"E"
I left the house to take a trip to a neighbor town yesterday and about three blocks from house I stoped and made a left turn. My RT hesitated, screen went orange, the gear indicator showed an "E". I finished the turn and all cleared up and was fine. I returned home and checked the oil, it was at the full mark. Made the trip with no problems. Should I be concerned? This has happened only once in the 6000 miles.
J. D.
2016 F3T Magnesium Metalic : Smooth Spyder Dual Backrest, Lamonster LED Head lights and Fog lights
Do you manually downshift? This happened to us when we first had our . We were coming to a red light, and I was downshifting. I attribute the event to me hitting the down paddle at the same time as the SE5 was going to downshift to first anyhow.
Check the codes if it happens again. Once in awhile is a glitch but if it get worse or the codes indicate failure vice incompatibility, you probably need a new gear position sensor.
Bill
Pride Runs Deep Semper Tacitus
An armed man is a Citizen; an unarmed man is a subject....
2017 F3 T SE6
2015 Vulcan Vaquero ABS
ALR Chapter 401 (Hilliard FL)
GA & FL Patriot Guard
I do manually downshift as I approach a stop sign. I will try code retreival if it happens again.
J. D.
Displaying "E" (Note without the R+N lights flashing) denotes gear position sensor fault.
I agree with everyone else drive on and see if it happens again.
