Jul 2010
    Huntsville, Al
    Default camera mounting...
    Other than a helmet mount, I found the best place on the RT to mount a camera is the side air deflector (if you still have the original ones installed). I tapped out one of the small Ram balls 10-32", and drilled a #11 hole in the air deflector to mount the ball. I tried the ball mounted on the inside as shown, as well as on the outside of the deflector with equal results.
    Dave
    Never leave well enough alone! (Raymond Loewy)
    Feb 2020
    Albuquerque, NM
    That is a clean and clever idea, will try that, thanks!
    Jun 2017
    Rapid City, SD
    I’ll add one to consider “fat gecko”
    HE>I
    2017 RT , Asphalt Grey
    Aug 2013
    SF Bay Area
    I use the TricLED dash bracket and GoPro Max 360.
    2021 F3 Ltd , Magna Red
